Old October 30th, 2009, 06:26 PM   #121
g21-30
g21-30's Avatar
That's OK about the switch. I'm thinking the gray wire, which isn't connected to anything on the '88-94 CDI, may have something to do with the kickstand issue. It appears that it only connects the '08 CDI to the ignition.
I couldn't pass up the chance to rib you a little on the multiple changes. As I stated, we have all done it.
Old October 30th, 2009, 09:50 PM   #122
Snake
Snake's Avatar
After reading how you motorcycle gurus were able to take a pregen CDI and adapt it for a newgen bike it got me thinking. Since the BRT TIS ignition only available for the newgen could it be adapted for use on a pregen?
Old October 30th, 2009, 10:06 PM   #123
I think you would need the schematic of the BRT TIS to answer that question.
Old October 31st, 2009, 05:03 AM   #124
g21-30
g21-30's Avatar
If someone will post a pic of the connector on the BRT TIS, I will hazard a guess. My first thought is it could be wired to fit the '88-94 pregen. For '95 and up, I don't have a schematic of the OEM harness.
Old October 31st, 2009, 05:48 AM   #125
Racer x
Racer x's Avatar
MOTM - Sep '18, Feb '16
The 2008 ninja 250 connector plugs straight into the BRT-TIS unit . I don't think it would be a problem to reverse wire it to the 88-94 or the 95 to 07 bikes . The only one that wont work is the 86-87 because they have a dual pick up .
oops
THe wiring pattern on the 95-07 is different but the system is the same.I think the wire colors are the same .The only reason I used the 88-94 box was the 15000 rpm limiter.
Last futzed with by Racer x; October 31st, 2009 at 03:01 PM.
Old October 31st, 2009, 08:30 AM   #126
Snake
Snake's Avatar
I am not familiar with electrical wiring, correct me if i'm wrong, but it sounds like I need to get a schematic for an 08/09 and one for 89 - 07 and make a harness to mate the BRT TIS to my bike.
Old October 31st, 2009, 09:53 AM   #127
g21-30
g21-30's Avatar
Rick there was a typo in the 2nd part of Racer-X's post. You need a schematic for '95-07. My harness (+Racer-x's) is for an '88-94. There is not a schematic for the '08+ in this thread.
Old October 31st, 2009, 10:58 AM   #128
HKr1
IC2(SW)
HKr1's Avatar
http://www.ninjette.org/forums/showp...2&postcount=20
Old October 31st, 2009, 11:03 AM   #129
g21-30
g21-30's Avatar
Kerry, Thanks! It's been too long. I saw starter lockout and blew right by it!
And the one I have for '08 is much more detailed, because the one you posted was from the starter section of the service manual.
Old October 31st, 2009, 11:07 AM   #130
HKr1
IC2(SW)
HKr1's Avatar
Did you ever try and jump the clutch switch, to the neutral switch, to see if the kick stand switch could still be used?
The green line in 08 pic:
Old October 31st, 2009, 11:12 AM   #131
g21-30
g21-30's Avatar
Nope. Removable jumper (connector with a loop) is in place. I like it much better.
Wasn't able to get a sticky for the CDI Troubleshooting thread, so you can find it here:
http://www.ninjette.org/forums/showthread.php?t=33076
Last futzed with by g21-30; November 13th, 2009 at 04:35 AM.
Old January 15th, 2010, 01:36 PM   #132
I've now had a few runs up the hill since doing the CDI swap and I have to say I don't notice the advance curve enhancing power. It does rev past the redline, so I know the CDI is working as advertised.
That being said... I love the change. I'm one of those that hates hitting the rev limiter. It happens all too often with this bike when gearing down to pass someone quickly while traveling uphill. With the new CDI, that problem is a thing of the past. I'm usually pretty aware of when the bike is near the redline by the engine wail, but now it doesn't fall on its face when I need to make that pass should I hit the stock engine ignition cutoff when doing so.
Thanks again, Sam, for the well detailed DIY and the help you provided offline.
Old January 15th, 2010, 05:01 PM   #133
randomwalk101
self wrencher
randomwalk101's Avatar
No increase in hp but did you noticed any increase in throttle respOnse?
Posted via Mobile Device
Old January 15th, 2010, 05:06 PM   #134
no... not really.
Old January 15th, 2010, 06:24 PM   #135
g21-30
g21-30's Avatar
kelly,
You're more than welcome! I love the fact that the tachometer is ALWAYS correct, now.
Old May 19th, 2010, 03:10 PM   #136
Sam,
Just had to thank you again for this mod. I had a chance to really push the bike this weekend and appreciated being able to keep the bike singing in the upper registers without the electronic muzzle the stock CDI clamps on. I love the way the bike will continue to rev till I'm ready to shift.
I'm careful not to over rev it, but it's nice having a small margin to play with when flirting with the redline.
