Old June 19th, 2022, 03:36 PM   #1
Fatherof2
Motorcycle(s): 2017 Triumph Trophy, 2001 Honda Valkyrie, 2007 Ninja 250, 2017 Yamaha 250X, 2018 YZ125
I can't get my carb back into the air boot!
Hi Guys,
Not my first time rebuilding a carb, but it is the first time I could not get the carb back in the bike after a rebuild!
In fact, I am so frustrated that I took the airbox boot out of the air box and also removed the carb again. I still could not get the boot onto the carb with both out of the bike!
I have tried lubricant. The boot almost seems too small. The boot is not cracked or brittle. It is not terribly soft, but it is a bit pliable.
Thoughts?
Thanks All!
Fatherof2 is offline   Reply With Quote
Old June 19th, 2022, 04:25 PM   #2
Not sure how this is impossible... Make sure spring-clamps have been rolled off end of boot where they go over carbs. And also verify tubes aren't folded over inwards. Other than that, I can't image what could possibly be wrong.
Post some close-up photos of these boots, straight-on, from side and at 45-degree angle.
You maybe trying to do too much at once on bike. Break it up into separate stages:
1. shove carbs back in
2. insert left rubber manifold back onto head. Pay attention to orientation, it's marked which end faces head and which end faces carbs. Tighten clamp (right manifold should've stayed clamped to head)
3. Spray little silicone lube onto rubber manifolds. Shove carbs into manifolds, you should feel satisfying >clunk< as they slide into position
4. tighten clamps holding carbs to manifolds
5. squirt little silicone onto airbox boots that go over carbs.
6. gently slide and wiggle airbox boots over carbs. Might want to look from underneath with flashlight to verify boots haven't overlapped carbs and folded inwards. If so, reach in with long screwdriver and pry out folded-in section
7. roll spring-clamps over on airbox boots.
Old June 19th, 2022, 04:37 PM   #3
ducatiman
ducatiman's Avatar
adding to above.....try blowing with an electric hairdryer to soften the rubber
gordon@customcarbservices.com
Custom Carb Service
www.customcarbservices.com
Old June 19th, 2022, 04:57 PM   #4
If you've got stiff shrunken boots, it's possible to restore them to original pliable condition like new with this procedure: https://www.ninjette.org/forums/show...72&postcount=5
I just did this with rubber-manifolds on my 36-yr old VFR750. Getting those carbs into V between cylinders is impossible if they're not soft & rubbery!
Old June 20th, 2022, 12:17 PM   #5
Fatherof2
Thanks Danno!
Appreciate your input.
I am no stranger to removing, rebuilding and installing carbs.
I do think these boots must have shrunk a tad and certainly lost some pliability. I will try to recondition them and see what comes of that.
Thanks again.
Old June 26th, 2022, 05:58 PM   #6
Fatherof2
I have the airbox boots soaking in a combo of rubbing alcohol and wintergreen oil.
It is really working! One of the boots is now like rubber. The other one is getting there. I just ordered more wintergreen oil to add to the mix and hopefully make that one like rubber too.
Carb to Intake rubber boot clap leaking joecool 2008 - 2012 Ninja 250R Tech Talk 1 August 24th, 2014 08:17 AM
[RideApart] - Dainese TR-Course Out Air boot Ninjette Newsbot Motorcycling News 0 July 15th, 2014 10:10 AM
[motorcyclistonline] - New Sidi Clever Air Boot Ninjette Newsbot Motorcycling News 0 January 3rd, 2011 06:30 PM
[sportrider - latest stories] - New Sidi Clever Air Boot Ninjette Newsbot Motorcycling News 0 December 22nd, 2010 04:00 PM
[sportrider - latest stories] - New Sidi Fusion Air Boot Ninjette Newsbot Motorcycling News 0 December 21st, 2010 11:20 AM
