December 18th, 2021, 02:21 PM | #1 |
Join Date: Aug 2020 Motorcycle(s): 2008 Ninja 250 Posts: 15
2009 Ninja 250 theft recovery rebuild
I am sharing this because I feel accomplished and don’t have anyone to tell. At least nobody who appreciates my undertaking. This journey started 18 months ago at this point. I got a 2009 ninja 250r theft recovery from my brother, it was only missing for a few days but it had a busted ignition and did not turn on even after my brother purchased a Chinese ignition. I got it from him for $400 and decided I was going to have to just service the entire thing. My brother had originally purchased it from some guy on Craigslist who kind of mashed a bunch of bikes together and half the things on it where broken or did not work, the vin number matches title for a 2009 but a few production stickers on the frame and engine have a manufacturer date of 02/2012. He ran it into the ground further until it was stolen. So when I got it all hoses where shot, all bearings where shot, the suspension was terrible and my brother told me how it was constantly bottoming out, forks where leaking heavily. Front brakes didn’t work because the caliper was seized, rear brake was leaking fluid. Brake lines where in poor shape spongy and leaking, fluid reservoir was leaking and full of dents, Sprockets where completely worn out, chain was covered in rust and in poor shape, all the turn signals broken and most of the fairings just gone and what was left where in poor shape. The front cowling was cracked and the support had been bent back into shape but badly rusting and looking bad, engine supports where cracked, engine was only held in place by bottom bolt(my bother later told me how he could feel the engine move independently from frame while he was accelerating etc.), radiator was leaking, all hoses where spongy and leaking. The handle bars where all bent and all the controls felt hard, the choke, the carb, and the clutch cables where all damaged and breaking. The engine oil was black and there was oil leaking from the head And from oil filter. Battery tray and a lot of other smaller items where missing so wires where just kind of shoved under the seat. Odometer was cracked and the gas gauge didn’t work, foot controls where all bent out of shape, muffler had a lot of holes from rust and was badly dented. I knew 2 things where good, the headlight and the engine. I was familiar with the engine and it ran strong, I saw the bike days before the incident and that engine was running strong with no strange sounds or anything seeming out of place. While the bike didn’t stay on it would start for a few seconds, enough to know the engine more than likely doesn’t require a rebuild and was just tossed because they couldn’t Hotwire it.
Not in this particular order but I’ve done the following:
I have tested all the controls and they feel smooth and precise, the steering feels smooth as butter, the braking system feels great, the front suspension feels pretty good. Im worried that I made a mistake and I’ll have to rebuild engine, i have experience rebuilding all sort of engines including jet engines so I’m pretty confident doing this type of work even though my last rebuild was in 2010. I have put it into gear and moved the wheel to turn engine and everything seems to be turning perfectly fine so I’m probably just being paranoid. I’m also worried about the possible sound from my $32 Amazon slip on muffler. Undecided on what color for the fairings. Any input from anyone on anything I should do or look out for as far as first start, break in procedure for brakes or even suggestion for the color Is appreciated. I might keep it all red, already has red accents on a few of the new parts, and of course in the spirit of being cheap I will avoid painting the tank. I have seen a black and red fairing kit I liked. I really like white and saw a white and red beet fairings kit, But not sure if I want it to look like I want to race everything. Also saw a green fairing kit which had a green tank cover, that would make my bike look like new. |
January 1st, 2022, 08:06 PM | #2 |
Let me say congrats and well done. I don't know if you have ridden your bike yet but I hope so. If not, why not?
Just do a thorough checkup on all the hardware to make sure there are no loose bolts and such. It happens! That would be my break in advice for you. It sounds like the motor is already well seasoned. I'm curious what adjustments were needed if any for the valves. Was the lash loose or tight or out of spec? Did you buy a shim kit, or was all well and no adjusting needed? As far as color choice, do what YOU want then ride that thing, you won't be thinking about fashion or looks when you hit that perfect apex, just the next apex! Everything else is old oatmeal. I recognize the effort required to take a neglected bike and bring it back to a safe and top performing machine Let's hear some news about your results! |
January 26th, 2022, 11:53 AM | #3 |
Retired motorcycle Mc.
