Old October 17th, 2016, 08:27 PM   #1
naderzb
Motorcycle(s): 2012 Kawasaki Ninja 250
Handlebar bent/ Throttle stuck/ help a newbie
I left my bike at my gf's apartment (we go to a large university) and when I checked it in the morning I noticed my bike was messed with. Once I started riding the bike I noticed the front break lever was farther than normal, the throttle was sticking, and my mirror was up. I checked carefully and the bike was dropped on its right side but picked back up (which is why the mirror was up/fairings were cracked).
I'm a new rider and dont want to have insurance cover it, where should I buy a right handlebar, how do I fix the throttle, and what tools do I need in order to get the job done? Im fine with replacing the handlebar with stock parts unless you guys suggest otherwise.
naderzb is offline   Reply With Quote
Old October 27th, 2016, 01:46 PM   #2
Free bump for more views. The thing that sticks out as most important is the sticking throttle. You need to figure out what it is catching on, and get it back to rotating smoothly. Everything else is cosmetic (assuming the brake lever still engages and disengages as expected).
Old October 27th, 2016, 02:06 PM   #3
As a guess, the throttle will quit sticking when you either straighten the bent bar, or replace it with a new one. The tube that has the grip on it rotates on the handlebar, and if the bar is bent, it can get tight.
Old October 27th, 2016, 07:43 PM   #4
Jiggles
Jigglin' your Jiglets
Jiggles's Avatar
MOTM - Apr '13
+1 to bend it back, its actually not too hard. Find an open pole that fits over the handle bar and have someone hold the steering column still and you can gently bend it back.
AFM #676
Supersports are for n00bs
Old October 28th, 2016, 06:32 PM   #5
broken neck
Motorcycle(s): 2011 Ninja 250R Special Edition (sold), 2017 CRF250 Rally
You can take a quick look at your grip and your bar end... Maybe the grip is touching the bar end preventing it to rotate back to its closed position.
The bent bar is another good option...
broken neck is offline   Reply With Quote
Old October 31st, 2016, 08:57 PM   #6
CaliGrrl
CaliGrrl's Avatar
Motorcycle(s): Ninja650
Husband and I just replaced my bent handlebar, and my throttle was hanging just a little because the rubber was grabbing the bar-end. He squished it up away from the bar end and now it's fine. I was thinking we were going to have to take the throttle off and lube the cable/unstick it but it turned out to be something simple.
We got the new handlebar from our local bike shop, and replaced it pretty easily. Screwdriver and I think an allen bolt did it. Look at the exploded parts diagrams, and you should be able to replace it.
Old November 1st, 2016, 04:25 AM   #7
VaFish
VaFish's Avatar
MOTM - Jan '16
If the 2012 is like the older bikes it should only take a 6mm hex wrench and a Phillips screwdriver to replace the bar.
Stuck at the gas station. Dies when giving throttle spc2125 1986 - 2007 Ninja 250R Tech Talk 29 May 19th, 2016 08:23 PM
bent handlebar - suggestions? jaesun 1986 - 2007 Ninja 250R Tech Talk 11 September 18th, 2012 06:14 PM
Slightly bent handlebar need advice!! Pics included Miami_Dom 2008 - 2012 Ninja 250R Tech Talk 9 June 18th, 2012 06:01 PM
Best Method to Fix Bent Handlebar tony7kp 2008 - 2012 Ninja 250R Tech Talk 14 May 15th, 2012 07:49 AM
Stuck throttle after Area P install & new needles The Blue Rider 2008 - 2012 Ninja 250R Tech Talk 6 July 25th, 2011 09:01 PM
