Old June 11th, 2009, 08:03 PM   #1
addy126
Motorcycle(s): '09 Kawasaki N-250 + '09 Vulcan 900 Classic Lt
Scorpion Exo 700 Shields
Quick question.... anyone owning the captioned helmet... cleaning the outside visor a snap. Inside a different story.... different slightly sticky surface due to Everclear coating. What do you guys use to clean it out and avoid the inevitable "lint sticking" even from microfiber cloths?
addy126 is offline   Reply With Quote
Old June 11th, 2009, 08:38 PM   #2
OldGuy
Live Life
OldGuy's Avatar
Motorcycle(s): 2009 Green SE Ninja 250
I've got both the clear and tinted visor and haven't even thought about cleaning the inside yet - haven't really needed to.
- ATGATT -
Scorpion EX700 Hi-Vis Helmet, First Gear MeshTek 3.0 Jacket, TourMaster Transition 2 Jacket and Flex Pants, Sidi Doha boots
OldGuy is offline   Reply With Quote
Old June 11th, 2009, 09:24 PM   #3
Cedilla
Cedilla's Avatar
Motorcycle(s): 2009 Ninja 250 (sold)
Im not sure if my exo400 has the same visor, but ive been using paper towels, soap and water to clean it. Works fine for me.
Cedilla is offline   Reply With Quote
Old June 11th, 2009, 09:27 PM   #4
When I clean the inside of the visor, I remove it from the helmet and hold it under running cool water from the tap. Use a soft paper towel (like bounty) and keep cleaning/rubbing the visor till all the crap softens up and comes clean. After you're done, take a cotton towel and pat dry. To finish use a clean dry towel and wipe off any remaining water.
If I only need to clean the outside, I hold the helmet sideways, fully closed, so the face shield runs under the water from the faucet. Same drill... use a paper towel and rub the bugs/dirt until the visor is clean. Dry with a paper towel. I do this at restaurants or places you stop and the helmet needs cleaning.
I've found clean running water will take off a majority of what the helmet collects on the road and the face shield ends up streak free and sparkling without worrying if chemicals from your cleaner is removing the anti fog coating.
Old June 11th, 2009, 09:47 PM   #5
P1NDLESK1N
P1NDLESK1N's Avatar
Motorcycle(s): 2015 Ninja 300 (Sold), 2016 Z1000
Wow kkim, I didn't think it was possible to type out that much about cleaning a visor.
edit: But yeah, water and paper towels for my lids as well.
P1NDLESK1N is offline   Reply With Quote
Old June 11th, 2009, 09:51 PM   #6
DerTeufel
Motorcycle(s): 2008 Kawasaki Ninja 250R, 2009 KTM 690 SMC, 2001 Suzuki GSX-R 750 (track bike)
I will take paper towels or napkins, get them wet, and lay them on my visor. I leave them there for a minute, so that the water will soften anything that is stuck to the visor. Wipe the visor off, dry with a clean, dry paper towel, and you are done. For the inside of the visor, I take the visor off the helmet, run it under running water, then take a mild soap and use my fingers to wash the visor down. I fling the excess water off and pat dry with a paper towel.
DerTeufel is offline   Reply With Quote
Old June 11th, 2009, 10:11 PM   #7
addy126
Thanx guys just want to avoid surface scratching with wiping it dry. The inside is the trouble spot with that "additive". Catches anything linty and when you are out it creates alot of "shiny scratchy" looking artifacts on the lens. Wash it again, it comes off... its the drying process that can be the trouble.
Scorpion exo 700 shell size? VengeanceB4U Motorcycle Gear 2 November 2nd, 2012 12:31 PM
Scorpion EXO 700 Review!! Jninja Motorcycle Gear 9 November 11th, 2011 01:48 PM
Scorpion Exo-700 helmet (M) nomen cognomen Gear-related 1 June 23rd, 2010 02:46 PM
[motorcyclistonline] - Scorpion Hollywood EXO-700 Helmet Ninjette Newsbot Motorcycling News 0 March 30th, 2010 04:00 AM
Scorpion EXO-700 Burst Helmet ninjablk08 Gear-related 3 June 18th, 2009 08:54 PM
