Old July 4th, 2012, 09:03 PM   #1
Gunner
Gunner's Avatar
Motorcycle(s): 2010 Ninja 250R SE
Battery, regulator or alternator problem?
Just bought a new battery 1 month ago. Everything has been running fine. Parked the bike since the weekend and fired it up today, only to find the bike clicking when trying to turn it on. At first i thought it was about to turn over but after a few more attempts it was only clicking and the lights were dimming. Used a charger to charge the battery and plugged it back in. Used a voltage multimeter and these are the values i got;
Sitting = 12.90 volts
Idle = 14.30 volts
start = 9.90 volts
RPM@4K= 13.95 volts
When i turn the bike off it starts at 13.40 volts and goes down 0.01 volts every 3 seconds till it equals out to 12.90 in about 4 minutes.
Read through a few forums but couldnt really find anything concrete. Any help on what the cause of the sudden dead battery be?
Gunner is offline   Reply With Quote
Old July 4th, 2012, 09:12 PM   #2
FrugalNinja250
FrugalNinja250's Avatar
Motorcycle(s): Several
Almost all the voltages you describe and the conditions upon which they occur are normal. The nominal battery voltage is 12V, that's inherent to the battery chemistry. Alternators and regulators are designed to put out around 13.5-14V under moderate load, sometimes a bit more (but never more than about 14.5V). When you first shut off the motor the voltage off the battery will show alternator voltage above, but that will rapidly decrease to the battery's nominal voltage.
The cranking voltage you measured is low. This can be caused by a defective battery or poor connections. I'd suggest disconnecting, cleaning, and reconnecting your battery connections. If they're fuzzy with old acid you can use a soft drink like Coke or Dr. Pepper to clean, then thoroughly rinse with clean water afterwards, or you can mix up a solution of baking soda and water to clean with, also rinsing thoroughly afterwards. Also, check the water level in the battery, if it's low you should return it for another one because it will likely be damaged internally from sitting with low electrolyte on the store shelf.
Old July 4th, 2012, 09:37 PM   #3
Gunner
Gunner's Avatar
Thanks for the quick reply!
Def will clean the connections to see if the running voltage will go up
but that doesn't solve the mysterious dead battery
Old July 4th, 2012, 10:09 PM   #4
k-os
Motorcycle(s): 1988 Honda Hawk NT650, 1989 Honda Hawk NT650, 1997 GSXR750 Track Bike
Try going through this diagram to pin-point which component is faulty.
http://www.electrosport.com/media/pd...ng-diagram.pdf
k-os is offline   Reply With Quote
Old July 5th, 2012, 11:05 AM   #5
Originally Posted by Gunner View Post
.........but that doesn't solve the mysterious dead battery
This reading may help you solve the mystery:
http://forum.motorcycle-usa.com/defa...?f=18&m=331125
Problem with the alternator or regulator or electrical or all of the above? Gunner 2008 - 2012 Ninja 250R Tech Talk 14 May 26th, 2012 09:37 AM
Troubleshooting Battery/Alternator Help bkh2 2008 - 2012 Ninja 250R Tech Talk 2 February 20th, 2012 11:45 AM
battery problem? Moto126 2008 - 2012 Ninja 250R Tech Talk 3 February 2nd, 2012 11:10 PM
alternator/battery/charging related problem mrkyo 2008 - 2012 Ninja 250R Tech Talk 6 May 2nd, 2010 05:41 AM
Battery problem? emilyLOVESlime 1986 - 2007 Ninja 250R Tech Talk 24 July 14th, 2009 01:27 PM
