Old April 26th, 2022, 07:15 PM   #1
Zgray350
04 250f carb bowls
I got a 04 250f ninja and working on carbs I cleaned them all out several times and I’m not getting fuel in the bowls. I put gas in the bowls put it together and started it and it ran till they was empty and there not filling up I can watch the gas go to the carbs what am I doin wrong float needles look good keys are all clean and clear. I can unhook fuel line and crank and it squirts gas out so I no it’s getting fuel to the carbs
Zgray350 is offline   Reply With Quote
Old April 26th, 2022, 07:33 PM   #2
it might be case where petcock flows fuel, but carbs are using it up faster than petcock can supply?
Old April 26th, 2022, 07:42 PM   #3
Zgray350
If I unscrew drain screws and crank nothing comes out
Old April 26th, 2022, 08:20 PM   #4
When you say "I can unhook fuel line and crank and it squirts gas out", which end of hose did you disconnect? Where it goes into petcock or where it connects to carbs?
Old April 27th, 2022, 04:19 AM   #5
Zgray350
Both ways I get fuel
Old April 27th, 2022, 04:30 AM   #6
ducatiman
ducatiman's Avatar
is the carb vent line capped/plugged? Note it should be totally free to "breathe", fully open, not kinked or plugged in any way, shape or form.
gordon@customcarbservices.com
Custom Carb Service
www.customcarbservices.com
Old April 27th, 2022, 06:21 AM   #7
Have you looked for a plugged in-line fuel filter?
https://faq.ninja250.org/wiki/How_do...fuel_filter%3F
https://faq.ninja250.org/wiki/File:D...ine_filter.jpg
https://faq.ninja250.org/wiki/File:Fuel_Filter_4.JPG
Old April 27th, 2022, 06:34 AM   #8
Zgray350
In-line fuel filter good I’m getting fuel past filters to carb
Old April 27th, 2022, 09:30 AM   #9
ducatiman
ducatiman's Avatar
do you have a mesh inlet filter present in the black carb inlet fitting? Clogged up?
next in the line would be the carb float needles/seats. Stuck/sticking?
I believe a carb pull is in your immediate future.
Custom Carb Service
Old April 27th, 2022, 09:36 AM   #10
I think conclusion of all this is fuel-rail is clogged or float-valves are stuck to their seats. Either one requires disassembling carbs for full restoration job.
Old April 27th, 2022, 01:01 PM   #11
Zgray350
I even took the filter out the inside of the hose and hooked a squirt bottle of gas to it and still nothing Iv had them apart prolly 6 times now and cleaned float needles and seats really good needle spring works good floats float in a cup of gas Imma tear back into them today and see what happens I guess
Old April 27th, 2022, 05:30 PM   #12
Hmm ok, something between fuel-rail and float valve-seats then.
A USB camera can actually fit into fuel-rail to take look around.
Old April 27th, 2022, 08:50 PM   #13
NinjaBiker
Motorcycle(s): 2007 Ninja 250, 1985 Honda XR200R
When I had this issue, I had to pull the carbs and do a thorough cleaning using the wealth of information available here in ninjette.org. Long story short is that I got the carbs cleaned, re-installed, and sync'd as best I could. Bike runs very well now. However, cold start is an issue. I think I should have checked the choke lever action and plungers for issues. But once the bike starts and warms up, it runs very well. Many thanks go out to all who volunteer their knowledge and advice here.
NinjaBiker is offline   Reply With Quote
Old April 28th, 2022, 06:26 AM   #14
That's strange, because there's not that much that would stop fuel flow between that point and the float valves.
Seems like the float valves would have to be stuck, or there is a significant blockage somewhere, which is odd as well.
Old April 28th, 2022, 07:17 AM   #15
ducatiman
ducatiman's Avatar
agreed.....and as such, as I posted earlier.....
"I believe a carb pull is in your immediate future."
Anything less, I'd characterize as irresponsible.
Custom Carb Service
Old April 28th, 2022, 07:57 AM   #16
Ghostt
Ghostt's Avatar
I get the feeling this I'd gonna be a long thread
violente et ignorantia
ZX-2R BLOG
Old April 28th, 2022, 08:05 AM   #17
Could be previously an internal filter got wadded up and went into fuel rail?
Although that would still dribble petrol through at slow rate.
Pencil eraser stuffed in there?
Potatoe or banana?
Old April 28th, 2022, 03:09 PM   #18
ducatiman
ducatiman's Avatar
zgray....wha' happened?
Custom Carb Service
Fuel Not Flowing to Carb Bowls NinjaBiker 1986 - 2007 Ninja 250R Tech Talk 11 April 27th, 2022 05:44 AM
Seafoam in the carb float bowls? Kurgan 2008 - 2012 Ninja 250R Tech Talk 14 July 22nd, 2015 10:06 PM
Unscrew carb bowls - tips please mickheaven 2008 - 2012 Ninja 250R Tech Talk 10 September 5th, 2013 09:52 AM
Hex Replacement Screws for Carb bowls and tops g21-30 2008 - 2012 Ninja 250R Tech Talk 2 June 14th, 2010 06:52 PM
