November 21st, 2014, 01:22 PM | #1 |
I love lamp.
Join Date: May 2014 Motorcycle(s): 2007 ninja tooniftyAaaarrrr (250) Posts: 142
Unresponsive throttle (2007 Ninja 250)
MY PRECIOUS NINJA!!! I'll go to warm up my bike like I usually do put it on 3k rpm for 10 seconds then 4k rpm for another ten then I'll roll out. I'll kick it into first gear and it'll work decently well for the first like two stop signs. But after I get to a stop sign and try to roll off my throttle becomes very unresponsive, even if I hold down the clutch halfway and steadily let it gain speed it still doesnt accelerate fast enough. I have to hold the clutch halfway and put a lot of throttle into it before I can even get up to speed otherwise it will just blip for a little bit and then jump up a few thousand rpms. I had to replace the throttle cable a few weeks back but I couldnt get it to fit right so I modified the cable a bit so it would fit into the spot and I had to take out the closing cable as well due to it not doing it's job after I was done. I rode my bike like that for a few weeks and it still rode fine because of the spring thats fitted under the seat throttle. Not sure if that's what's causing the issue but maybe What I did do is I replaced the oil filter and put in some seafoam. Figured it was just a dirty ole carburetor. Still does it though. I haven't been able to ride it out to see if the carburetor would clear out because I'm scared the bike will burn out on me. I didn't change that oil filter for about 3k miles I think (shame). I saw somewhere on another forum that it might just be a kink in the air hose (Kinky hose LOL) But I'm still a newb so tell me what to do!
"we must learn to live together as brothers, or perish together as fools" |
November 21st, 2014, 01:23 PM | #2 |
I love lamp.
Also the engine runs fine when it's in neutral.
November 21st, 2014, 01:30 PM | #3 |
have you checked your spark plugs recently? when was the last time you adjusted the valves?
you probably want the return cable on a street bike... its a safety thing. when you're in a nasty situation and the throttle jams or something sometimes it takes a second or two to realize you need to turn the engine off with the kill switch and clutch it out.
November 21st, 2014, 01:54 PM | #4 | |
I love lamp.
November 21st, 2014, 03:46 PM | #6 |
I love lamp.
November 21st, 2014, 04:47 PM | #8 | |
If OK there, I would drain the bowls of the carbs: http://faq.ninja250.org/wiki/Draining_the_carbs If that fails, disconnect the fuel hose where it enters the carburetors and clean a tiny mesh filter that may be inside the end of the hose. While there, open the tank cap, and blow backwards into that hose while the petcock is open and in reserve. If all the above fails, report back.
November 21st, 2014, 06:43 PM | #9 |
It sounds like a carburetor issue, fuel delivery, or fuel contamination(water).
I'm curious on what issues you had replacing the cables? Also check all fuel lines, petcock is in proper working order, and of course vacuum lines have no leaks/holes, etc, tank vent working, all carburetor boots Is there a fuel filter? Also think about what you've done prior to the event?
November 22nd, 2014, 08:38 AM | #10 |
I love lamp.
Well my oil light is still on but I'm not sure if that's because I haven't run my bike enough.
November 22nd, 2014, 08:52 AM | #11 | |
That's not good. It should go out very quickly after the engine starts. What oil did you use? How did you check the level? Don't ride it if the light stays on. As far as warm-up, keep the choke set so it idles about 2000 when cold. |
November 22nd, 2014, 08:53 AM | #12 |
Huh? Oil light on is not a good sign for sure, it means you have no oil pressure,as the switch is a low one, about 3~5 psi. is it on only at idle? Or when the RPMs pick up? Are You absolutely sure that the oil filter is installed correctly? Didn't leave an o-ring out or something that simple??:???
November 22nd, 2014, 01:22 PM | #13 |
I love lamp.
Well my oil light will light up when I turn my key and start my bike then it will turn off. Remember I'm not a mechanic so no I don't know what a pressurized valve trinkle is.
November 22nd, 2014, 01:23 PM | #14 | |
I love lamp.
November 22nd, 2014, 01:26 PM | #15 |
Don't scare us like that, it's perfectly normal for the light to be on, if the is on, but motor not running/no oil pressure if it's not running, as long as it goes off went it starts and runs, your okay. It Measures pressure not oil level, that's what ththe sight glass is for on the clutch cover.
November 22nd, 2014, 01:28 PM | #16 |
Okay I'm a little lost, pictures please? Did you order the right cable?
November 22nd, 2014, 02:30 PM | #17 |
I love lamp.
Yeah I had a bike shop order it for me because I couldn't find it. I'll post pictures later. but I'm gonna take a look at the air hose tomorrow. The previous owner stripped the screws on the fairings so I dont want to have to take them off just yet.
November 22nd, 2014, 02:59 PM | #18 | |
KAWASAKI EX250 NINJA 250 R 1996 STAINLESS STEEL FAIRING BOLTS http://pages.ebay.com/link/?nav=item...138695&alt=web
November 22nd, 2014, 03:19 PM | #19 |
Okay this is the exact same fairing bolt kit I have,
For Kawasaki EX 250 R 1986-2007 88 92 00 03 06 Full Fairing Bolt Kit CK http://pages.ebay.com/link/?nav=item...583996&alt=web And the best part you can pick your favorite color.
November 22nd, 2014, 03:49 PM | #20 |
Also I did the engine covers as well with this kit,
Stainless Steel Engine Bolt Set EX250 Ninja 250 1986-06 - NGSS-829 http://pages.ebay.com/link/?nav=item...288404&alt=web
November 22nd, 2014, 06:01 PM | #21 | |
I love lamp.
November 26th, 2014, 10:35 AM | #22 | |
Join Date: Nov 2012 Motorcycle(s): Ugly 89 frankenstien special ex250, and the "Zooks" : 1982 GS450 and 1979 GS1000 Posts: 327
Oh god the bikes are multiplying!!! |
November 26th, 2014, 12:14 PM | #23 |
Glad I could help.
November 26th, 2014, 12:38 PM | #24 |
I love lamp.
ok so I've drained the carbs and check out my air hose. But I've found the problem. It was my air filter. Twitch just had a clogged up nose xD
November 26th, 2014, 12:44 PM | #25 |
Awesome deal then, I love happy endings, are you replacing it with a K&N?
November 26th, 2014, 10:58 PM | #26 |
I love lamp.
DUUUHHHH! It feels so good to ride my bike smooth again.
Unresponsive Throttle | xaple | 2008 - 2012 Ninja 250R Tech Talk | 13 | June 28th, 2015 05:38 PM |
2007 250 Ninja for sale | wardie | Motorcycle-related | 7 | February 24th, 2013 07:53 PM |
Just bought a 2007 ninja 250 | dago | 1986 - 2007 Ninja 250R Tech Talk | 12 | March 12th, 2012 06:35 PM |
2007 Ninja 250 - Texas | Apex | Motorcycle-related | 17 | June 29th, 2010 05:35 PM |
2007 Ninja 250 - Kauai | rogue.guineapig | Motorcycle-related | 0 | July 26th, 2009 07:20 PM |
