Old March 11th, 2009, 07:05 PM   #1
Apex
Livin' the Minimoto Life
Apex's Avatar
"J" series rear shock assembly on "F" series
I read somewhere about someone doing a swap from the F series, non-adjustable, shock to the J series unit.
Anyone ever done this? I do plan on taking it to the track more often. So I think the stiffer shock would be nice. I may get some aftermarket fork springs in the future as well. I just want low budget and decent performance. I don't want to go high dollar for this little 250.
Old March 12th, 2009, 11:28 AM   #2
jonb08
jonb08's Avatar
Motorcycle(s): 2007 EX250
I personally would not upgrade the rear shock without upgrading the front forks to compliment. I went to a shop in Jersey that builds and races its own bikes and the guys provided me with that advice. It makes sense if you think about how load will get distributed. They said the best thing you can do first is buy better tires.
Posted via Mobile Device
jonb08 is offline   Reply With Quote
Old March 12th, 2009, 05:25 PM   #3
Apex
Apex's Avatar
My next purchase is a set of tires for track duty (nice DOT tires).
I was going to most likely upgrade the front fork springs and just wanted some adjustment capability for the rear.
Old March 19th, 2009, 02:10 PM   #4
kayfouroh
Motorcycle(s): 2001 EX250-F
I've done it, it's easy and cheap.
kayfouroh is offline   Reply With Quote
Old March 19th, 2009, 10:00 PM   #5
jonb08
jonb08's Avatar
Luckily, your in Texas. Those tires wouldn't be able to get into operating temp for about 2-3 months here.
Old March 22nd, 2009, 11:46 PM   #6
fjyang
fjyang's Avatar
Motorcycle(s): 87 Ninja 250, 90 Ninja ZX750R, GPZ 900r, 02 Moto Guzzi LeMans, 95 Triumph Speed Triple
I've pick up a 08 rear shock for a song on ebay and it was a easy swap onto my classic 87 Ninja 250. The 08 are about 1/4" longer eye to eye compare to 86-87 and 88-07 250's so if you mount a taller 90 series tires you'll not be able to lift your rear tire up with the center stand with a 08 rear shock.
I my rear tire is a 130-80-16 so I just barly have enough gap to spin my rear tire when on the center stand. I have not ride it as I'm rebuilding my front brakes but when I sit on the bike, my old shock will sag 2", the 08 will only sag 1" and I crank the preload 3/4 to max as I'm no light weight but I'm sure this will be an improvement over the older shocks.
fjyang is offline   Reply With Quote
Old March 29th, 2009, 08:05 PM   #7
Apex
Apex's Avatar
Sweet, then I can finally pull off that centerstand for some weight savings!
EXCELLENT!!
lol
Old March 30th, 2009, 12:11 PM   #8
sometimesido
sometimesido's Avatar
Motorcycle(s): 2006 250R
Frank, let us know after you ride few miles.
I'm interested in doing this.
What about 2x4 underneath the center stand with 130/90-16?
my flickr™
sometimesido is offline   Reply With Quote
Old March 30th, 2009, 12:13 PM   #9
sometimesido
I just noticed two of you who have done it are both "Frank."
my flickr™
Old March 30th, 2009, 12:55 PM   #10
fjyang
fjyang's Avatar
Great Minds (Franks) think alike Just got a 30 min ride over the weekend and the shock is firm but not jarring, my old shock is like marshmellow compared to the 08 shock. What I like the most is that now I have more weight on the front of the bike, I put a 110-70-16 which lower the front and a 1/4" longer 08 shock further the bias toward the front and I like how the bike handles now in corners.
I got progressive springs with no spacer (per instructions) and its a little soft so I put a little more fork oil and 1/2" spacer in each fork and its a little bit too stiff so I might take the spacer off and see how it feels with just the fork oil increase. My 87 E2 only got 35mm fork tubes, 88-07 got 36mm and 08's got 37mm.
If you can find a 08 shock then by all means go for it, its really a bolt on installation. If you go touring with your ninja then stock might be better option but if you like canyon carving a firmer rear shock is always the way to go
Old March 30th, 2009, 04:43 PM   #11
sometimesido
lower profile front tire?
I'm wondering if the firmer shock will help with the weight of all the extra gear in the back for touring.
my flickr™
Old April 4th, 2009, 12:53 AM   #12
fjyang
fjyang's Avatar
Stock front tire is 100-80-16 if you put 110-70-16 then its a lower profile tire then stock and just lower the front just ever so slightly.
I personally feel 250 is bit small for touring purpose but that's just my opinion and many people have turn the F series into Iron butt rally contender. If you can find an 08 shock for little money then you got nothing to lose by trying.
Old April 14th, 2009, 09:06 AM   #13
Grn99Kawi
Grn99Kawi's Avatar
Motorcycle(s): 2000 Honda CBR600F4 (sold) 1999 Ninja 250 (sold)
I bought one last week on ebay.. it should actually be here today, and I am 'planning' on getting outside to install it. I'll post up my impressions of it.
