Old October 15th, 2016, 11:08 AM   #1
KaTyStew
Pilot jets
I made an earlier post about the idle problem I'm having since switching to a shorty exhaust and a pod filter.
I figured I could get size 40 jets in there instead and bring the idle back to normal. I didn't buy a jet kit so it's been more of a pain then I expected.
Does anyone happen to have an extra pair of size 40 pilot jets from their kit that they don't need?
I'll obviously pay and what not.
I just wanna ride my bike again! Please help if you know what else there is I can do! Check out my other post for the whole story! Thank you!
KaTyStew is offline   Reply With Quote
Old October 15th, 2016, 11:44 AM   #2
CrazyCanuckGoat
Motorcycle(s): 2003 ZX12R (sold), 2012 250R, 1975 Honda XL250, 1980 XJ650
I just bought 4 new EBC #40 Pilot jets (supplier in Canada only ships 4). I haven't installed mine yet as my bike is running great with my main swap and 3 washers on my needles.
Not really sure what your idle issue is, but a pilot change is going to affect your mid range more and not idle.
CrazyCanuckGoat is offline   Reply With Quote
Old October 15th, 2016, 11:53 AM   #3
CrazyCanuckGoat
Read your other post.....
With a K&N 0990 and a slip on I was running 107.5 Keihin mains, 3 washers and and 2.75 turns. I could have went up a jet size as it was a bit lean on cooler days. This is at about 800 ft above sea level.
You are too lean.
As for the high idle, Sounds more like an vacuum leak you created when you opened up the carbs. Double check your work.
Old October 15th, 2016, 11:58 AM   #4
KaTyStew
So you think I could keep the 38s for the pilots I have in there now? Mid range is great. It's just that high idle that's wrong right now. If you think 38s will be good on pilots, ill go ahead and put it all back together and check for leaks.
Thank you for your help!
Old October 15th, 2016, 12:19 PM   #5
CrazyCanuckGoat
Here's mine at the moment (same altitude as before):
2012 250, Area P full quiet core exhaust, KN 0990, pregen CDI wired in, non stock gearing......Currently at 115 mains, 3 washers on the 38 Pilot and 2 3/4 turns. My bike runs amazing at all speeds/rpms now and is a blast to drive. It's bringing out the hooligan in me lol. I could dial it back to 112.5's, but I'm planning a motor build over the approaching winter. I might mess with the 40 pilot after the motor build, but it runs so sweet now.
I would look into either an air leak around the boots, did you put both throttle cables on correctly with enough slack/play? Is the choke cable actually going off with the lever? When you messed with the needles you didn't tear the diaphragms?
I've never had a high idle issue like that with pulling my carbs multiple times that's why I suspect a user oopsy.....just hard to pinpoint through the internet without seeing it.
Old October 15th, 2016, 04:09 PM   #6
Racer x
Racer x's Avatar
MOTM - Sep '18, Feb '16
Kits generally don't come with pilots.
Try these guys
http://jetsrus.com/a_jet_kit_street/...50R_Ninja.html
Worlds fastest 250 ninja
FS: Genuine Keihin 42 Pilot Jets GlassAnkles Motorcycle-related 0 March 27th, 2013 10:19 AM
All Jets Feel the Same DevinWolfe 2008 - 2012 Ninja 250R Tech Talk 25 April 30th, 2012 02:53 AM
Changing pilot jets on a stock 250 shadowman 2008 - 2012 Ninja 250R Tech Talk 4 March 15th, 2012 08:49 AM
WTB #40 Pilot Jets tjkamper Items Wanted 1 August 29th, 2010 05:32 PM
What do the jets look like? WindMeUp 2008 - 2012 Ninja 250R Tech Talk 7 August 15th, 2010 11:49 AM
