Old January 5th, 2009, 09:03 PM   #1
stingray
Motorcycle(s): 2008 250r
[VIDEO] Homemade FRONT WHEEL camera mount!
hey guys,
new guy here, came over from kawiforums. thought i'd share my little homemade contraption with y'all...
i have a cheap digital camera capable of shooting 1.5 hours of continuous video with a 4gb SD card. my goal was to create a mount with a full unobstructed view as low to the ground as possible, and i don't really care if the cheap camera eventually gets smashed by a flying rock or whatever.
with that said, i chose to make a homemade camera mount to fit the front wheel reflector studs. i cut a stainless steel butterknife in half, bent at 90*, and drilled holes for the mount and camera. the camera mount came off my tripod and works great.
here's a 15 minute video i took down some old country roads just outside of town. a few of the roads are poor quality and the mount shakes a little when hitting bumps. on a smooth road it performs quite well...
VIDEO(google video compressed it way too much, looks better on my computer)
http://video.google.com/videoplay?do...39881935&hl=en
front view...
rear view...
how the knife looks mounted...
don't know exactly what size screw goes into the reflector stud, i had this one in my junk bin...
heres what the tripod shoe looks like, any tripod shoe should work..
stingray is offline   Reply With Quote
Old January 5th, 2009, 09:06 PM   #2
very ingenious!
as was asked before, how close to the ground does that camera get if you lean the bike over a lot? it seems to me you would have lots of clearance at full lean? is that true?
Old January 5th, 2009, 09:21 PM   #3
stingray
very ingenious!
yeah, forgot about that part. it's so high up on the wheel that you have plenty of clearance at full lean.
i went out to the garage to check by leaning the bike over, and you'd be well past the point of dragging your pegs before the camera would drag. at full lean, the camera is about 6-8" (maybe more, not less) above the ground, and the video would look awesome on a track.
by the time the camera started dragging, you'd already be sacrificing a pound of flesh to the asphalt gods. and you know you'd wanna catch that on video!
Old January 5th, 2009, 09:27 PM   #4
Thanks... I may have to steal one of the butter knives out of the silverware drawer.
gf- "you're gonna do what with the butter knife and my camera?!!"
Old January 6th, 2009, 01:17 AM   #5
NJD022588
NJD022588's Avatar
Motorcycle(s): '09 Ninja 250R
Great idea!
NJD022588 is offline   Reply With Quote
Old January 6th, 2009, 06:26 AM   #6
Erin_S
Motorcycle(s): Gix
Have you considered a cheap plastic cover? You could easily rig up a little lexan cover that would only be a couple bucks a replacement instead of having to do all this over again... just an idea. Awesome though.
Edit:
Like this
Erin_S is offline   Reply With Quote
Old January 6th, 2009, 06:55 AM   #7
stingray
be sure to use the cheapest butterknife you can find - they sell them at dollar stores and walmart for 4/$1. the cheap stainless knives tend to be flatter and the lower grade stainless steel bends better. i found that expensive stainless knives tend to snap in two instead of bending. heating the metal probably helps with making the bend.
i'm sure someone with metalworking experience can take this general idea and really make it look professional. in my case, i just wanted a quick and dirty camera mount using crap i had laying around the garage. honestly the whole project took 10-15 minutes once i decided to use a cut up knife as the base.
Old January 6th, 2009, 07:07 AM   #8
stingray
Edit:
Like this
great idea! a cover would definitely protect the camera from bugs/rocks and also cut down on the wind noise from the microphone. i think i'll try your lexan idea soon, since it kinda sucks scraping bug guts off the camera after each ride.
Old January 6th, 2009, 07:14 AM   #9
Erin_S
Motorcycle(s): Gix
Glad I could help! ^_^ Hopefully it works out well, and I get to see some rockin videos!
Old January 6th, 2009, 11:03 AM   #10
OldGuy
Live Life
OldGuy's Avatar
Motorcycle(s): 2009 Green SE Ninja 250
Nice work - now I just need to figure out where I could do that on a pre-gen.
- ATGATT -
Scorpion EX700 Hi-Vis Helmet, First Gear MeshTek 3.0 Jacket, TourMaster Transition 2 Jacket and Flex Pants, Sidi Doha boots
OldGuy is offline   Reply With Quote
Fix for front wheel squeak noise/Front wheel removal cuong-nutz 2008 - 2012 Ninja 250R Tech Talk 13 April 23rd, 2014 12:25 PM
[roadracingworld.com] - Benny Solis Tests A New Type Of Video Camera Mount Ninjette Newsbot Motorcycling News 0 December 16th, 2013 02:10 PM
My lame camera mount test video! garrisonboobs Videos 4 September 6th, 2012 12:34 AM
let's see pics of how you mount your video camera BFisher244 General Motorcycling Discussion 22 April 27th, 2012 02:25 PM
[roadracingworld.com] - Video: How To Install A Front Wheel Correctly, Without Side- Ninjette Newsbot Motorcycling News 0 June 9th, 2010 03:01 AM
