Old August 22nd, 2008, 01:12 AM   #1
FlamingYellowInsanity
Too sexy for roadrash
FlamingYellowInsanity's Avatar
Motorcycle(s): 2004 Ninja 250, 2007 Lance GS-R 150 (racing modified scooter), 1980 Honda CB750K project
Missing Shifts?
I got a quick question about the tranny. Every once in a while when I'm riding I'll go to shift, pull the clutch and hit the shifter, and it won't shift. It'll move, but not click, and when I let the clutch out, it is still in the same gear as before. Also, I've had it not shift into first when I was sitting at a stop light. Will this get better as it breaks in a bit more, or is there some trick to making it sure shift every time? I'm also thinking that a good, high quality oil may help these weird symptoms.
Maybe I just need to learn how to shift better and this is all just me!
Thanks!
Travis
I'm too sexy to get roadrash, that is why I wear my gear all the time. If you are not as sexy as me, then maybe you can get away without it.
~Unofficial ninjette.org fish smacker~
FlamingYellowInsanity is offline   Reply With Quote
Old August 22nd, 2008, 01:34 AM   #2
Hi Travis -
I think your suggestion for some good new oil is a good one, you don't know how long that oil has been in the bike already (likely since new). All of my bikes shifted better after an oil change, and the ninjette is no different. What I'd also try is to adjust the clutch cable to make sure that when you are pulling the clutch lever the clutch is completely disengaging as it should.
Here's a link on how to adjust the clutch lever (it's a snap).
After you've done those two things, I'd concentrate on making sure that each shift you make is firm and positive, and see if the symptoms go away. You can also adjust the shift lever itself to put it in a comfortable place for your boot, so it's positioned just right for good shifts up and down. The ninjette transmissions are reasonably bulletproof, there is little talk of early failure on them and at 400 miles or so, there's no reason to believe yours is already broken in some way.
Old August 22nd, 2008, 07:12 PM   #3
dw8
Motorcycle(s): None
Very common issue with the 250. If you rock the bike forwards and backwards a couple times, it will go into first.
dw8 is offline   Reply With Quote
Are clutchless shifts harsh on the bike? snowbandit 2013 - 2017 Ninja 300 Tech Talk 42 June 17th, 2013 01:11 AM
Occasionally shifts to neutral from 1st to 2nd woofer987 2008 - 2012 Ninja 250R Tech Talk 8 May 6th, 2013 08:52 AM
Shifting problem - False shifts from 2-3 s2kenny 2008 - 2012 Ninja 250R Tech Talk 6 March 26th, 2013 11:05 AM
Clutch Slipping during high RPM shifts? SV_Hadder 1986 - 2007 Ninja 250R Tech Talk 5 January 5th, 2011 10:10 AM
[roadracingworld.com] - Shifts Launches New Website Ninjette Newsbot Motorcycling News 0 February 13th, 2009 11:40 AM
