Go Back   ninjette.org > General > Group Rides and Local Events
Old January 5th, 2013, 02:59 AM   #2041
Mountain Dew
Ambrosia.
Mountain Dew's Avatar
Motorcycle(s): 1974 Honda CB550K0 W.I.P.
Not familiar with shim-and-buckets, but if you ever need help with tappets, let me know :P
Life's better on the Mountain.
Mountain Dew is offline   Reply With Quote
Old January 6th, 2013, 12:06 PM   #2042
kremtok
Motorcycle(s): 2016 Triumph Street Triple RX
Haha...thanks for the offer!
We do what we must because we can.
kremtok is offline   Reply With Quote
Old January 21st, 2013, 12:05 AM   #2043
Kstorm21
Kstorm21's Avatar
Motorcycle(s): 2009 Ninja 250R SE
Everyone okay?
Kstorm21 is offline   Reply With Quote
Old January 21st, 2013, 02:18 PM   #2044
kremtok
Originally Posted by Kstorm21 View Post
I heard about that yesterday. I really wish they'd release more information on these accidents so the rest of us can learn from them. Was the biker doing everything right and a car hit him, or was he doing 115 mph wearing flip flops and no helmet splitting lanes then crashed into a guardrail?
In any case, it's bad news to hear that another biker went down.
Old January 21st, 2013, 05:01 PM   #2045
Kstorm21
Kstorm21's Avatar
^^agree...the never really give out any info other than no helmet and "not sure if alcohol was a factor".
Old February 6th, 2013, 03:00 AM   #2046
Gorilla25
Dakine...
Gorilla25's Avatar
Motorcycle(s): 2009 Ninja 250R (Sold) | 636 (hopefully soon)
@Kstorm21: you been doing much riding lately?
My Mods
Gorilla25 is offline   Reply With Quote
Old February 6th, 2013, 07:16 AM   #2047
Kstorm21
Kstorm21's Avatar
Yeah, as much as possible. Not for another week tho. Had to go back to the mainland for a family emergency.
Old February 6th, 2013, 10:42 AM   #2048
zion757
zion757's Avatar
Motorcycle(s): 2012 ninja 250r
Does anyone still have the factory tire still on? If not how many mile till you had to change it?
http://www.ninjette.org/forums/blog.php?b=1792
zion757 is offline   Reply With Quote
Old February 6th, 2013, 01:37 PM   #2049
Gorilla25
Dakine...
Gorilla25's Avatar
I see. I hope everything works out.
Sorry, not me. I changed it out because i'd slide around too much in the rain...no bueno
My Mods
Old February 6th, 2013, 01:45 PM   #2050
Kstorm21
Kstorm21's Avatar
I do...but I'm not much of a rain rider.
I see. I hope it works out.
You can see why on FB. Thanks tho
Old February 6th, 2013, 02:14 PM   #2051
zion757
zion757's Avatar
Opinions: do you think it would be nice to swap swing arm wit r1 or r6? I really don't know the gain or loss in performance but It look really sweet to me.
Old February 6th, 2013, 04:50 PM   #2052
Gorilla25
Dakine...
Gorilla25's Avatar
well, with time and patients, its possible. You would have to research how the swing arm bolts up to the R6 or 1 vs. how its mounted on the 250r. then comes the bolt diameter and length. Im sure you're gonna have to get/make spacers for the fitment. next, you gonna have to measure and make sure the sprockets gonna line up so the chain gets lined up as well. of course you gonna have to get the rim and tire to go with the swing arm. next is the shock. luckily it should be a simple bolt on. check my DIY for my R1 shock swap for info on mating the R1 shock to the 250r subframe. how comes the handling. with a 180 rear tire, you gonna lose a little performance on the 250r. the 250r was designed to be optimal with a 130 rear tire. im running a 140 and haven't experienced a loss in performance, though.
EDIT: hell yeah, its gonna be sweet!
My Mods
Old March 28th, 2013, 11:53 AM   #2053
Mountain Dew
Ambrosia.
Okay guys here's an update on my bike since I'm in the home stretch.
As you know, sometime in early October, it spun a rod bearing. The exact cause I'm still not sure,but my guess is that the primary chain (the chain linking the crankshaft to the transmission), had tons of slack, and on a hard decel/accel, managed to damage the bearing. That shredded the bearing and blocked up the oil passages to the top end, which subsequently overheated. That was enough to scorch the cam lobes, journals, and a few of the rocker arms. It also scored the rod journal and filled the oil hole with bearing material. The local machine shop (Ted's) didn't have a grinder small enough to fix it, and there are no under/oversized bearings available from Honda.
