Old April 6th, 2022, 08:43 AM   #1
jjlaw66
Motorcycle(s): 2011 Ninja 250r
2011 Ninja 250 high idle
This morning I was on the freeway and when I got off and stopped at a stop light my idle was suddenly at 3k rpm!? Bike was running totally fine before then so that was very confusing for me. I’m not super mechanically inclined so if I don’t have to take out the carb and clean it that would be sweet, but I guess that’s what comes with the territory. Have had the bike for about 6 months and had the carb cleaned by a shop when I purchased it. Bike has 4k miles on it.
jjlaw66 is offline   Reply With Quote
Old April 6th, 2022, 09:04 AM   #2
thedrewski86
thedrewski86's Avatar
Did the choke cable get hung up?
Don't think, look!
Old April 6th, 2022, 12:01 PM   #3
jjlaw66
I’ll see if I can check that tonight, though that seems like a weird thing to spontaneously happen… Choke was off during the ride so for it to get stuck in the on position seems odd to me. Before getting on the freeway the idle was normal at 1-1.5
Old April 6th, 2022, 12:46 PM   #4
thedrewski86
I suppose a vacuum leak may be more likely. I spray of carb cleaner around the carbs while running may lead you to a cracked boot or misplaced vacuum line. It's hard to say, these carbs are tiny and any imperfection is magnified in how they idle, just gotta get in there and start digging.
Don't think, look!
Old April 6th, 2022, 05:06 PM   #5
jjlaw66
Well I have no idea what I did but it’s better now. I’m guessing maaaaybe either the choke or throttle cable was hung up or something because I did give them both a jiggle, though there didn’t seem anything off with them at the time. Weird.
Old April 7th, 2022, 12:10 AM   #6
Could also be choke-cable needs lubrication.
2006 Kawasaki Ninja 250R high idle Elgaaenj New Members 11 February 23rd, 2020 07:58 AM
Idle High, Adjuster All the Way Down Speedy3 2013 - 2017 Ninja 300 General Discussion 2 May 22nd, 2017 08:48 AM
High idle issue dannyb 1986 - 2007 Ninja 250R Tech Talk 14 July 11th, 2015 06:58 PM
2006 Ninja 250 High Idle RPM GunnaBoyEB 1986 - 2007 Ninja 250R Tech Talk 4 September 4th, 2014 10:30 AM
Idle - too high ninja_sleeper 2008 - 2012 Ninja 250R Tech Talk 26 August 30th, 2011 06:11 PM