Mahalo, braddah!
Old May 19th, 2010, 03:51 PM   #137
g21-30
g21-30's Avatar
Kelly, you're more than welcome! We're in an exclusive club "New Gens with 20 Year Old CDIs"! I have actually never felt the limiter on mine, since I retrofitted prior to ever going over 13-14K RPMs.
Old May 19th, 2010, 05:22 PM   #138
yep, only thing older on the bike is the rider.... just by a bit.
Old May 19th, 2010, 06:36 PM   #139
Racer x
Racer x's Avatar
Thats not a typo . The pattern for 95-07 is different than the pattern for 88-94 . The 95-07 has a 14500 rpm limiter.With the same timing . the Colors of the wires are the same they just go into different locations in the plug.
Old May 20th, 2010, 05:42 AM   #140
g21-30
g21-30's Avatar
Eric, thanks for the clarification. I apologize for any confusion that I may have caused!
Old May 29th, 2010, 01:23 PM   #141
barmaley
Motorcycle(s): 250r ninja + 600vlx
cdi #s
sorry to bring an old thread up, didn't want to start a new one.
I bought a cdi from ebay that supposedly came off a 1994 ex250. I should've asked for the numbers or at least gotten suspicious that it could be a different cdi. It looked fine in the pic, but when i took off the rubber sheath off of it, i saw the casing was cracked. It was cracked specifically as you can see at the opening, obviously to switch it out(the circuit board), why else? someone just opens it up to look at it and put it back?
Anyways, the casing reads 21119-1233. The the cdi board itself has four prongs from each side, totalling 8 and the left one being wider as if to house 6 prongs - just like the 88-94 cdi you guys posted pics of. Here's a picture of the whole thing:
Do you think this will be ok to use and what model years suppose it is from? I was thinking about just simply connecting the appropriate wires to the metal prongs w/ holes in them and making it nice and water proof. So i don't need a harness. Are ALL the prev gen ex250s have the same aggresive map on them as the 88-94 gen?
barmaley is offline   Reply With Quote
Old May 29th, 2010, 03:52 PM   #142
g21-30
g21-30's Avatar
See post #17 in this thread. You have the CA version, which does NOT have the same timing as the non-CA (1229) version. If you want to still use it, I would recommend putting the housing back on and sealing it with rubber epoxy. Buy a used '88-94 wiring harness and cut the two connectors with 7-8" leads left on them. Use the Scotch Lock connectors (shown in this thread) to connect to your OEM harness. If the 1233 CDI works then you're done; otherwise, disconnect the connectors and hook up the original and look for a 1229 version.
Good Luck
Old June 7th, 2010, 06:47 AM   #143
dubojr1
dubojr1's Avatar
Any of you guys interested in making some plug and play harnesses for this swap?
Old June 8th, 2010, 03:48 AM   #144
g21-30
g21-30's Avatar
But you haven't determined for sure that it's the CDI. You're in the absolutely BEST position (owning 2 post gen bikes) to test the CDIs (swap them from each bike).
Besides, you stated here that you going to try something else first:
Cool idea. Guess I could try that before swapping the CDI's around from 1 bike to the other.
Old June 8th, 2010, 05:09 AM   #145
dubojr1
dubojr1's Avatar
As for the plug and play harness.... Yeah I'm not ready to swap to a 88-94 CDI. I came across a deal that would be perfect just to grab up and have on hand. To me that would be the perfect position to be in being I'd have one bike that I know at least has the varying RPM issue along with the odd shut down problem, and one bike with no known issues, and the part that is supposed to fix any CDI issue.
I'm not ready for that though. I would be interested to know if one of you guys would consider a plug-n-play harness though for my own knowledge.
What I want to do first is fill the troubled bike back up with fuel which is the only varible that is not identical when I had the problem. I'll do this first before moving to any others step. Next will be the least expensive option for me and prolly the best for the group and that is to make the CDI swap from one bike to the other.
Old June 8th, 2010, 12:17 PM   #146
Momaru
Momaru's Avatar
As for the plug and play harness.... the varying RPM issue along with the odd shut down problem, and one bike with no known issues, and the part that is supposed to fix any CDI issue.
What exactly do you mean by "odd shut down problem"? Is there a thread describing it that I missed (or a post earlier in this one)?
I've been having some strangeness with my RPM bouncing around +/- about 500, but not exactly the way as described with the CDI issue. My bike has cut out on me a couple times when it shouldn't have, so I'm considering the CDI swap as a project, an improvement and a diagnostic.
I'd be quite willing to see if I can set up a plug & play wiring harness, but it'll likely take a month or two as I'll need to get all the parts together and review this thread/other materials.
