Old August 23rd, 2015, 12:47 PM   #1
KnuckleBuster
KnuckleBuster's Avatar
Motorcycle(s): Ninja ZX6R 2007 600cc
2007 ZX6R Clutch Spring Plate/Clutch Spring Direction?
I apologize if this is not in the right category but figured someone would know.
Does anyone know which direction the clutch spring and spring plate face? The spring plate has a flat and slightly beveled edge and the spring has a flat edge and more noticeable curve to it. The shop manual is a bit confusing and my instinct is to put both flat sides going in with bevels facing out (away from bike). These also are more like large metal o-rings than springs but that's the name in the manual. I didn't take notice when I took it apart obviously so any help is appreciated. I also have 3 different width clutch plates and from what I can tell the 2.3 and 2.9 are for the inside and outside and 2.6 are the middle ones. If anyone is familiar with this, any help is greatly appreciated. Thanks again.
KnuckleBuster is offline   Reply With Quote
Old August 23rd, 2015, 05:50 PM   #2
InvisiBill
EX500 full of EX250 parts
InvisiBill's Avatar
Does http://www.kawasaki.com/Parts/PartsD.../2007/ZX600P7F help at all?
Old August 24th, 2015, 03:21 AM   #3
KnuckleBuster
Originally Posted by InvisiBill View Post
Thanks a lot for sending this. This is what I have too. I have to assume that I have it the right way with the flat side of 92144 on the left and the angled side going to the right. The other thing I noticed is I have to shift the first friction plate to the left one notch just like the outter one is. I really should have taken a pic before disassembly because I'm not sure which groove they go in since they fit in both notches. I will have to google a few pics to make sure. Thanks for your help and getting back so fast! (When I uploaded the pic, it rotated it 90 degress CCW so it probably looks way off)
What grade are the clutch spring bolts? MrAtom 1986 - 2007 Ninja 250R Tech Talk 17 April 29th, 2015 02:35 PM
New Problem - Broke heads off two clutch spring bolts indr 2008 - 2012 Ninja 250R Tech Talk 1 June 30th, 2013 11:32 AM
08+ Barnett Clutch Spring - Reviews? abhijitz 2008 - 2012 Ninja 250R Tech Talk 10 June 13th, 2013 09:08 AM
clutch lever "plastic spring pin" gt_turbo 2008 - 2012 Ninja 250R Tech Talk 16 September 6th, 2011 07:00 PM
[motorcyclistonline] - All New Barnett Clutch Spring Kits for Ducati Ninjette Newsbot Motorcycling News 0 October 15th, 2009 12:30 AM