Now on to the work that's been done:
- 592cc 10.5:1 CR pistons by JE (up from 544cc 9.0:1 CR)
- WebCam camshaft, .330/.330 lift, 288/288 duration (up from .252/.272 lift, 240/245 duration ** can't find accurate specs, but that's what it was reported as)
- Kibblewhite Black Diamond oversized intake valves (+1mm over stock or 28.5mm)
- Kibblewhite Black Diamond stock sized exhaust valves (23mm)
- Kibblewhite heavy duty valve springs
- Serdi valve job
- Barnett heavy duty +1 plate clutch kit
- APE chrome moly head studs
- Stage 3 porting and cylinder boring by JMR
- APE lightened crankshaft
- Carpy's Yoshimura-style exhaust
- HondaMan transistorized ignition kit
- HondaMan swingarm rebuild with SAE 660 bronze bushings
- Progressive shocks
- Progressive fork springs
- New fork tubes (out of stock at the shop I want them from, should be in stock soon)
That's about it for the engine and suspension. I'm still contemplating getting my transmission undercut, as well as either forged rods or aluminum rods.
Will all the big and light internals with massive flow, it'll be more like a roadrace engine, not wanting to be under a certain RPM, and will take off like it has a turbo when it hits that sweet spot. According to an expert, I'll have a hard time getting the advance curve and timing just right. And since it's a points-type ignition with a centrifugal spring advance, I'll have to do some actual work to get it right.
As for the cosmetics, I'll be powdercoating the frame, swingarm, and triple tree Gulf Orange (marigold). The bodywork MAY have to wait as I'll be spending tons on the El Camino to pass safety inspection (and feel a bit safer when I'm driving it). But it'll be Gulf Blue (Powder Blue) with an orange stripe, just like the Gulf livery. I'm still playing with ideas in my head though. I'll have a more definite description eventually. I'll be replacing the wheels with some Excel or Akront wheels with a large polished shoulder and stainless spokes. Already have my black clip-ons. I'll also be doing something with the seat, not sure what.
And here's some pictures for you autophiles (everything's still kinda dirty with lube and such).
@Gorilla25
Old April 1st, 2013, 05:59 PM   #2054
Galaxieman
Galaxieman's Avatar
Motorcycle(s): 2008 Ninja 250, 2009 Concours 14
Did a 1-lap run around the island last Saturday (23 March)... on the Concours. Did get my adjustable brake and clutch levers (matching set from the2wheels on ebay, since I have a 2002 VTR1000F brake MC) installed on the Ninjette though. As a sidenote, it's a good idea to leave your gloves out to dry after riding around in the rain here. I never had an issue in AZ, but had nasty-ass mold growing on my gloves when I pulled them out from under my helmet yesterday. WAY not cool.
Igitur qui desiderat pacem, praeparat bellum...
Galaxieman is offline   Reply With Quote
Old April 5th, 2013, 07:32 PM   #2055
kremtok
Hey guys I have a problem. I discovered to small rust spots on my gas tank, likely where a rock chipped off the paint, and I'd like to get them repaired. Can anyone recommend a good paint / body shop?
Old April 7th, 2013, 09:28 AM   #2056
Gorilla25
Dakine...
Gorilla25's Avatar
@Mountain Dew: cant wait to see how it turns out!
My Mods
Old June 5th, 2013, 11:37 AM   #2057
Gorilla25
Dakine...
Gorilla25's Avatar
@5eleven: here is the unofficial oahu "chat" thread. its small kine dead but hopefully can revive it. If you know more 250 owners, send um to ninjette..
My Mods
Old July 9th, 2013, 02:23 PM   #2058
Mountain Dew
Ambrosia.
Making some big progress on the cosmetics.
Check page 4 of my build thread http://forums.sohc4.net/index.php?topic=101783.0
Old July 27th, 2013, 03:13 AM   #2059
Kstorm21
Kstorm21's Avatar
For those of you that I don't know of FB...I had a HORRIBLE experience at Hawaiian Rides in Wahiawa. Long story short...got my safety check done...guy left the keys in the ignition and some kids stole the key. He ended up telling me I had to take some fault to the keys being stolen. Ass hole!
Old July 27th, 2013, 03:22 AM   #2060
Sound Wave
Ramen Rider
Sound Wave's Avatar
Sorry to hear that. The only fault of yours is mistakenly taking it to such a cruddy business.
They seem to have a bad overall rating on Yelp.
http://www.yelp.com/biz/hawaii-rides-wahiawa
Old July 27th, 2013, 04:11 PM   #2061
Kstorm21
Kstorm21's Avatar
Oh...my husband then got involved after I had to go back the following day cause he said he would get me a replacement key. (that's when he blamed me) and the locksmith that said he had the key yesterday, now doesn't have one. I asked him to replace the garage door opener and that's when things really got bad. Called my husband to vent and he got involved. He called, they yelled at each other....blah blah blah...hubby hung up 3 different times telling him to stop calling and the the last time hubby said, I'm hanging up now stop calling. The guy said, if you hang up again, I'll come to your house so we can discuss this further. Husband accepted his challenge. He never came. After reading everything on Yelp, I guess I should be grateful they didn't break my ****.
