Old August 5th, 2012, 01:14 PM   #1
How to Use a Torque Wrench
I have found this article about how to properly use your torque wrench:
http://www.aa1car.com/library/torque_wrench.htm
Old August 5th, 2012, 02:07 PM   #2
Old August 5th, 2012, 07:37 PM   #3
lgk
good stuff
Old September 11th, 2012, 08:52 AM   #4
nycsteve
Biker
nycsteve's Avatar
Motorcycle(s): 2010 Ninja 250 SE
What would be a good all around(size, lbs-ft) torque wrench for maintenance on the ninjette?
S*** Happens!
Design Stuff | Tumblr
James 1:2-4
nycsteve is offline   Reply With Quote
Old September 11th, 2012, 09:31 AM   #5
flynjay
flynjay's Avatar
I've found that having three is just about right.
1/4" drive , 20-200 in-lb
3/8" drive, 5-80 ft-lb
1/2" druve, 20-150 ft-lb
1/4" drive is sufficent for all internal motor work and adequate for oil changes. If I was only to get one this would be it. Also the small fasteners are the ones most susceptable to failure due to over torque.
3/8" drive is used for motor mount bolts
1/2" drive is used for axle nuts.
Old September 11th, 2012, 10:22 AM   #6
You can see the range of torque values that you will need here:
http://www.ninjette.org/wiki/Fastene...Specifications
1 ft-lb = 12 in-lb
Old September 11th, 2012, 10:28 AM   #7
kingkang204
Motorcycle(s): Bike-less, Can I ride yours?
I had so much trouble with my Harbor Freight Torque Wrench when I was replacing the clutch plates. If you don't mind making a few trips there until you get a good one, then it should work fine(they were cheap, like $20). From what I heard, Craftsmen doesn't warranty their torque wrenches because they're "measurement tools"
Food for thought.
RR stands for Responsible Riding... Right?
kingkang204 is offline   Reply With Quote
Old September 11th, 2012, 10:41 AM   #8
there is a 35 year old 3 foot long, inch drive torque wrench in my garage. its used on excavators i'm told... can you tell me how to use it?
Old September 11th, 2012, 10:57 AM   #9
nycsteve
Biker
nycsteve's Avatar
Food for thought.
I was going to pick up one or 2 from craftsmen because of the warranty. Maybe I'll rethink that. Although the stuff at home depot and lowes are cheaper, I know the replacement for them is normally a hell of a lot easier. Most employee's just don't care and replace whatever tools you bring that are store brand.
S*** Happens!
James 1:2-4
Old September 11th, 2012, 10:59 AM   #10
kingkang204
Check & make sure about the warranty, because thats just what I heard. Returns at Harbor Freight were painless, almost like they were expecting them to break
Old September 11th, 2012, 11:11 AM   #11
harbor freight is like the cyclegear of tools. everybody buys what they need, uses it, then returns it for a full refund.
Old September 11th, 2012, 11:35 AM   #12
02337
Motorcycle(s): 03 ninja 250
I personally have a harbor freight 1/2" torque wrench. I don't trust it under 30ft, in all honesty I don't trust it to exact numbers above that either. It's nice for lugs on the car that's about it. I still am going to purchase a 3/8" dial style torque wrench for precision. I've never left the spring tensioned on my harbor freight not dropped it but if it's something that I need to be exact(say piston rods or main bolts) I just borrow my buddies craftsmen.
I usually just put most of my bolts on my car in a tradition German fashion, güd-en-tight.
02337 is offline   Reply With Quote
Old September 11th, 2012, 11:38 AM   #13
DennyV
I got a gearwrench one that cost me $200 and thinking of picking up another one for around the same price, I use my tools almost everyday so i like the finer things.... Still can't afford the Snap-On Torque wrenches, but I can afford their really nice ratchets =) Pretty much the key to torquing is, to do it in steps, and to do a smooth and steady swing, no tugging or pulling. And biggest no no is dropping your wrench or using it as a breaker bar
DennyV is offline   Reply With Quote
Old September 11th, 2012, 01:29 PM   #14
dino74
dino74's Avatar
The Snap-On's are made by CDI
You can find them for much cheaper than Snap-Ons
CVMA #55
Old September 11th, 2012, 04:53 PM   #15
Originally Posted by 02337 View Post
I personally have a harbor freight 1/2" torque wrench. I don't trust it under 30ft, in all honesty I don't trust it to exact numbers above that either.........