Proud member of the Blue Army
Old June 8th, 2010, 12:35 PM   #147
dubojr1
dubojr1's Avatar
Here's the thread. Please don't confuse this one with others that are discussing the varying RPM issue. This concern is not the same.
http://www.ninjette.org/forums/showthread.php?t=43990
Old October 26th, 2010, 10:31 PM   #148
headshrink
headshrink's Avatar
What is the difference between the CA version and non.... other than part number?
Old October 27th, 2010, 08:34 AM   #149
barmaley
the lower RPMs on the CA model have less aggressive timing, not as advanced. 5 degrees instead of 10.
Old October 27th, 2010, 04:21 PM   #150
g21-30
g21-30's Avatar
Here you go:
Old October 27th, 2010, 08:42 PM   #151
headshrink
headshrink's Avatar
That looks pretty significant. Are these the ONLY years the CA version is timed differently? Are new-gen CA CDIs the same as non-CA CDIs?
Old October 28th, 2010, 04:03 AM   #152
g21-30
g21-30's Avatar
CA versions are always timed differently, as are the new-gen CDIs. The '88 CDI removes the rev limit (previously mentioned).
Old September 13th, 2012, 08:24 PM   #153
thomason2wheels
thomason2wheels's Avatar
Motorcycle(s): dl650
Well, now we have three post gens converted via pre gen CDIs! Who will be #4? Any predictions?
Yeah i know this an old thread, but i would seriously like to have the additional sparkadvance...approximately what is the expected cost odf this mod?
thomason2wheels is offline   Reply With Quote
Old September 14th, 2012, 04:28 AM   #154
g21-30
g21-30's Avatar
^^ The cost of the CDI is biggest variable, along with the wiring harness, which will need to be modified. I found mine on eBay as did kkim and it is probably mentioned in this thread somewhere. Just a SWAG would be a total of $50-65.
Good Luck!
Old September 16th, 2012, 01:14 PM   #155
headshrink
headshrink's Avatar
I was going to replace my '08 CA version CDI with the older non-CA version mod. However, after reading all the related threads, researching all the connectors, etc., decided to pickup a used BRT TIS. In the end I think I payed roughly the same, and am happy I went this route.
Old September 16th, 2012, 05:20 PM   #156
thomason2wheels
Originally Posted by Ken View Post
Thanks for the confirmation. I'm using the BRT TIS right now and I have the timing advanced to 44 but I'm running on premium with no pinging so I should be fine.
What is the brt tis? How much does it cost and do i want one?
I was with Alex.S and Jiggles last night and they had sex....the video is on utube. :-)
Old September 16th, 2012, 05:39 PM   #157
Racer x
Racer x's Avatar
It is a cdi that is fully programmable or they have one with a pre written map. The programmable unit has two maps and adjustable rev limit. Check out Sportisimoto USA . Some one was selling one here last week.
Worlds fastest 250 ninja
Old October 5th, 2012, 08:47 PM   #158
thomason2wheels
Talking
Below is some info I combined from the other thread and a comparison of the timing for both years '88 and '08.
After more research, I now know that I have the non-CA, i.e. US version of the '88-04 CDI. The relevant part numbers are: 21119-1229 (US) and 21119-1233 (CA). Per the attached picture from the '88 Service Manual, it looks like the timing can vary roughly 5 degrees thru-out the power curve!
'88-94 - Timing specs: 10 degrees BTDC @ 1300 RPM / 42 degrees BTDC @ 4500 RPM
'08-09 - Timing specs: 10 degrees BTDC @ 1300 RPM / 35 degrees BTDC @ 4000 RPM
Hi Sam, I am looking really hard at possibly doing this mod, but couldn't you get much the same effect by advancing the static timing? You'd get better torque down low and sufficient advance up high. Is there an easy way to adjust static timing on these engines?
Thanks in advance....no pun intended...hehe.
Old October 9th, 2012, 06:24 AM   #159
g21-30
g21-30's Avatar
When I did this mod, my OEM CDI was overheating (much contention about this) and not functioning correctly; therefore, I wasn't thinking about static timing. I wanted a responsive engine with reliable tachometer readings. The timing advance and no rev limiter were just icing on the cake. My goal was achieved.
Old July 21st, 2013, 05:53 PM   #160
rfstinker
Motorcycle(s): 2011 ninja 250
will this also work on a 2011? I've had the tach fluctuation problem too. So far I've replaced my stator and the voltage regulator.
rfstinker is offline   Reply With Quote
CDI Ignitor compatibility between years Quick1 1986 - 2007 Ninja 250R Tech Talk 4 December 2nd, 2013 07:50 PM
'08+ CDI, anyone opened it up before? Soujyu 2008 - 2012 Ninja 250R Tech Talk 4 June 1st, 2013 04:28 PM
Few Different BRT CDI's ? HKr1 2008 - 2012 Ninja 250R Tech Talk 2 December 18th, 2010 03:59 PM
