December 20th, 2017, 03:47 PM | #1 |
Join Date: Dec 2017 Motorcycle(s): 2010 Ninja 250r Special Edition Posts: 1
2010 250r Repairs
Hello everyone,
Unfortunately yesterday I low sided my 2010 250r on its right side at a decent speed. I did have frame sliders installed they took the brunt of the crash. I took another look at the bike today and was able to replace the frame sliders with the original engine mount bolt. The bike will start and seems to run fine, however there are a few things I am concerned about. When I turn on the left turn signal, both sides come on. When I try to turn on the right side, neither side comes on. Also after running the bike, I noticed a small amount of a mostly clear liquid on the ground under the middle of the bike. Did not smell like gas or brake fluid. Is this normal? I am planning on getting the bike checked out once I get it in ride-able condition (right handlebar is bent). Just wondering if anyone could offer any help? Thank you. |
December 20th, 2017, 05:49 PM | #2 |
Hi Douglas, welcome to the board, it's good to meet you. The liquid is likely to be coolant. Get some on your fingers and see if its properties match antifreeze, which is slightly slippery, but not as much as oil, has a unique smell, and usually has a little of some color of dye in it. Also, take a close look and see if you can find out where it's getting out. Then you'll have a better idea of how to stop it.
As far as the turn signals, maybe one or more wires or connections got knocked loose, or the handlebar switch is damaged. Fixing that is a matter of checking the circuits with a meter and a copy of the wiring diagram. |
[RoadRUNNER] - MotoMojo: Paint Touch-Up Repairs | Ninjette Newsbot | Motorcycling News | 0 | February 9th, 2017 06:30 AM |
Fairing Repairs with PlastiFix | Rustitution | 1986 - 2007 Ninja 250R Tech Talk | 15 | October 7th, 2014 08:57 AM |
Need Lots of Help With Bike Repairs | bkh2 | 2008 - 2012 Ninja 250R Tech Talk | 2 | July 9th, 2012 12:41 PM |
Repairs (Scratches + Bodywork) | AeroXtasy | 2008 - 2012 Ninja 250R Tech Talk | 12 | August 30th, 2011 04:23 PM |
Spare pre-08 Ninja Parts for repairs | herrorara | Items Wanted | 0 | November 30th, 2010 01:34 AM |