Old July 31st, 2013, 01:18 AM   #2062
Galaxieman
Galaxieman's Avatar
Anybody up for a ride later this week / weekend? Friday and Saturday afternoon are both clear and I've been itching to get out and try some new GoPro angles. That and anybody got good directions to '13 turns'? I've done Tantalus a couple of times and while it's ok, the surface can be kinda sketchy, and with yahoos blasting up and down on 600's the police presence is actually noticeable...
As for the Hawaii Rides guys, they completely missed the massive fork seal leak on my bike, so I'm leery of it being anything other than a 'make sure the lights and horn work' tax-check. I knew it was leaking and cleaned it right before I rode over there, but any fork compression and it was painfully obvious. Of course that's pretty much the standard for 'safety checks' out here anyway...
Old August 1st, 2013, 09:36 AM   #2063
Gorilla25
Dakine...
Gorilla25's Avatar
I'd come out and ride, but I'm helping my fiancee move :/ hopefully next time.
My Mods
Old August 12th, 2013, 07:21 PM   #2064
Manimal
Manimal's Avatar
Motorcycle(s): 2013 Ninja 300 SE
My family and I recently visited Oahu. Arrived back to the Mainland last week. My Father is from the Kalihi area and have family in the Mililani area. We nearly visit yearly. We typically drive all over the island. One of these years, I would like to ride.
Where do you guys ride?
The roads are often filled with traffic, how do you guys get to enjoy your rides?
Manimal is offline   Reply With Quote
Old August 19th, 2013, 02:43 AM   #2065
Gorilla25
Dakine...
Gorilla25's Avatar
There are about 5 spots to ride twisties. Traffic does vary so the time you go riding matters too.
My Mods
Old September 20th, 2013, 09:22 PM   #2066
kremtok
Sunday ride from town to Kahuku sound good to anyone?
Old September 30th, 2013, 08:23 PM   #2067
Gorilla25
Dakine...
Gorilla25's Avatar
For anyone interested or know of someone interested, my bike is up for sale. $3,300 OBO
http://honolulu.craigslist.org/oah/mcy/4101133389.html
Edit:
SOLD
My Mods
Last futzed with by Gorilla25; October 4th, 2013 at 03:30 PM.
Old December 23rd, 2013, 02:48 PM   #2068
Lucagst
Lucagst's Avatar
q
Lucagst is offline   Reply With Quote
Old February 12th, 2014, 06:17 PM   #2069
dkstariob
Motorcycle(s): None
Planning a cruise with Kremtok and my roommate this coming Sunday, weather permitting. Will post more details later.
dkstariob is offline   Reply With Quote
Old February 12th, 2014, 06:20 PM   #2070
corksil
Motorcycle(s): A lot.
Maui anyone?
Old February 14th, 2014, 10:59 PM   #2071
kremtok
I hope it doesn't rain too badly. Oh well. Even if it does, the ride will do me a world of good.
Old February 15th, 2014, 02:53 PM   #2072
dkstariob
Motorcycle(s): None
Looks pretty damn awesome today. Hopefully it holds up!
Old February 16th, 2014, 11:53 AM   #2073
kremtok
Looks pretty crappy out...
Old February 16th, 2014, 11:56 AM   #2074
dkstariob
Motorcycle(s): None
I just sent you a text. It looks extremely crappy from the east side, just let me know. I'm ok with a rain check but if you're willing to brave it than I am as well. Definitely don't want to be the party pooper, but IT DOES LOOK CRAPPY haha. :\
Old February 16th, 2014, 12:08 PM   #2075
kremtok
Didn't get you text, but this seems to be working! Let's cancel today. I get rained on enough during commutes that I don't have to go out of my way on weekends.
Old February 16th, 2014, 12:36 PM   #2076
dkstariob
Motorcycle(s): None
I'll send you the PM, alright man that sounds cool. Enjoy your sunday and the run tomorrow!
Just got my very first bike! I'm from Oahu! Ninjastyle23 New Members 16 January 7th, 2012 10:38 PM
Aloha from Oahu Rob808 New Members 23 October 12th, 2011 09:27 PM
Stairway to Heaven (oahu peeps) istreefitty Off-Topic 10 May 8th, 2011 10:01 PM
Aloha from Oahu!! jupiter1827 New Members 17 October 1st, 2009 09:59 PM
Hello from Oahu ninjabrewer New Members 2 November 19th, 2008 02:02 PM
