Old February 14th, 2011, 06:45 PM   #201
MiniCog
MiniCog's Avatar
Motorcycle(s): Past: 2007 250 Ninja 2005 XR650R 2003 KLX400R
Shopping for parts for when I get the money.
I have choices:
Two Brothers Exhaust and/or pod filters with jets, of course.
Two Brothers Exhaust and jets.
Pod filters and jets.
I'm thinking of making my own 2:1 exhaust system, too. Maybe from a Cobra F1s or Holeshot from a Concours? I can weld, bend and I actually know my way around a bike more than your typical under 20 year old...
Paint, I want a variation of Eddie Lawson's paint scheme.
Those are my goals for my bike, and I plan on having it for a very, very long while, so why not farkle the balls off of it? Hmmmmm?
What do you guys think of Muzzy's exhaust on a EX 250? I hear about them getting a lot of crap...
When life throws turns at you, aim for the apex.
MiniCog is offline   Reply With Quote
Old February 14th, 2011, 08:26 PM   #202
eddiekay
eddiekay's Avatar
Motorcycle(s): 300, WeeStrom
I was in 2nd and i should add that these are "speedo" speeds...prob off 3-4mph @ 50.
My pal has a BMW and he's going with me tiomorrow night and I'll let her out and see what we can see vs his speedo
Old February 15th, 2011, 11:03 AM   #203
CThunder-blue
ModMy250.com
CThunder-blue's Avatar
Just got done installing the KOSO speedometer gauge yesterday. It seems to work pretty well, but I need to find time to go test it. It's raining all week this week too
Old February 15th, 2011, 11:06 AM   #204
dubojr1
dubojr1's Avatar
Any new pics?
Old February 15th, 2011, 11:12 AM   #205
CThunder-blue
ModMy250.com
I did a short DIY, so I'll get that posted tonight or tomorrow.
The www.ModMy250.com guy
Old February 20th, 2011, 03:30 AM   #206
KawiRider
KawiRider's Avatar
Motorcycle(s): '08 and 09 Ninja 250R
Installed Vortex links from a 98 Gixxer 750 on my '09! Awsome adjustability from around -1/2", to +1", and +1 3/4".. Great alternative to the Busa links for those looking to RAISE the rear for the track or twisties, and they look great too! Also intalled the Yoshi rearset adjusters...
KawiRider is offline   Reply With Quote
Old February 20th, 2011, 05:29 AM   #207
gfloyd2002
User Title Free Since '12
gfloyd2002's Avatar
MOTM - Feb '12
Washed her, cleaned the chain (WD-40), then dried it and lubed it (Cyclo moly/graphite industrial chain lube). Pulled the fairings to see how easy it would be to install an Area P full exhaust. Inspected carburator to see how easy jetting change would be. I'm very close to pulling the trigger on the Area P . . .
Old February 20th, 2011, 06:26 AM   #208
warlord
warlord's Avatar
Motorcycle(s): 2014 Ducati Panigale 899
I stared at her like a creep. Oh yeah baby, I have plans for you...
warlord is offline   Reply With Quote
Old February 20th, 2011, 06:41 AM   #209
Lvr
Do it! It takes all of three minutes to install, and you'll be amazed at the weight difference when you take off the old one. Plus it looks very nice and sounds even better.
Lvr is offline   Reply With Quote
Old February 20th, 2011, 07:14 AM   #210
grandelatte
Go Pack Go!
grandelatte's Avatar
Motorcycle(s): 09 250R, 07 XL1200L
- installed new chain
- installed new front sprocket (15t)
- installed new rear break pads
- replaced license plate light bulb
- got her inspected
09 Ninja 250R (commuter)
07 XL1200L (weekend fun)
02 SV650S (totaled by an idiot cager) & others
grandelatte is offline   Reply With Quote
Old February 20th, 2011, 07:17 PM   #211
MiniCog
MiniCog's Avatar
This weekend:
I checked my valves.
Cleaned the engine's outside.
Washed the bike.
Cleaned the rims, swing arm and chain.
Lubed the chain.
Knocked the plastic insert out from under the taillight for my license plate (the led burned out...).
Fixed the wiring for the turn signals I inherited from the previous owner.
Played pretend while the bike was on it's center-stand because I was grounded.
Old February 22nd, 2011, 10:10 AM   #212
Ninjamomma
Ninjamomma's Avatar
Taller windshield - what a difference...WOW!
Riding at 70mph and turning my head to look at the scenery, was like a rudder on a boat. Felt like my head would rip off. Bought/installed (easy) taller windshield and WOW!, what a difference. Makes riding at higher speeds much, much more enjoyable. Of course, I'm older than most in this forum so this info. is for you people who are built for comfort - not speed. Although, if I'm comfortable, I can go faster - Wooohooo!
