Old June 5th, 2011, 04:14 PM   #1
Boom King
So, where's the reverse?
Boom King's Avatar
Accidently shifting into neutral
So I have some new boots that I'm still getting used to. The soles and toe box area are thicker than what I'm used to in my last pair. When I went riding today, accelerating from a stop a couple of times I didn't click all the way into second gear when I thought I did and the bike was in neutral. I had traffic behind me so I could only slow down so much. I just pulled in the clutch and rolled off the throttle, made sure it clicked into second and gave it throttle again.
I usually shift out of first anywhere from 8000 to 9000 RPM so rolling off the throttle to get it from neutral to second would have put the tach needle around that or a bit lower I think. My noobish question here is did I do any damage to the gears or transmission . Bike seemed fine the rest of the ride.
What do experienced riders here suggest to do in a situation like this?
Old June 5th, 2011, 05:21 PM   #2
rockNroll
rockNroll's Avatar
Motorcycle(s): black
I don't see where I would expect any kind of damage from this. I say good to go!
Adjust your shift linkage to make room for your thickest boot toe. My Sidi boots have the tallest toe of all my boots so I have my linkage adjusted for them. When I wear my Alpinestars I have to lift my toe "extra" to get the shift.
Old June 5th, 2011, 05:28 PM   #3
ally99
Ninja chick
ally99's Avatar
Motorcycle(s): '13 Ninja 300
MOTM - Dec '13, Feb '15
I've done that many times in my riding. As long as you shift up and not down, your damage should be minimal, if any at all. It's never seemed to affect my tranny.
Postwhores are COOL! ~Allyson
Old June 5th, 2011, 05:58 PM   #4
Yup, if in doubt, always shift up.
/moved to riding skills
Old June 5th, 2011, 09:46 PM   #5
adjust your shifter linkage so this doesn't happen.
Old June 5th, 2011, 10:29 PM   #6
kaiserz
There's a limit to s2pdty
kaiserz's Avatar
This used to happen to me like almost all the time when I was a newer rider.
Mr. Kkim what's a shifter linkage, (sorry for my lack of knowledge )
Old June 5th, 2011, 11:30 PM   #7
it's that metal rod that runs between the shifter pedal and the engine. it has 2 lock nuts on it. loosen them and you will be able to turn the rod to lengthen or shorten it, thereby adjusting the shift lever height in the process. watch out, the front lock nut is reverse threaded and needs to be turned in the opposite direction to loosen it than from normal.
a DIY w/ some pics...
http://www.ninjette.org/forums/showthread.php?t=15136
Old June 7th, 2011, 09:16 AM   #8
Ria44
is just ok
Ria44's Avatar
omg. i shifted into neutral when i took my test right in the S curve. ugh.
Ria44 is offline   Reply With Quote
tips to avoid shifting into neutral please OCMagnum Riding Skills 35 September 28th, 2012 12:26 PM
false neutral. BOH 2008 - 2012 Ninja 250R Tech Talk 10 July 23rd, 2012 08:50 AM
slipping from second into neutral...? clintalmighty 2008 - 2012 Ninja 250R Tech Talk 8 March 21st, 2011 08:43 AM
Shifting to neutral when at a stop. Kitdog Riding Skills 55 October 28th, 2010 10:20 AM
[roadracingworld.com] - Friday Video: How Danny Eslick Accidently Qualified Fastest A Ninjette Newsbot Motorcycling News 0 August 7th, 2009 02:00 PM
