May 25th, 2015, 08:12 AM | #1 |
ran when parked
Join Date: Aug 2013 Motorcycle(s): Freeride 250R, KLX250SF, mopeds Posts: A lot.
MOTM - Sep '17, Dec '14
running issue on my SV650
thought I'd post here for your guys' wise input .. esp since some of you have SVs. calling on @Jono and... I forget who else...
anyway, I've got a small problem. when the bike is hot (over 180F) and I pull the clutch in from 4k+ rpm, the bike cuts out at above normal idle speed and will not restart. I only lose the motor, no electronics. it doesn't stumble, it just dies quick. usually at 2k rpms. if I baby it and let the rpms down slowly I dont have an issue and it will idle normally. after it dies it does not want to restart until at a cooler temperature, around 170 it seems fine. it ONLY happens when hot, and ONLY happens when I let the rpms fall (I dont think it has anything to do with the clutch other than it's the easiest way to let the rpms fall fast). it's a 2003 fuel injected with a yosh slip on and no pc but ecu flashed for 10% more fuel at mid and top range. I just did a throttle body sync yesterday. 14,6xx miles. fresh oil fresh coolant stock air filter. below is a video of what happens..
Instagram: @katie.baden |
May 25th, 2015, 09:05 AM | #2 |
My guess it sounds fuel/fuel pump related. I had a similar experience with the zzr600 where the fuel pump would crap out which ended up being a solder to the pump had broke off from the vibrations.
Do you have a inline fuel filter? Can you hear your pump prime?
May 25th, 2015, 09:10 AM | #3 |
ran when parked
the pump primes every time it should, it's loud but it's always been loud and especially loud the lower the fuel level goes. somehow I dont think its a fuel issue because the temperature of the motor shouldn't affect the flow of fuel from the pump. I can check the fuel output but since it revs up just fine and runs normal when cooler.. hm. I'm off to get some spark plugs and see what I can see...
May 25th, 2015, 09:21 AM | #4 |
My money is on fuel pump and/or screen. Easy fix, but kinda common when the engine is pretty warm.
May 25th, 2015, 09:40 AM | #5 |
180 reliably and repeatably or just about 180? If it's reliable and repeatable, the temp sensor could be faulty, telling the ECU that the engine is one temp, adjusting the fuel to an amount that the engine doesn't run on at the temp it actually is.
Is there a way to check error codes or anything? I'm not super familiar with factory EFI systems on bikes. Also, what's the timeline look like with the ECU mapping relative to the problems you're experiencing? |
May 25th, 2015, 10:43 AM | #6 | |
Do you have a way to temporarily increase the idle rpm some, in order to by-pass the problem and make your street riding less dangerous? When you suddenly close the throttle, only air goes in, which lowers the minimum temperature to sustain internal combustion. If fuel injection is coming back a little too late (or it supplies insufficient or excessive fuel) when the crankshaft reaches normal idle rpm's, the combustion stops. Why not re-starting right away? Try starting hot with the throttle open some. Your spark plugs can tell you how the overall air-fuel mix is. If the oil pressure is insufficient, the pistons may be sliding too tight into the cylinders to start.
May 25th, 2015, 01:49 PM | #7 | ||||
ran when parked
I cleaned both spark plugs, put them back in, and could not get the bike to die again. The idle is a little bit low, around 1100 instead of the normal 1250 but doing what I was doing before which caused the bike to die, does not cause it to die anymore. Will throw in brand new plugs and check back in... Could just be that simple. The air filter is a little bit dirty...
May 25th, 2015, 02:15 PM | #8 |
it's a suzuki so i think you need to put on that fancy full yoshi and do trumpets instead of airbox. powercommander yo. also put beads in your tire. also paint it a different color. and do some more wheelies.
May 25th, 2015, 04:24 PM | #9 |
Participant
Join Date: Oct 2012 Motorcycle(s): '94 K75 std Posts: Too much.
-vacuum leak? I'd guess not.