Grn99Kawi is offline   Reply With Quote
Old April 15th, 2009, 01:34 PM   #14
sometimesido
looking forward to it.
my flickr™
Old May 21st, 2009, 01:25 AM   #15
ninjammin
Motorcycle(s): 2003 Ninja 250
I installed an 08 shock on my 2003 yesterday and love it. I like a firm ride, and this has done just the trick. I was going to start a thread on this with my pictures, but why not just post them here. I've gained a pretty substantial amount of height. My stock shock had 16,300 miles on it, and was extremely mushy. Let me know if you guys have any questions. The photo's are arranged before/after, before/after if you can't tell.
ninjammin is offline   Reply With Quote
Old May 23rd, 2009, 06:30 PM   #16
Apex
Apex's Avatar
Thinking about doing anything up front?
Old May 23rd, 2009, 06:53 PM   #17
ninjammin
I'm very satisfied with how it rides right now, so it's not in the plans. The forks will need to be serviced before too long though, so I may look into my options at that point.
Old May 23rd, 2009, 07:06 PM   #18
Grn99Kawi
Grn99Kawi's Avatar
I am... I have read that someone put RaceTech .75 kg/mm front fork springs up front to complement a rear EX500 shock.. I figure it might be worth upgrading mine as well.
FRONT FORK SPRINGS
Recommended Fork Spring Rate for Street: 0.724 kg/mm (use closest available)
Stock Fork Spring Rate: .440 kg/mm (stock)
FRSP S2938080 RT FRK SPR 29.0x377mm .80kg $109.99
hmmmm
2000 Honda CBR600F4 Silver and Red
1999 Kawi Racing Green Ninja 250 sold
Old May 24th, 2009, 03:13 AM   #19
jonb08
jonb08's Avatar
Definitely do that. Go to someone that really knows their stuff about suspensions and try to match the forks to the rear shock for a more well balanced bike. I bet that rear shock was toast after that many miles!!
Old May 24th, 2009, 12:52 PM   #20
Apex
Apex's Avatar
16k is a lot of miles?
Wow, that is right around the corner on mine. I'm almost there.
I need to race mine.
Old May 24th, 2009, 01:45 PM   #21
jonb08
jonb08's Avatar
Wow, you really racked up the miles. I guess you get to ride pretty much all season down in TX.
Old May 24th, 2009, 06:29 PM   #22
Apex
Apex's Avatar
Yup. The only time I don't ride is when it is too dangerous (lots of lightning, flooding, chance of hail, chance of ice/snow, etc). I don't really care how cold it is, I'll still cruise around out there.
Old May 24th, 2009, 08:13 PM   #23
ninjammin
I got my bike with 8k on it about 9 months ago. I haven't even gotten a summer's worth on it right now. I plan on adding around the same since it's finally riding season
Old June 29th, 2009, 11:28 PM   #24
Verus Cidere
Verus Cidere's Avatar
Motorcycle(s): '91 Honda CBR600 F2
Quick question on the dead thread! Do you need to get the whole shock mounting piece for this mod or can you just get the spring? I'm really interested in doing this, but I don't want to get the wrong things.
1991 Honda CBR600 F2, White/Gray, D&D slip-on exhaust, tail integrator, gel grips, Custom undertail.
Verus Cidere is offline   Reply With Quote
Old June 29th, 2009, 11:32 PM   #25
You need the entire shock (shock and spring) from the new gen, otherwise it wouldn't be adjustable.
the one on the left in this picture...
Old June 29th, 2009, 11:34 PM   #26
Verus Cidere
I didn't say that right did I? I meant, can I just get the shock or do I have to get the mounting bracket for it too? Is the newgen shock a direct bolt-on replacement for the pregen shock?
Old June 29th, 2009, 11:35 PM   #27
yes
Old June 30th, 2009, 12:08 AM   #28
Verus Cidere
Sweet. Thanks.
[superbikeplanet.com] - WSBK Delighted to Announce Series "Should" Return To South Af Ninjette Newsbot Motorcycling News 0 December 2nd, 2013 10:50 AM
[topix.net] - "The Fonz", "Ralph Malph" & "Potsie" are giving away Fonzie's motorcycl Ninjette Newsbot Motorcycling News 0 August 16th, 2012 04:30 PM
[motorcyclistonline] - AHRMA announces a "World Championship" mini-series Ninjette Newsbot Motorcycling News 0 May 18th, 2011 04:40 PM
[roadracingworld.com] - New Road Racing "Feeder" Series Being Organized In Germany Ninjette Newsbot Motorcycling News 0 December 10th, 2009 11:00 AM
[motorcycledaily.com] - Honda Withdrawal from "AMA/DMG Roadracing Series" Hardly a Su Ninjette Newsbot Motorcycling News 0 September 21st, 2009 06:40 PM