You could verify it:
http://home.jtan.com/~joe/KIAT/kiat_3.htm
http://en.wikipedia.org/wiki/Torque_wrench
Old September 11th, 2012, 05:04 PM   #16
DennyV
thing is, its a pain to get serviced... i like to calibrate my stuff every year and dont like to deal with the companies, with my Gearwrench torque wrench, I hand it to my MAC dealer and he takes care of it. Same if I had a Snap-On torue wrench, I'd hand it to my dealer for him to take care of, Thing is, Gearwrench is owned by Danaher, the same company that makes crap for craftsman, but at the same time the same company that owns MATCO, and as far as i know the gearwrench and Matco torque wrenches are almost exactly the same
Old May 17th, 2014, 07:00 AM   #17
How important is to keep those nuts and bolts properly torqued down?
http://www.boltscience.com/pages/junkertestvideo.htm
A Junker test is a mechanical test to determine the point at which a bolted joint loses its preload when subjected to shear loading caused by transverse vibration:
http://en.wikipedia.org/wiki/Junker_test
On-line converter:
http://www.engineersedge.com/calcula...conversion.htm
Axial force calculator:
http://www.engineersedge.com/calcula...orque_calc.htm
Last futzed with by Motofool; May 17th, 2014 at 08:46 AM.
Old May 17th, 2014, 04:45 PM   #18
harvey58
Motorcycle(s): 2007 250r
I turn wrenches for a living. Once bought a Craftsman torque wrench, click type, did not like the "feel" Both of my torque wrenches are Matco 1/4" and 3/8". Use them a lot. Have NEVER had a failure of rods or heads because of torque failure.
Had a Snap-On before, but could not get it repaired because of age. The lock for the adjuster had failed. (There were others using it as well-DON'T LOAN TOOLS!)
Buy quality, LEARN how to use it! It will serve you well!
Have no problem with H/F stuff. Have a bunch of it at home. However, when you need technical tools, BUY QUALITY!
harvey58 is offline   Reply With Quote
Old May 17th, 2014, 05:40 PM   #19
adouglas
adouglas's Avatar
Motorcycle(s): Aprilia RS660
I bought one of these about 30 years ago. Exact same product as available today. Has never failed me.
Craftsman Digitork.
Old May 19th, 2014, 09:17 AM   #20
kxpower?
kxpower?'s Avatar
Motorcycle(s): Ugly 89 frankenstien special ex250, and the "Zooks" : 1982 GS450 and 1979 GS1000
Just to add/pose a question...
I bought this: http://www.harborfreight.com/1-4-qua...ench-2696.html
Which has a range of 20-200 in-lbs thinking 20 in-lbs is waaay less than I'd ever use, then of course last night as I'm ready to torque my head bolts and I discover the spec is 18 in-lbs! I mean last time I put a head on, it was 44 ft-lbs then an additional 1/4 turn (12-valve vw VR6).
Since I didn't want to put off the work to a later date, I went ahead and set it to 18 by putting it at 20 and backing it out to line up with the 8. Torquing the bolts went fine and the wrench acted like I expected (this is the first time it's been out of the case), but I didn't put the cams on just in case I needed to go back and do something different.
I'm thinking about verifying the accuracy at 18 in-lbs, since it's such a small amount of weight I'd use a fish balance (like this: http://www.digitalscalesaz.com/Jenni...FRJnOgodwVgApw) attached to a 1/4" combination wrench attached to the drive. If it's pretty close I'll leave things alone, if not I'll play with the setting until I find one that calibrates to 18 in-lbs. The scale measures to a tenth of an ounce IIRC, so even using a 6-inch (haven't measured) lever arm the resolution will be on the order of a 20th of an in-lb.
Any thoughts from the gurus? Or is this overkill, like if Kawi figures a +/- 10% error in torque values?
