Old August 9th, 2016, 12:42 PM   #1
Azvolts13
Motorcycle(s): None yet
Question with seat
I have a question can I put a 2012 Kawasaki 250 seat on a Kawasaki ninja 2007 or below. I like the tail of a 2012 seat and I was wondering of I could put that fairing and seat on a 2007 or below. Thanks in advance here are link for what I'm talking about
https://www.google.com/aclk?sa=L&ai=DChcSEwjovtKIi7XOAhWKstsKHW3dAJEYABAX&sig=AOD64_2FZRMjyrKy9YlohVN_b lvGaGdiwg&ctype=5&q=&ved=0ahUKEwj1-s6Ii7XOAhXnCcAKHctBDcQQwg8ILw&adurl=
Azvolts13 is offline   Reply With Quote
Old August 9th, 2016, 12:51 PM   #2
JohnnyBravo
Certifiable nontundrum
JohnnyBravo's Avatar
MOTM - Sep '13, Sep '16
I have no idea, but I'm sure someone around here has a clue
Old August 9th, 2016, 03:04 PM   #3
RacinNinja
Vintage Screwball
RacinNinja's Avatar
MOTM - Mar '16
Short answer: No.
Long answer, how much time and skill do you have to fab up what you need?
Goin' fast on slow bikes!
Old August 9th, 2016, 03:55 PM   #4
NevadaWolf
Certified looney toon
NevadaWolf's Avatar
MOTM Jul '13, Jul '14
Looking at the two, a direct bolt on conversion isn't going to happen - the tails changed too much between the years.
Looking at the part diagram you can see how the newgen narrows more than the pregen turning it from a boxy tail to a pointed end.
2002 Frame:
http://www.bikebandit.com/oem-parts/...49388sch290297
2012 Frame:
http://www.bikebandit.com/oem-parts/...54177sch731496
It'd be interesting if you can pull it off.
<-- Linky
Old August 10th, 2016, 05:27 AM   #5
juliusmichaelhonrada
Motorcycle(s): GPX250-RII
yes here in the philippines , we have this shop called JBB modifications , he can convert any motorcycle into a YAMAHA R6 replica .. the rear of the r6 and the newgen is like the same , how he do it is he just cut the old frame and weld a new frame that is similar to the r6 tail , he also sell the seat , the whole package cost just around 5000 pesos , or around $107 ? in total , if you want the complete r6 fairing and the bigger front inverted fork with the dual front disc brake , he will do it for around $400
The inverted front fork with the dual disc , the 2 wide mags , swing arm all came from this china bike called z200 explorer.
About the rear frame , i dont exactly know which he uses .
Without paint it is 100$ cheaper
most of these bikes are 150cc-250cc single cylinders, with dual rear shocks , and very thin front fork with single disc rotors...
juliusmichaelhonrada is offline   Reply With Quote
Old August 10th, 2016, 05:36 AM   #6
ForceofWill
Blind 250 Loving Whore
ForceofWill's Avatar
$400 for a front end swap with forks, wheel, and brakes? Man I need to move to the Philippines lol.
Old August 10th, 2016, 05:50 AM   #7
Final product , this is not a yamaha R6 , look at the exhaust manifold there is only 1 because this is a single cylinder ricer bike
Old August 10th, 2016, 05:53 AM   #8
a closer look
Old August 10th, 2016, 05:57 AM   #9
JohnnyBravo
^ that is cool!!!
Old August 10th, 2016, 06:13 AM   #10
I dont know if this bike is available in your country its called Motorstar Z200 explorer(china bike) , they have this huge inverted fork , dual front disc ,mags , monoshock , pegs and swingarm , buy 1 of these part out/junk bike and use the parts to build
Old August 10th, 2016, 06:47 AM   #11
SLOWn60
n00bie to wannabie
SLOWn60's Avatar
Motorcycle(s): 2012 250R (Red), 2005 VFR800A (Red), CRF450X (Red), 2012 F800GS (Wants to be Red!)
MOTM - Nov '15
If you do: Julius has a motorcycle he will sell to you cheap!
The Smart Money: #1 - ATGATT, #2 - Training (machine skills and survival skills), #3 - The bike; whatever floats yer boat with the money you have left over
SLOWn60 is offline   Reply With Quote
Old August 10th, 2016, 08:16 AM   #12
JohnnyBravo
Lol
Another Solo Seat Cowl Question hardkhor 2008 - 2012 Ninja 250R Farkles 7 February 22nd, 2015 09:00 PM
Seat Cowl Question Treyzian 2008 - 2012 Ninja 250R Farkles 8 September 13th, 2013 06:26 AM
Single seat cowl question Confuzshuz 2008 - 2012 Ninja 250R Farkles 33 September 30th, 2012 11:20 AM
Corbin seat question peng155 2008 - 2012 Ninja 250R Farkles 5 July 2nd, 2012 05:26 PM
Question about Corbin seat ichibunkid.206 2008 - 2012 Ninja 250R Farkles 7 July 10th, 2011 08:52 PM
