Old February 2nd, 2016, 06:24 AM   #1
[visordown.com] - Royal Enfield Himalayan officially launched in India
FOLLOWING the first official pictures and promotional video, Royal Enfield has just launched its new Himalayan adventure bike to the world at the Auto Expo in Delhi.
The presentation, which you can watch above (skip the first 15 minutes), was hosted by Royal Enfield CEO Siddhartha Lal, who talks through the bike at length and now it's officially out there, there are some proper specs available.
We thought the engine was going to be around 410cc and we weren't far off because the Himalayan is powered by a 411cc air-cooled single cylinder carb-fed engine paired with a five-speed gearbox.
It makes a claimed 25hp at 6,500rpm (slightly less than the 28hp we were expecting) and 23.6lb/ft torque at 4,000 - 4,500rpm.
The bike's kerb weight is 182kg, although Royal Enfield doesn't explained what it classes as kerb weight.
The Himalayan is built around a half duplex split cradle frame. At the front are a set of 41mm conventional forks with 200mm travel and at the other end is a monoshock that gives 180mm travel.
Braking at the front is handled by a two-piston floating caliper biting on to a 300mm disc, while the rear gets a 240mm disc and single piston caliper.
Ground clearance is 220mm and the seat height is 800mm.
It's available in two colours - 'Snow' and 'Granite'.
The 21 inch front wheel is shod with a 90/90 section tyre, while the 17 inch rear gets a 120/90.
Royal Enfield's marketing would have you believe that it's a simple and rugged adventure bike, and its spec seems backs that up, as long as it isn't let down by dodgy footpegs.
  • Sign up for Visordown's weekly newsletter, Bugsplat, to get the best motorcycle news, road tests and features plus exclusive competitions and offers direct to your inbox. Register as a Visordown member here and tick the box for Bugsplat in your newsletter settings here.
Related Content
Royal Enfield Himalayan official promo video
Royal Enfield Himalayan debuts
Royal Enfield Himalayan spotted again
Royal Enfield Himalayan spied again
Click here for full story...
[visordown.com] - This is what the Royal Enfield Himalayan sounds like Ninjette Newsbot Motorcycling News 0 January 21st, 2016 03:20 AM
[visordown.com] - Royal Enfield Himalayan spied again Ninjette Newsbot Motorcycling News 0 December 9th, 2015 06:02 AM
[visordown.com] - Royal Enfield Himalayan our best look yet Ninjette Newsbot Motorcycling News 0 August 7th, 2015 12:51 AM
[visordown.com] - Royal Enfield Himalayan spotted again Ninjette Newsbot Motorcycling News 0 May 22nd, 2015 10:10 AM
[visordown.com] - Is this the Royal Enfield Himalayan Ninjette Newsbot Motorcycling News 0 April 30th, 2015 04:02 AM
