March 8th, 2009, 08:33 AM | #81 | |
Join Date: Feb 2009 Motorcycle(s): 2008 Ninja 250R Posts: 290
http://www.southparkstudios.com/clips/224099 |
March 8th, 2009, 08:56 AM | #82 |
Been there, done that! The only problem is the water in the bowl. If it's a lot, the engine stops. If only a little, maybe a slight miss. Too much starter fluid and we have other problems, i.e. kind of like the first "pig in space"!
March 8th, 2009, 02:52 PM | #83 |
Join Date: Dec 2008 Motorcycle(s): 2009 SE Ninja 250R Posts: 796
Need some of you gurus for the old-gen!
http://www.ninjette.org/forums/showt...1256#post31256 /end hijack |
April 13th, 2009, 02:32 PM | #84 |
Join Date: Apr 2009 Motorcycle(s): 2009 Ninja 250R Posts: A lot.
Dirty Carbs
I had a similar problem. I was never not able to turn it over, but It was extremely cold hearted and did not want to idle. I took it back to the Dealer who found that one of the Carbs was clogged. He waranteed it out and it didn't cost me a dime. Runs great now. I went back for the first service and have just put the first 1,000 miles on it.
This bike is great. Fun good looking and not scary. |
September 8th, 2009, 10:20 PM | #85 |
Stealth Ninja Pilot
Join Date: Sep 2009 Motorcycle(s): 1999 EX250 Black Posts: 8
No start, check for spark by removing spark plug with spark plug wire connected then crank it over. Good spark means good ignition, no spark means bad ignition.
Next spray starter fluid into the carburetor (with air filter removed) then crank (10-15 sec.). if it starts and run for a few seconds then the carb/fuel supply isn' supplying fuel. Check fuel flow, if ok then its clogged jets. If not then the fuel source is bad (no fuel flow to carb). If those don't do it, then most likely no compression, or ign. timing is way off (this would be indicated by backfiring and/or extremely rough running and lots of black smoke). One other item would be a safety lockout switch not operating or bad sensor. If these don't help then take two Advil and call a professional in the morning. All ignition combustion engines operate on the same principals, but there are literally thousands of configurations, and someone that is familiar with your engine would be the most help with a hard to troubleshoot problem. By the way ethanol has an octane rating of 115, and will mix with water, and gas, this is why Dry gas works.
1999 Ex250 with 2-1 header capped with Muzzy. Crappy body repairs (Previous owner), starting mods. and repairs/maintenance |
05 Ninja 250 won't start on its own - help! | AmyF | 1986 - 2007 Ninja 250R Tech Talk | 59 | July 8th, 2014 11:46 AM |
'07 250 won't start | heroin300 | 1986 - 2007 Ninja 250R Tech Talk | 10 | May 10th, 2014 08:59 PM |
Ninja 250 won't start! please help me! | Black knight | 2008 - 2012 Ninja 250R Tech Talk | 4 | May 23rd, 2013 03:22 PM |
06 250 Won't Start, Please Help! | aspenratt07 | 1986 - 2007 Ninja 250R Tech Talk | 39 | May 16th, 2013 09:32 AM |
'06 250 won't start | Nemy | 1986 - 2007 Ninja 250R Tech Talk | 24 | May 23rd, 2009 04:17 AM |
