Old September 23rd, 2015, 01:29 PM   #1
22R88
Motorcycle(s): 2004 EX250R
04 Ninja 250 oil leak onto lower cowl.
I got my free Ninja 250 on the road finally. It runs great. Only slight issue is I have a small seep drip of oil the lands on the inside lower cowl just right center. I can't see where it is coming from without taking the cowl back off. I am going to investigate but was wondering if anyone knew what could be leaking that far up ? I am thinking valve cover maybe ??
Any tips appreciated
Pic of ride attached
22R88 is offline   Reply With Quote
Old September 23rd, 2015, 04:38 PM   #2
Ghostt
Ghostt's Avatar
Looks like your removing that lower, oil leak could be several things. Crush washer, O-rings, gaskets, etc......
violente et ignorantia
ZX-2R BLOG
Old September 23rd, 2015, 06:13 PM   #3
22R88
Thanks for the reply, Yea what has me confused is if the plug crush washer or filter o ring leaked it looks like it would hit the ground not the cowl bottom. It is like it is coming from higher up on the front near radiator area ??
I will look and see in the next few weeks, Gonna ride a bit first.
22R
Old September 23rd, 2015, 09:50 PM   #4
Ghostt
Ghostt's Avatar
Other areas would be side covers, the external rubber oil line, and the crush washers on those banjo bolts, bad oil pressure sending unit, valve cover.
You need to pull the lower, and start looking, too many suspects without further investigation.
ZX-2R BLOG
Old September 25th, 2015, 01:50 AM   #5
f0r54ken
Motorcycle(s): Kawasaki ninja ex250 2007
Hey, I ain't nobody, but What I like to do to find leaky oil is to grab a couple napkins or tissues, wipe off the visible oil, and use a fresh one holding it on the spots I think are suspect. Assuming your oil leak is a little aggressive you can probably find the source pretty quickly.
If you took off the clutch panel during your repairs YOu can probably assume that old gasket (The Rubber Guard sandwiched between the cover and the housing) Probably isn't doing it's job in keeping the oil in. So check those edges and bolts holding it on.
f0r54ken is offline   Reply With Quote
Old September 25th, 2015, 08:24 PM   #6
22R88
thanks for the replies guys. I will be looking into shortly.
22R
Old September 26th, 2015, 03:27 AM   #7
MrAtom
MOTM - July '15
fwiw it's a paper gasket. Also fwiw, I've seen dudes use permatex blue stuff and have it last forever. I'd still recommend a new paper gasket though. I marred mine up a little getting off the old gasket so I used both.
Old September 26th, 2015, 04:11 AM   #8
Ghostt
Ghostt's Avatar
Use the black RTV, it matches the engine
ZX-2R BLOG
Old September 26th, 2015, 05:02 AM   #9
And clean it while you're there. A clean engine is easier to follow the leaks.
Old September 26th, 2015, 11:15 AM   #10
f0r54ken
Kind of curious to know, since you mentioned it. We don't want to put that blue stuff on right? From what I've heard. Red can be Removed but Blue is Pretty much God mode? (Can't be removed.) I'm curious Cause I'll be using the red RTV high temp 650f Gasket maker on my stator cover. (Sorry for thread jacking it's just a quick related topic.)
Old September 26th, 2015, 01:12 PM   #11
xorbe
xorbe's Avatar
I too get drops of oil on the inside of the lower cowl. It's been like that for 2 years. It's not much so I haven't worried about it so far. I looked around but couldn't find anything obvious.
Old September 26th, 2015, 02:02 PM   #12
MrAtom
MOTM - July '15
Its pretty tacky but you can get it off.