Oh god the bikes are multiplying!!!
kxpower? is offline   Reply With Quote
Old May 19th, 2014, 02:18 PM   #21
cbinker
Track Clown
cbinker's Avatar
MOTM - Sep '15
I have a clicker and love it, i need to get another one with a lower poundage threshold.
TEAM ALFALFA
www.apexassassins.com
Old August 19th, 2016, 05:06 PM   #22
Torquing Fasteners 101
Old August 24th, 2016, 01:20 PM   #23
Rifleman
Old and slow
Rifleman's Avatar
Motorcycle(s): Suzuki TL1000R, Honda CBR600F3, Ninja 250
Yup
http://img.photobucket.com/albums/v620/Ricejocky/achievement.easy.bake.Rifleman_zpscllv4ryl.png
Rifleman is offline   Reply With Quote
Old August 24th, 2016, 06:16 PM   #24
cuong-nutz
cuong-nutz's Avatar
I had to fix my HF special after stretching a bolt from it not clicking.
HalfFast Racing Team
Old August 24th, 2016, 07:48 PM   #25
What the reason for the lack of clicking was and how did you fix it?
Old August 24th, 2016, 08:59 PM   #26
JohnnyBravo
Certifiable nontundrum
JohnnyBravo's Avatar
MOTM - Sep '13, Sep '16
Looks like he had a screwdriver stuck in it
Old August 24th, 2016, 10:50 PM   #27
cuong-nutz
cuong-nutz's Avatar
I had backed off on the adjuster too far and the clicker barrel rotated the opposite way locking the pivot from clicking. The barrel has ball bearings. After I cleaned it and lubed it up, the clicks are loud and solid without mistake.
Haha, the screwdriver is pointing to a pin that keeps the adjuster barrel from backing out fully. On other rebranded ones, there's a screw or a set screw thst removable so you can r n r it. I had to use brute force to remove mine.
Old August 28th, 2016, 06:16 AM   #28
InvisiBill
EX500 full of EX250 parts
InvisiBill's Avatar
https://getyarn.io/yarn-clip/embed/9...?autoplay=true
Old October 23rd, 2016, 04:08 PM   #29
kindboy
kindboy's Avatar
Motorcycle(s): 06 Ninja 250
Real newbie question here. I changed my oil filter and motorcycle oil in preparation for winter. I set the torque wrench to 14.5 ft/lb and tightened the drain plug and filter bolt until I heard the click.
Just want to make sure here, you're still able to continue tightening using the torque wrench but should not as the "click" tells you that the bolt is tightened to the torque that was set on the wrench? It was my first time using the torque wrench and although I heard the audible click it wasn't too loud. Now I'm just a bit worried if I used it correctly or not!
kindboy is offline   Reply With Quote
Old October 23rd, 2016, 04:23 PM   #30
Flying
Stop when you hear or feel the click.
Old October 23rd, 2016, 04:54 PM   #31
adouglas
adouglas's Avatar
Yes, very important to recognize that at low torque settings, you won't hear anything. You'll feel the wrench yield and hit the stop. The "click" you hear at higher torques is just that same phenomenon happening with enough force to be audible.
Just for grins, set the wrench to low torque and go test it on some bolts to experience what that silent "yield" feeling like in a safe setting.
Don't forget to reset the wrench to its minimum before storing it, or it'll go out of calibration over time.
Old October 23rd, 2016, 06:42 PM   #32
kindboy
kindboy's Avatar
That's a great idea. Thank you for the suggestion!
Torque Wrench Driddle 2008 - 2012 Ninja 250R Tech Talk 17 July 15th, 2013 09:32 PM
Torque Wrench koenigcitizen 2008 - 2012 Ninja 250R Tech Talk 16 October 16th, 2011 08:11 AM
Torque Wrench JLinde1339 1986 - 2007 Ninja 250R Tech Talk 16 September 18th, 2011 05:40 PM
torque wrench tinng321 Off-Topic 2 June 28th, 2010 02:31 PM
Torque wrench Betlog Off-Topic 7 March 12th, 2010 08:55 PM
