Old August 24th, 2015, 09:42 AM   #1
ji0315tafeng
Motorcycle(s): 2011 Ninja 250
Ninja 250 stalls when giving throttle
Hello everyone newbie here.
So long story short I had a crash because of some truck dropping 2 by 4 all over highway. I was merging onto highway (luckily I survived). The bike was dropped on the right side.
Just two days before the crash I had the bike serviced (It was making a ticking noise) and the cam chain tensioner was changed to a manual one. The service also include a re-jet of the carb. This solved the ticking noise.
After the crash the bike would make the same noise and would stall after giving throttle. The exhaust air smells bad.
My questions are:
Since the bike falls on the right side would a damaged exhaust pipe affect how the bike runs?
I went through a few shop asking for a fix, they all said I might need to re-jet, is it true?
ji0315tafeng is offline   Reply With Quote
Old August 24th, 2015, 09:50 AM   #2
asdfman
٩(͡๏̯͡๏)۶
asdfman's Avatar
Motorcycle(s): 09 Ninja 250 held together by duct tape and zip ties
I doubt your exhaust has to do with the stalling. Have you been able to look at the carb yet? Make sure all the connections are intact and correct. Also, how does the bike run at idle? Are the RPMs okay?
asdfman is offline   Reply With Quote
Old August 24th, 2015, 09:53 AM   #3
ji0315tafeng
The bike will start and sits between 1 and 2. The bike starts fine but after warming up the ticking noise would start and dies on throttle.
Old August 24th, 2015, 10:00 AM   #4
asdfman
٩(͡๏̯͡๏)۶
asdfman's Avatar
In that case, definitely check out your carb connections (all ends). I had a similar problem with my bike after I cleaned my carbs the first time. Turns out I connected the cables incorrectly.
Old August 24th, 2015, 10:43 AM   #5
Foxrider64
Hello Moto
Foxrider64's Avatar
Motorcycle(s): 1975 RD350; 2001 KX125; 2003 Z1000; 2003 KDX50; 2009 ZX6R; 2011 Ninja 250R; 2014 KX250F
What happens if you have the choke full "on" and you give it gas slowly?
Are all the fairings on? Airbox in tact? Air Filter clean?
I can't tune my 250 without the tail and seat on because it changes the air flow enough that it runs like crap as soon as you touch the throttle.
Foxrider64 is offline   Reply With Quote
2011 Ninja 250 stalls when given too much gas GregoryC4 2008 - 2012 Ninja 250R Tech Talk 15 April 1st, 2014 09:45 AM
stalls sometimes when applying throttle ninja12345 2008 - 2012 Ninja 250R Tech Talk 11 November 3rd, 2013 07:41 PM
Bike bogging when giving it throttle dwright0723 2008 - 2012 Ninja 250R Tech Talk 23 July 15th, 2013 10:11 PM
Bike stalls when touch throttle Cycy 2008 - 2012 Ninja 250R Tech Talk 31 May 20th, 2013 12:35 AM
bike dies when giving it throttle RED_09 2008 - 2012 Ninja 250R Tech Talk 8 December 16th, 2012 04:51 PM
