October 26th, 2011, 05:52 PM | #1 |
Join Date: Oct 2011 Motorcycle(s): 250 Ninja - Soon Posts: 96
Dimensions
Can someone measure the opening where the front turn signals are.
See circled part in the picture included I would like to know the length, height, and depth if at all possible, as accurate as you can get it, metric measurement would be ideal, if at all possible Thanks so much Lou, I hope you don't mind me using your picture.... |
October 26th, 2011, 06:08 PM | #2 |
Don't be rubbing it in........
It will be in the garage soon................................................... Thanks for the offer to measure But I am getting prepped for when the bike is home...... |
October 27th, 2011, 08:01 PM | #3 |
Bump
October 27th, 2011, 08:08 PM | #4 |
Jigglin' your Jiglets
MOTM - Apr '13
You have large breasts and hide the salami well
October 27th, 2011, 08:16 PM | #6 |
and not so deep.......
and none of this gets me the correct dimensions....... |
October 28th, 2011, 12:50 PM | #7 |
need measurements for an idea for flush mount lights
even a rough measurement using a tape measure would help, to see if I am even close in using what I think I could use... Thanks |
October 28th, 2011, 01:48 PM | #8 |
Thanks
saw that, not what I want to do, or how to do it, but close, not going to use the existing hardware that the bike comes with... |
Front master cylinder piston dimensions? | ds650rida | 1986 - 2007 Ninja 250R Tech Talk | 3 | May 4th, 2014 04:35 PM |
CVK32 Carb dimensions | The_big_dill | 1986 - 2007 Ninja 250R Tech Talk | 7 | May 31st, 2013 01:34 PM |
brake banjo bolt dimensions? | smokinsingle | 2008 - 2012 Ninja 250R Tech Talk | 3 | February 29th, 2012 09:50 PM |
[webbikeworld.com] - Motorcycle License Plate Dimensions for U.S. States | Ninjette Newsbot | Motorcycling News | 0 | July 9th, 2009 11:10 PM |
Race Body Work number dimensions | Broom | Ninjettes At Speed | 6 | January 28th, 2009 09:47 AM |