-vapor locking/gas cap breather clogged? Naah. -tight valve (gonna do the valve check Saturday but I doubt its out of spec)? Naah. -bad spark plugs? Naah -bad ignition coils. Not if there's more than one. -coil arcing to cylinder head? Wouldn't think so. -crankshaft position sensor? Maybe. -throttle position sensor? Maybe. -clutch/sidestand safety switch? Naah. Seems heat-related. If it won't run at all, then it's not likely something you have two of. I like crankshaft position sensor (hall-effect?), TPS, temperature sensor. Also fuel pump relay (if the SV has one). Use a hot air gun to heat suspects if the bike's cold. Use compressed air to cool suspected parts if it's hot and won't run. Last futzed with by dcj13; May 25th, 2015 at 04:27 PM. Reason: Add another thought... |
May 25th, 2015, 04:34 PM | #10 |
Yeah, if it's only heat related as in problem happens at one temp vs doesn't happen at another and not heat related as in does this sorta at one temp and worse at another temp, I'm standing by my thoughts that it's electrical and not mechanical.
No idea why you don't have codes, but start heating/cooling parts as oldguyDave has mentioned and see what happens. You work at a shop, pick your coworkers brains. |
May 25th, 2015, 05:57 PM | #11 |
ran when parked
Being heat related and being something going wrong with two of something are definitely not mutually exclusive.
I can't get it to die after simply cleaning the spark plugs. I'll replace with new NGK tomorrow and see how it holds up. opinions like buttholes....... everyone has one. lmao
May 25th, 2015, 06:02 PM | #12 |
ran when parked
I think I figured out my problem. the motor ants have died on my rear plug. does anyone know where I can get new motor ants???
May 25th, 2015, 06:09 PM | #13 |
Join Date: Sep 2013 Motorcycle(s): 2015 Yamaha FZ07, Ninja 250r 2012 Limited Edition (Sold) Posts: 529
Well at least it turned out to be a cheap fix.
That engine sounds good to me!
"Take it easy driving. The life you might save might be mine." |
May 25th, 2015, 06:11 PM | #14 |
ran when parked
Yeah I'm sure it's not a problem with the actual motor. Sounds healthy.
I'll keep an eye out. It could be the air filter being dirty is causing the bike to run a little rich and foul the plugs after a long time of riding. this would account for my 5-mile commutes not being an issue, and only having trouble after riding around for a long time. idk though.I'll keep you posted...
May 25th, 2015, 08:25 PM | #15 |
I think it's running too rich, there may be fuel-related issues, and the injectors may be slightly dirty. It doesn't need the 10% additional fuel it's getting.
How old is the gas? Ethanol-free 87? Has the tank been sitting at a low level? If the gas could be old or the level has been low, the first thing I would do is drain the tank, get some fresh gas (87 w/o ethanol), and add 1 oz per gal of Techron Concentrate. |
May 25th, 2015, 08:31 PM | #16 |
ran when parked
filled up to the top yesterday with 87.
May 25th, 2015, 08:33 PM | #17 |
ran when parked
it's really hard if not impossible to find gas without ethanol here
May 25th, 2015, 11:08 PM | #18 | |
MOTM - July '15
True story, btw. |
May 26th, 2015, 07:08 AM | #19 |
The issue is what was in the tank before filling. If there was significant condensation, or the gas was bad, adding new gas will not fix the problem.
That's why I suggested completely draining the tank, then filling with 87. Adding a strong fuel system cleaner like Techron Concentrate once a season is a good idea with a F.I. engine. 1oz per gal is usually sufficient. Is there ethanol-free available in any grade in your area? I will only move up in octane to get away from ethanol. |
May 26th, 2015, 05:49 PM | #20 |
So was it doing this plug fouling trick before the ECU was reflashed?
May 27th, 2015, 09:46 PM | #21 | ||
ran when parked
today I checked the valves and my right rear intake valve was tight by 1 thousandth of an inch so I adjusted it to back within spec. no big deal, only 3 hours, I love shim under bucket. -_- bike runs flawless now though. new spark plugs and new cam cover gaskets/cam cover bolt o-rings. and the motor sounds so nice and quiet and healthy. cams look great. but I will go on another long ride this weekend and see how it holds up.. after I cleaned/replaced the spark plugs, before the valve adjust, the idle was a little weird when hot, it would rev fine and drop down to 1,000 rpm, and barely creep up to maybe 1100-1200. normally it was idling steady at 1300. after I adjusted the valve, the idle stopped hanging after revving and it's closer to 1400 now (I bumped it up yesterday but it was still only around 1200) anyway I don't think it was just bad gas, I shook the **** out of the bike which usually mixes it up good enough to see if that's the problem, and it wouldn't make sense that it would only act up from bad gas/water when the bike was hot and would be fine for awhile and then all of a sudden die when the rpms fell. I think its a combination of the tight intake valve, ******/old spark plugs, a slightly dirty air filter, and more fuel at higher rev ranges. or it could be none of those things, who knows. I'll keep ya posted and we'll see how it does on a longer ride.