Join Date: Jul 2021 Motorcycle(s): 2012 Kawasaki Ninja 250R, 2021 CSC TT250, 1977 Triumph Bonneville 750cc,2001 Honda XR650L. Posts: A lot.
WOW ! you've put alot of time and effort into that thing ! WELL DONE!
wait till you ride it and feel how it corners ! my little ninja corners better than anything else i have ever owned ! and I've had over 50~75 bikes in my time ! enjoy your completely new machine ! just be careful ! and keep your speed down, till you get to know her ! .... Bob.....
Its too late when you've gone too far ! |
February 21st, 2022, 07:36 AM | #4 | |
Have not ridden it yet. I got quite busy in December all the way through the middle of January. I filled all the fluids and discovered a leak at one of the coolant pipes, ordered new O rings abut I got busy again. I installed the o ring a few weeks back but I’ve had nothing but hesitation on my part, mostly due to fear that the engine would blow up on me. I woke up with resolve and just fired it up this morning for the first time in 21 months. turned on easily, I felt incredibly relieved that it works. As far as the valve lash, all of the valves where out of spec, most of them had a gap between .003 and .006. |
February 21st, 2022, 07:39 AM | #5 | |
February 21st, 2022, 08:20 AM | #6 |
It turns on!
Took about 8 seconds of cranking for it to start. Turns on no problem, noticed a leak from another coolant pipe so I turned it off to avoid issues. So far everything appears to be running smoothly. Please watch video and comment, I appreciate any feedback, does engine sound ok?
March 3rd, 2022, 11:58 AM | #7 |
Sounds good to me ! ride it for a short run without the fairings on it just to be sure you don't have to take them off again (their a pain !)
the coolant will drip from the over flow vent if you put in too much coolant it's not a concern just keep an eye on the coolant tank and make sure you keep it at least 1/2 full. if it drops during riding then you have a problem. .... Bob......
March 3rd, 2022, 10:10 PM | #8 |
Woohoo!!! Awesome job on that massive repair list! Wow!!!
It's so amazing to bring these fun bikes back from brink! |
March 24th, 2022, 06:40 PM | #9 |
Thanks for the good vibes. I know you have allot of experience with these bikes so I have a question for you. I am concerned about some unusual noise coming from under the valve cover, I took a video and showed it to a mechanic. I don’t know how well experienced he is but I just finished repairing a Dynojet dynamometer for him as he builds race bikes so I’m assuming he knows what he is talking about. He told me it sounded like I have air inside the oil pump, asked if I primed it and I obviously said no, he says I have to remove external oil line unplug the spark plugs and crank engine until I get oil coming out. I tried looking this up but found only info about doing this on the bigger Kawasaki engines like the zx6rs. The oil light is not on, do you have experience priming the oil pump to remove air bubbles? If so I could really use a hand with this.
April 15th, 2022, 06:02 PM | #10 |
i HAVE never HEARD of having to prime the ninja's oil pump I think the guy is referring to the other bigger bikes.... your bike sounds good make sure theirs oil and coolant in it and give it a test run
can you take a video of where the funny sound is coming from and an audio of it too.... Maybe Danno can identify the problem but to me the bike sounded great ! .... did you tighten the cam chain ? .... Bob....
04 Ninja 250 Carb rebuild kit | Ninja Rob | 1986 - 2007 Ninja 250R Tech Talk | 18 | August 10th, 2019 01:41 PM |
1987 Ninja 250 Rebuild | Jozed03 | Pictures | 13 | May 26th, 2016 05:09 AM |
2009 Ninja 250r Race Bike Rebuild! | NINJosh. | 2008 - 2012 Ninja 250R Tech Talk | 25 | January 21st, 2014 05:07 PM |
[sportrider - latest stories] - SkyLINK Introduces Advanced Theft-Recovery Solution f | Ninjette Newsbot | Motorcycling News | 0 | April 4th, 2012 11:50 AM |
Ninja 250 Theft? | d4land | General Motorcycling Discussion | 8 | August 9th, 2011 04:20 PM |
