Old May 24th, 2013, 06:09 PM   #1
walty87
walty87's Avatar
Motorcycle(s): 2012 ninja 250
Plastic chain guard / cover
Who uses it? I'm debating not using mine.
I really don't think that this flimsy piece of plastic will stop the chain from doing damage if the chain flies off.
Only trouble I see is maybe riding with a passenger, the passengers foot will be pretty close to the chain. Or if one was to go down and have the bike lay on you...
Also chain lube will be everywhere...
walty87 is offline   Reply With Quote
Old May 24th, 2013, 06:40 PM   #2
az3200
az3200's Avatar
Motorcycle(s): 2002 Ninja 250
I'm sure even the flimsy plastic would be better than nothing...But my pregen doesn't have one on there and it hasn't been an issue riding 2-up yet. I like the way it looks better without it. The pregen guards are pretty ugly..
az3200 is offline   Reply With Quote
Old May 24th, 2013, 06:42 PM   #3
walty87
walty87's Avatar
How long you been riding without it?
Old May 24th, 2013, 06:54 PM   #4
Reswob
Reswob's Avatar
Motorcycle(s): 2008 Triumph Bonneville Black
Take a look at the underside of the chain cover. Clearly it's purpose is to stop all that chain gunk from getting flung on your leg. I'd leave it there!
'08 Bonneville Black
sold->'08 Ninja 250R | OES Swingarm Spools | EBC HH brake pads | reflector delete | no-cut brake light modulator | DIY fender eliminator
Reswob is offline   Reply With Quote
Old May 24th, 2013, 07:48 PM   #5
........I really don't think that this flimsy piece of plastic will stop the chain from doing damage if the chain flies off.....
It can't do that, but it protects the chain from water and mud thrown down by the front of the tire.
Old May 25th, 2013, 03:42 PM   #6
KawiKid860
KawiKid860's Avatar
I went like a week without a chain cover on my 500 and there is still grease splattered on the underside of the tail. That was about a year and a half ago too so... I've scrubbed it pretty good several times too. So unless you like a lot of clean up, keep it.
Old May 25th, 2013, 04:48 PM   #7
az3200
az3200's Avatar
since i've had the bike, almost 8k miles ago. I use the dupont chain lube from walmart. It's not thick and it dries almost like a wax. I haven't had any issues of gunk under my fairings or on my pants.
Old May 25th, 2013, 06:29 PM   #8
Apex
Livin' the Minimoto Life
Apex's Avatar
Get a shop to make a brushed aluminum cover (or get it color matched). That would look great on a newer ninjette.
Old May 25th, 2013, 07:30 PM   #9
I've gone with/without a plastic piece over my chain for the last couple thousand miles. No chain lube to report here.
Old May 26th, 2013, 09:34 AM   #10
Jono
Jono's Avatar
I took mine off both my bikes. Mainly for looks. And it saves a few seconds when I clean/lube my chain. Very little gunk fly up.
Old May 28th, 2013, 02:01 AM   #11
KawiKid860
KawiKid860's Avatar
So you guys don't have fling with the DuPont lube? I use that now instead of whatever I had before which flung A LOT. I guess the 500 likes to vibrate screws loose because its fallen off before and only has one left now lol but maybe I'll just let it fall off this time
Old May 28th, 2013, 02:34 AM   #12
NathanUc
B-Town Ninja
NathanUc's Avatar
Motorcycle(s): Black 2013 Ninja ZX6R ABS
Good ol' parallel twins. Even my 250r used to vibrate screws loose over time (ones correctly torqued). Eventually, I was using a bit of blue loctite on everything.
Downgraded to a 2013 636. Previous owner of a 2010 250r
My moto-vlog YouTube channel http://www.youtube.com/bloomingtonninja
NathanUc is offline   Reply With Quote
Old May 28th, 2013, 05:58 AM   #13
subxero
dirty boy
subxero's Avatar
MOTM - Apr '14
I saw a used new gen in Pennsylvania the other day with a checkered steel plate chain guard. I can't say it looked good but it was different
Old June 25th, 2014, 05:32 PM   #14
I have a hugger to help with fling from the tire but the PJ1 Blue lube flings all over my pretty blue undertail and blue rims.
Old June 25th, 2014, 05:35 PM   #15
nickjpass
#squid
nickjpass's Avatar
MOTM - Jul '16
I keep mine there, because the chain guard prevents or at least I think it should prevent it from flying at me while riding if it were to break. I believe that's the actual purpose?
08-12 chain guard cuong-nutz Free stuff! 1 November 24th, 2012 06:17 PM
Chain guard bolt GREY NINJA 1986 - 2007 Ninja 250R Tech Talk 5 September 20th, 2012 01:00 AM
130-90-16 touch chain guard? Oaklandish 1986 - 2007 Ninja 250R Tech Talk 8 December 18th, 2011 09:16 PM
Free chain guard CZroe Free stuff! 43 October 5th, 2011 06:15 AM
Aftermarket chain guard/swingarm cover drumm3r9 2008 - 2012 Ninja 250R Farkles 11 November 4th, 2010 08:29 AM
