Old February 6th, 2013, 03:18 PM   #1
Racer x
Racer x's Avatar
MOTM - Sep '18, Feb '16
Takai Coils
I got the Takai coils
To get the most out of all the modifications I have made. I need to upgrade the ignition coils. These also save allot of space.
They are a stick type coil over plug design.
http://www.takai-racing.com/main/ignition_coils.htm
I got the kit and all it is a simple wiring harness to adapt it to the 250 Ninja.
Worlds fastest 250 ninja
Last futzed with by Racer x; February 6th, 2013 at 04:24 PM.
Old February 6th, 2013, 04:13 PM   #2
i'm wondering if they give coil specs? wire gauge, winding count? trying to find more info about these but can't see much... their measurements such as "Q-Factor" are new to me and i'm wondering exactly what it means...
edit: http://en.wikipedia.org/wiki/Q_factor
what i took away from this: good coils have smaller distance between field and output (so coilover plugs are better) and the more stable of a field produced by the coil, the longer the collapse of the field takes, meaning a longer spark and more complete combustion
i'm wondering what changes effect the q factor in these plugs... is it the type/gauge of coil wire used? alloy type? i know things like gold or platinum have much higher consistency compared with standard copper coil... maybe thats the difference?
Old February 6th, 2013, 04:20 PM   #3
Racer x
Racer x's Avatar
This is an area where my ignorance shines.
This is the PDF instruction
http://www.takai-racing.com/manual/T...STALLATION.pdf
Give Mark a call. He will be happy to talk to you.
I really need to learn everything there is to know about ignition systems now.
Last futzed with by Racer x; March 9th, 2013 at 09:45 AM.
Old February 6th, 2013, 04:25 PM   #4
im curious what kind of power differences these will make with your all your engine changes... lets see that dyno sheet!
Old February 6th, 2013, 05:53 PM   #5
Racer x
Racer x's Avatar
End of Febuary .
Old February 6th, 2013, 06:30 PM   #6
DaBlue1
DaBlue1's Avatar
Are you going to run these coils in both engines?
Old February 6th, 2013, 06:39 PM   #7
Racer x
Racer x's Avatar
Yes, I will use these coils in any engine I put in this bike.
Old February 7th, 2013, 08:19 AM   #8
Racer x
Racer x's Avatar
I got an answer back from Mark regarding your question.
"For obvious reasons we can’t give out exact details since our ignition coil engineering specifications are proprietary to Takai, but to answer the question as best as I can. To improve our ignition coils we address wire gauge size, wire type, winding count, core materials, core design and field design in our ignition coils vs competitor units. All are of importance when it comes to the best overall efficiency of the ignition coil."
Old February 7th, 2013, 09:31 AM   #9
Been doing more reading. Apparently they tune the field volume using combinations of different conductors at different stages of the coil, so the primer coil will be a small copper coil and then the return coil to catch the field collapse will be some fancy super low resistance coil like gold or platinum.
They claim in their marketing fluff they use a super conductor but that's a lie. Obviously they haven't broken the laws of physics and they aren't using a vht sc. So I believe the big difference (only real difference vs the Kawi coil over plugs is in the collapse coil material (gold or platinum instead of copper) and the wiring from the coil to the plug.
Old February 8th, 2013, 01:01 AM   #10
tubarney
You confuse the s*** out of me. Lets just wait for the dyno results.
Old February 8th, 2013, 06:36 AM   #11
DaBlue1
DaBlue1's Avatar
So, umm...I take it these don't emit a Takai-on Pulse?
Old February 8th, 2013, 07:03 AM   #12
Racer x
Racer x's Avatar
I do t care if they are full of gofer guts. I just need them to work.
Old February 15th, 2013, 08:48 AM   #13
Racer x
Racer x's Avatar
Some of the cutting edge technology in Takai coils.
http://en.m.wikipedia.org/wiki/Carbo...ubes#section_2
Old February 15th, 2013, 10:59 AM   #14
hah. they mean bulk carbon nanotubes. they take a metal substrate and coat it in carbon nanotubes to improve its properties. but the individual tubes are small and completely misaligned. to build a single nanotube coil large enough to power a spark plug would cost so much.... think hundreds of thousands of dollars of lab work. that is definitely what they are referring to in their marketing when they talk about "super-conductor"... in certain instances a single carbon nanotube (not bulk shake nanotubes) comes close to acting like a super-conductor but its not really accurate to call it a super-conductor. and calling bulk nanotube shake coated wire a super-conductor is kind of a joke... definitely better than most coils though.
Old February 15th, 2013, 11:39 AM   #15
GlassAnkles
GlassAnkles's Avatar
Motorcycle(s): 02 zx-12r, 13 zx-10r abs
those look sweet, i dont care if they produce little or no gains......it just nice to get rid of the old fashioned/space wasting pack.