Ninjamomma is offline   Reply With Quote
Old February 22nd, 2011, 10:39 AM   #213
KawiRider
KawiRider's Avatar
I adjusted the chain tension and rear brake switch from putting on rearset adjusters.... Nice..
Old February 22nd, 2011, 11:03 AM   #214
slolane
Motorcyclist
slolane's Avatar
Motorcycle(s): 2014 Ninja 300 ABS
How tall are you if i may ask? I have the Puig DB and like it but we just got my wife a 250 also and I want to look at all the options.
Thanks!
slolane is offline   Reply With Quote
Old February 22nd, 2011, 05:13 PM   #215
MiniCog
MiniCog's Avatar
I learned that one on the back of an ST1300 with my dad while we were doing about 80 while riding back from the COG National in Canaan Valley, 2007.
I heard that a guy broke his neck doing that. I will turn my head, but not too rapidly. I have a pretty good sized neck so I can keep my head on my shoulders, which is always a good thing.
Also, NEVER LOOK STRAIGHT UP, if my chin strap hadn't of been on (but it always is), one of my helmets would be in a lake right now. That was terrifying.
Old February 22nd, 2011, 06:29 PM   #216
warlord
warlord's Avatar
I just finished installing my shogun frame sliders and removing the reflectors.
Old February 22nd, 2011, 06:56 PM   #217
slolane
Motorcyclist
slolane's Avatar
Lookin good Brandon
Old February 22nd, 2011, 07:04 PM   #218
KawiRider
KawiRider's Avatar
I have been wanting to get rid of the reflectors on my bike. Where did you get the hex fasteners? Are they the OEM Kawasaki ones or did you get them from a hardware store?
Old February 22nd, 2011, 07:11 PM   #219
switch them out for the hex fasteners under your passenger seat.
Old February 22nd, 2011, 07:14 PM   #220
KawiRider
KawiRider's Avatar
Good idea KKim! I don't know why I didn't think about that! I wanted to keep OEM fasteners for the look, and was wondering! Thanks..
Old February 22nd, 2011, 07:15 PM   #221
warlord
warlord's Avatar
Yup, I used the spare hex nuts under the passenger seat (that hold on the rear fender). Just swap them out and it looks nice and stock.
Old February 22nd, 2011, 08:22 PM   #222
ungluck
sleeper
ungluck's Avatar
Motorcycle(s): '10 250r, '10 690 duke
washed it for the first time in weeks...
that white bike is DELICIOUS
ungluck is offline   Reply With Quote
Old February 23rd, 2011, 12:45 PM   #223
Ninjamomma
Ninjamomma's Avatar
Tall Windshield information
Thanks!
I am 5'7". I looked for some time to find a taller windshield for 2010 Ninja 250r with no luck - then I was visiting the dealership and saw a used 09 ninja with a tall windshield and asked the parts guy - could you find this height or kind of shield for me. It had the name on it - Zero Gravity, but was still hard to find. He dug and dug and finally found it.
I was going to paste the Zero Gravity link, but couldn't find this shield on their site, so I called the dealership to get the part # I ordered 3 months ago and then googled that part # which gave me a catalog screen of Zero Gravity with no pictures.
It is a: Zero Gravity, part #2301-1280.........$89 (Don't remember it being that high at the dealership)
http://www.rvsports.com/Zero-Gravity...ductId=7848470
It's hard for me to order anything without a picture, so I went outside to take a picture of mine, then put it on photoshop to show where the old screen was because the pictures make the shield look huge, but its not. It's just 4-5" taller and swoops out at the top so wind doesn't pour over the top. It doesn't eliminate all the wind but makes it much easier to turn my head at high speeds.
Hope this helps
Old February 23rd, 2011, 02:05 PM   #224
slolane
Motorcyclist
slolane's Avatar
Sweet, thanks! I'm going to check with the wife to see if she would like that better than a DB like mine.
Old February 23rd, 2011, 02:52 PM   #225
"A"
vampire
Motorcycle(s): 2 many 2 list
My Ninja 250 came with Two-Bros. slip-ons, previous owner had them installed without jetting/air filter mod, start/runs just fine, but it's LOUD!
Comapred to my previous bone stock 05 Ninja 250.
I doubt the 2-into-1 Muzzy would provide much better flow than OEM exhaust. With jetting mod, you're likely to loose one end of the performance to gain 2-5% at the most. IMO, not worth while for the $$$.
If you want a set of Two-Bros. slip-ons, I can sell you mine, cheap, when I get a set of chrome OEM mufflers.
