Old September 27th, 2015, 04:29 AM   #1
fastmaster11
Motorcycle(s): 2001 ninja 250
pick up/stator coil resistance?
Hey everyone, this is my first time posting here. I have a 2001kawasaki ninja 250 that i recently bought locally. The seller said the only thing that was wrong was he broke the key off in the gas tank, so i was unable to start or test ride at that time. For the $170 i paid i figured, why not? So i bought anew ignition installed it charged the battery, cleaned the carbs and tank, hit the start button and she turned over But wouldn't start. I have no spark... I checked the safety switches, stand switch, lever switch etc. I tested the ignition coils, plugs wires and they seem good. I Tested the pickup/stator coil and get 127 ohms of resistance. Is this within specs? I cant seem to find this information online. If this is, i guess ill be changing the cdi/ecu box. Any information or suggestions would be greatly appreciated! Thanks
fastmaster11 is offline   Reply With Quote
Old September 27th, 2015, 09:12 AM   #2
dcj13
Participant
dcj13's Avatar
Motorcycle(s): '94 K75 std
Welcome, Mike!
Do a search of the forum for the term "100 ohm" or ""100 ohm resistor". You'll find several threads about it. Your solution may be a 50-cent part.
"Some years of ninjettes needed a 100 ohm resistor somewhere in the starting circuit to fire. If you have a wiring diagram for that year, it should be straightforward to confirm."
Old September 28th, 2015, 06:07 AM   #3
fastmaster11
Thanks dcj13 for you response. I think the 100 ohm resister is located in the ignition switch which was purchased new. Ill have to double check that.
Old September 28th, 2015, 08:56 AM   #4
Originally Posted by fastmaster11 View Post
.......... I Tested the pickup/stator coil and get 127 ohms of resistance. Is this within specs?.........
The thing is OK, specs state 100~150 ohms, being able to generate peak voltage of 4.5 v or more.
Just in case it helps:
https://www.ninjette.org/forums/showthread.php?t=128112
http://faq.ninja250.org/wiki/How_doe...system_work%3F
http://faq.ninja250.org/wiki/Wiring_...s_%26_diagrams
Old September 29th, 2015, 03:22 AM   #5
fastmaster11
Thanks Motofool, just the answer i was looking for. I guess my next step is to change the cdi box. Ill be sure to update when i do. Thanks again
Old September 29th, 2015, 09:37 AM   #6
dcj13
Participant
dcj13's Avatar
Just make sure you see the 100 ohms through the switch before you buy parts.
Old September 29th, 2015, 03:24 PM   #7
It would be better that you could borrow one CDI known to be working, instead of investing without certainty.
You are welcome
Kawasaki ZX Ignition Coil Pack/ coil over plugs (CoPs) modification. Ghostt 1986 - 2007 Ninja 250R Tech Talk 44 June 10th, 2019 03:48 PM
Tightened chain. More resistance??? cadd 2013 - 2017 Ninja 300 Tech Talk 5 July 26th, 2015 09:50 PM
Front tire resistance? 02337 1986 - 2007 Ninja 250R Tech Talk 5 August 31st, 2012 08:05 PM
Which Material is Best for Gear? Abrasion Resistance Tests gfloyd2002 Motorcycle Gear 1 April 15th, 2011 04:47 AM