GlassAnkles is offline   Reply With Quote
Old February 27th, 2013, 08:50 PM   #16
Racer x
Racer x's Avatar
I have to give a total thumbs up to the Takai coils. No more surging or power loss. Smooth power to the rev limit. And I can pull the plugs without pulling the tank. That is so cool. I was able to tune 5 hp more and I can get more later with these coils. I am very very happy with them.
Old February 27th, 2013, 09:05 PM   #17
Good!
Eric, when's the Ohio Mile this year? I wasn't able to make it last year because it was at a bad time for me. If it works out with my schedule this year, I'd love to come watch you make a pass or two on that thing. I've really enjoyed reading about your progress and experiences in building it.
Old February 27th, 2013, 11:45 PM   #18
Racer x
Racer x's Avatar
The next run is April 27-28. I am glad you enjoy reading about the bike. I have a lot of fun with it.
Old February 28th, 2013, 05:53 AM   #19
tubarney
Did I read this correctly. You got 5 hp from the coils?
Old February 28th, 2013, 08:10 AM   #20
Racer x
Racer x's Avatar
No I got five hp from the nitrous. But without the coils the engine was surging at 12000 rpm. Because of the stronger coils the engine was still over 52 hp at 13500 when I let off. 55 was the peak at 12000.
Old February 28th, 2013, 08:18 AM   #21
DaBlue1
DaBlue1's Avatar
Which plugs did you use with the coils?
Old February 28th, 2013, 08:34 AM   #22
Racer x
Racer x's Avatar
NGK cr10e with the gap closed up some.
Old May 8th, 2013, 03:52 PM   #23
Racer x
Racer x's Avatar
the yellow clip goes into the end of the plug to hold the metal wire end in place
Old November 29th, 2017, 06:44 AM   #24
maverick9611
"a legend in my own mind"
maverick9611's Avatar
MOTM - Feb '18
is their a certain part # or did you get it for a certain model bike?
"trying not to get old"
Old November 30th, 2017, 03:13 PM   #25
Racer x
Racer x's Avatar
I talked to them on the phone. They sent me the coilss It has been a while. Best bet is to call them.
Old November 30th, 2017, 03:50 PM   #26
maverick9611
MOTM - Feb '18
ok, thanks
will my current stick coil harness hook right up?
Old December 6th, 2017, 06:02 AM   #27
Racer x
Racer x's Avatar
Not sure , but the coils come with plugs you can wire in .
Old December 6th, 2017, 07:44 AM   #28
maverick9611
MOTM - Feb '18
I saw the price and I freaked! maybe i'll stick to my eBay specials. thanx.
Old December 8th, 2017, 03:34 PM   #29
Racer x
Racer x's Avatar
Ya they ain’t cheap. I had a problem with my stock coils. With nitrous the power just flat lined at 40 hp. After changing just the coils I got an eleven hp jump. Then tuned it to to 61hp on its best dyno run. They will jump over a one inch gap and make a cracking sound the is frightening.
Old February 15th, 2018, 06:11 PM   #30
mgentz
Board Member
It would seem that Takai/weaponX is not responding or out of business. @Racer x do you know where I could get extra connectors?
Old February 16th, 2018, 12:07 PM   #31
Ceeloo Yello
Motorcycle(s): 250
I've seen similar conectors for sale on ebay and aliexpress.
Old February 25th, 2018, 05:16 PM   #32
Racer x
Racer x's Avatar
I would try an auto parts shop. They have to be a standard type plug end
Old February 25th, 2018, 05:30 PM   #33
Try mAtching up to some of these:
http://www.easternbeaver.com/Main/El...onnectors.html
http://www.cycleterminal.com/motorcycle-connectors.html
https://www.corsa-technic.com
https://revivalcycles.com/collection...-and-terminals
Old February 25th, 2018, 08:50 PM   #34
mgentz
Board Member
Jonathan, you are awesome. Found just what I needed at Corsa Technic!!!!
How To Bench Test Ignition Coils? ithaca00 2008 - 2012 Ninja 250R Tech Talk 8 April 5th, 2015 10:09 PM
[motorcyclistonline] - Takai (division of WeaponX Performance) Performance Ignition C Ninjette Newsbot Motorcycling News 0 September 30th, 2011 09:30 PM
[sportrider - latest stories] - TAKAI (division of WeaponX Performance) Performance I Ninjette Newsbot Motorcycling News 0 September 29th, 2011 06:10 PM
[motorcyclistonline] - EXACTFIT High Voltage Ignition Coils Ninjette Newsbot Motorcycling News 0 March 9th, 2011 06:00 PM
[sportrider - latest stories] - Cycleworks ExactFit Ignition Coils Ninjette Newsbot Motorcycling News 0 March 9th, 2011 06:00 PM
