July 26th, 2015, 05:46 AM | #1 |
Join Date: Jul 2015 Motorcycle(s): 07 Ninja 250R Posts: 1
Starting Issues
2007 ninja 250r.
I garaged it for a year. I decided to pull it out, and go for a ride...well....it won't start. The battery is dead, so I just booked it up to my cars battery. It will crank....but no start. It does however sound like it realll lywants to start. It will pop and sputter every few seconds. I have tried the following: New plugs...with gapping Checked for spark...yes, it has a spark I checked the petcock, its free and clear Cranked the motor with the fuel line disconnected, it shoots out just fine. I've literally checked everything. I've even pulled and cleaned the carbs, and adjusted the valves. I'm running out of ideas. I did spray some carb cleaner into the cylinder and airbox....nothing. What I do find kind of weird, is that I can see fuel vapors coming from the airbox as I crank. Any help would beappreciated |
July 26th, 2015, 07:29 AM | #2 |
Describe exactly how you cleaned the carburetors?
Sounds like the carburetors my be your problem. Any modifications to the bike?
July 26th, 2015, 07:56 AM | #3 |
You completely drained the old gas from the tank, right?
Starting Issues | FvnnyL3tt3r1ng | 1986 - 2007 Ninja 250R Tech Talk | 12 | January 22nd, 2015 10:33 AM |
Issues with starting | arieon69 | 1986 - 2007 Ninja 250R Tech Talk | 15 | September 7th, 2012 06:38 PM |
Issues starting up | Maielstrom | General Motorcycling Discussion | 2 | August 8th, 2012 08:35 AM |
Starting issues | Gorilla25 | 2008 - 2012 Ninja 250R Tech Talk | 14 | September 22nd, 2011 09:20 PM |
Starting Issues | mikkel | General Motorcycling Discussion | 4 | July 30th, 2009 01:40 PM |