May 28th, 2015, 06:40 AM | #22 |
I'd still add 1oz per gal of a strong fuel system cleaner like Techron Concentrate to a full tank.
Even minor deposits on the injectors can give you odd intermittent problems. |
May 30th, 2015, 12:22 PM | #23 |
Sorry for not being around to help. Sounds like you got it figured out? I am just as perplexed as you but I would have started with spark as well.
May 30th, 2015, 07:44 PM | #24 |
ran when parked
I'm taking it on a long-ish ride tomorrow, we'll see how it does. My commute is only 5 miles so it's not really enough time to test things out even though the bike does get up to normal hot running temp. Ill keep ya posted. seems good thus far
June 15th, 2015, 08:03 PM | #25 |
ran when parked
soooo... after the valve adjustment it got better... threw a k&n filter on it.. runs like 95% but occasionally, maybe twice in each ride depending on the length, it'll drop rpms at idle to around 1000 and stumble a little, it died once today but i was trying to kill it by revving it and then pulling in the clutch. restarted fine with some throttle after that and was good for the rest of my ride... I put 93 gas in it today just on the off chance it'll make a difference, I normally use 87. dont think it has anything to do with vapor locking or vacuum leaks. I'm kinda stumped and it's not enough of a noticeable problem for me to be able to investigate a whole lot.
June 16th, 2015, 02:30 AM | #26 |
So... it wasn't the spark plugs?
I'd offer my asshole, errr, my opinion, but you seem to have your mind made up already. |
June 16th, 2015, 06:56 AM | #27 |
Add any Techron yet?
93 octane won't help the SV, unless you need to use it to get away from ethanol. The SV makes the most power and gets the best mileage on 87 without ethanol. Can you back-down (lean) the mixture? |
June 16th, 2015, 06:02 PM | #28 |
ran when parked
I had checked the vents from the tank but I hadn't checked the vent on the gas cap actually
I rode another sv today that did the exact same thing as my bike but had a worse case of it and there was all kinds of **** in his gas cap vent. blew it out and his bike was fine. blew mine out and my bike seemed great on the way home. I will be so happy if it's this simple of a fix!
June 27th, 2015, 05:58 PM | #29 |
ran when parked
okay. so I seemed to have fixed it. and then yesterday it was dropping idle and died on me a couple of times with not too much fuss to restart it but I kept the idle up at stops so it wouldn't die again. Blew out the gas cap AGAIN and checked all the vents. all good. today it sat in the pissing rain for hours after i rode it to work (in said pissing rain) and just as I was getting back to my house from my 5 mile commute, where it normally displays the coolant temp, it says CHEC but there is no FI light and I checked for codes, and there are none.
what the F**K. I'm at a loss. some people on svrider said it's a random issue, my boss thinks it's water problems but I checked the connector to the ECM and it seems fine. the service manual just says check the ignition fuse and wires from the speedometer gauges to the ECM. the only other thing is that one of the letters that normally displays a number of the clock on the gauges wasn't going off even with the bike turned off. like the LCD panel was off but you could still see that one side of the letter. I'm going ****ing nuts over here.
June 27th, 2015, 06:59 PM | #30 |
ran when parked
replaced the ignition fuse and it was fine.
sviz you're killing me over here.....
June 28th, 2015, 01:40 PM | #31 |
MOTM - July '15
[motorcyclenews.com - news] - Staff Blog: Running In or Running Out!! | Ninjette Newsbot | Motorcycling News | 0 | May 7th, 2013 04:20 AM |
[motorcyclenews.com - news] - Staff Blog: Running In or Running Out!! | Ninjette Newsbot | Motorcycling News | 0 | May 6th, 2013 09:50 AM |
[motorcyclenews.com - news] - Staff Blog: Running In or Running Out!! | Ninjette Newsbot | Motorcycling News | 0 | May 6th, 2013 09:20 AM |
[superbikeplanet.com] - Suzuki: Haslam's Wrist Issue Should Not Be An Issue | Ninjette Newsbot | Motorcycling News | 0 | May 11th, 2010 07:50 AM |
Have a lean issue with my bike, issue with coasting enricher. | twiggy2cents | 1986 - 2007 Ninja 250R Tech Talk | 7 | February 24th, 2010 06:54 PM |