"A" is offline   Reply With Quote
Old February 23rd, 2011, 04:39 PM   #226
MiniCog
MiniCog's Avatar
I don't really have any money right now, I should in June when I can work... I'm sure you'll have them sold by then.
How much would you be selling them for? I could just buy the headers from somewhere else later in the summer.
Thanks for the offer though! I'm definitely interested if you get the stock pipes at the right time.
Old February 23rd, 2011, 06:36 PM   #227
ungluck
sleeper
ungluck's Avatar
front and rear brake fush today, along with full body disassemble,cleaning and fixing of some tweaked things. also raised it about 1.5 inches and went up another knotch on damping(5'5" 170lbs). ride is soo much better...wish i could stiffen the front a touch.
also trimmed the rear fender and cleaned my chain and relubed, also cleaned my airfilter...now due for an oil change..woohoo 1200 miles!! in what..3 months..not to shabby
Old February 23rd, 2011, 08:11 PM   #228
http://www.ninjette.org/forums/showthread.php?t=29141
Old February 23rd, 2011, 08:27 PM   #229
ungluck
sleeper
ungluck's Avatar
you rock my world sir..much mahalo!! and hap-e birfday!
Old February 23rd, 2011, 08:31 PM   #230
hap-e birfday!
thanx... and ur welcome... hic!!
Old February 24th, 2011, 07:13 PM   #231
slolane
Motorcyclist
slolane's Avatar
Wife and I did a couple of mods to her 250...
Clear ProGrip tank pad
ProGrip 719 Gel Grips
15/42 gearing, one ride on mine with this setup and she couldn't stand the stock gearing
All done
Time to order the windscreen and bar risers (or shes going to steal em off my 250, LOL).
Old February 25th, 2011, 06:28 PM   #232
gfloyd2002
gfloyd2002's Avatar
MOTM - Feb '12
Bought the Area P Quiet Core Exhaust system and jet kit. Can't wait to get it and install.
Old February 28th, 2011, 01:21 PM   #233
slolane
Motorcyclist
slolane's Avatar
Received Roaring Toyz bar risers for the 2011, putting on tonight.
Old February 28th, 2011, 04:14 PM   #234
warlord
warlord's Avatar
Looking good James! I'm probably going to pick up that same tank pad, I saw it over at the Kawi dealer for about $17.
Today I just warmed up the bike a bit and put some stabil in the tank (since it doesn't look like it'll be warm enough to ride in the next few weeks. I'm also currently painting my helmet...
Old February 28th, 2011, 06:31 PM   #235
slolane
Motorcyclist
slolane's Avatar
Thanks, your 250 is looking good too!
Yeh, the clear tank pad turned out pretty well, I was thinking black but we went with clear and glad we did.
Also, I decided to go another route with the GPS setup on my 250. I wanted something different that is water resistant. I have everything except the M10 post ball mount for the Ram Mount but should have that next week then I'm good to go. I have the generic bar mount but would rather have it threaded than clamped on... either is probably fine I guess.
Old February 28th, 2011, 07:05 PM   #236
slolane
Motorcyclist
slolane's Avatar
Installed Roaring Toyz risers...
before
after
Old March 1st, 2011, 11:20 AM   #237
Jaysep
Pinoy
Motorcycle(s): Ninja 250r, KMX, mio soul
Got front tire fixed. Punctured by a nail.
Jaysep is offline   Reply With Quote
Old March 1st, 2011, 11:34 AM   #238
FrugalNinja250
FrugalNinja250's Avatar
Motorcycle(s): Several
Rode it in to work, again. Was in the mid-30's so plugged in the electric gloves.
Old March 1st, 2011, 12:21 PM   #239
gfloyd2002
gfloyd2002's Avatar
MOTM - Feb '12
Slolane,
How do you find the comfort? Handling changes?
Old March 1st, 2011, 12:25 PM   #240
caps
Sexy Beast
caps's Avatar
Motorcycle(s): 2010 Ninja 250R, 2006 ZX-14, 2012 Ducati Monster
just got done driving it for the first time
caps is offline   Reply With Quote
Discovered something scary about my Ninjette today... kjohng General Motorcycling Discussion 28 October 15th, 2021 01:40 PM
Sold the 2006 Ninjette today :( Renner General Motorcycling Discussion 31 October 16th, 2014 11:46 PM
Today I Gave My Ninjette Wings! BlueHairSar Pictures 5 June 20th, 2013 07:38 AM
my bro went down today on his ninjette richierich781 !%@*#$%!)@#&!%@ I crashed! 46 January 18th, 2013 11:59 AM
Ninjette. org hacked today CC Cowboy Off-Topic 9 April 3rd, 2011 08:55 AM
