Old May 19th, 2022, 12:08 PM   #1
Rumple_45
Motorcycle(s): Ninja 250R 2011
[Kawasaki 250R 2011] Engine sounding weird? "knocking", and random metal "ticking" so
Engine sound
https://imgur.com/a/nVTflI6
What jumps to you when hearing the engine? Anything I should focus on fixing or is everything fine?
Thank you
Rumple_45 is offline   Reply With Quote
Old May 19th, 2022, 09:10 PM   #2
Hi and Welcome!!!
What's history behind his bike?
What kind of maintenance in past year?
Did these sounds occur gradually or suddenly?
I'd start with doing valve-clearance measurement, then adjustment if necessary. Then follow compression-test. That'll give us some numbers to work with.
Old May 19th, 2022, 11:18 PM   #3
Rumple_45
Hi and Welcome!!!
Hi and thanks It is simply wonderful here, been learning a lot already.
It has "19,000" on the dash, I honestly couldnt tell you what that means, we use "mil" here in Sweden so 19,000 "mil" of sorts?
I have used it as a daily through the 2 years of owning it. And I have not done a valve clearance check or adjustment on it, nor have have a adjusted possible chain slack. I just change the oil but I realized I havent been changing the oil filter or air filter so something nasty must making the screw jiggle sound in the engine?
The "knocking sound" gradually grew more audible and the little loose screw "ticking" sound came suddently but its barely audible so I'm not sure if its been there long.
[superbikeplanet.com] - Back in Stock & Shipping: "Roberts" and "Lawson" Yamaha Art P Ninjette Newsbot Motorcycling News 0 March 13th, 2015 01:40 PM
[topix.net] - "The Fonz", "Ralph Malph" & "Potsie" are giving away Fonzie's motorcycl Ninjette Newsbot Motorcycling News 0 August 16th, 2012 04:30 PM
[sportrider - latest stories] - Chris "Teach" McNeil stars in "New Hire". Ninjette Newsbot Motorcycling News 0 March 5th, 2012 04:50 PM
[sportrider - latest stories] - Nitrous Oxide--"Wet" and "Dry" Kits Ninjette Newsbot Motorcycling News 0 April 12th, 2010 11:20 PM
[sportrider - latest stories] - Nitrous Oxide--"Wet" and "Dry" Kits Ninjette Newsbot Motorcycling News 0 April 9th, 2010 11:30 AM
