Go Back   ninjette.org > 2013 - 2017 Ninja 300 > 2013 - 2017 Ninja 300 General Discussion
Old September 12th, 2021, 08:08 AM   #1
Brau110
Motorcycle(s): Kawasaki 650, 300
Ninja 300 Rough idle
I have a 2013 Ninja 300. Did a top end install as I had lost compression. Put it back together and it now starts but it takes a little bit to start. Then once it starts it won’t idle unless you hold the throttle and it runs a little rough. No ticking just doesn’t run smooth or idle. Now it won’t rev past 1000rpm with throttle usage. Any ideas?
Brau110 is offline   Reply With Quote
Old September 12th, 2021, 09:14 AM   #2
One possibility is your cams are not timed properly.
Old September 12th, 2021, 01:54 PM   #3
Vacuum leak
Measure compression to verify your fix
Old September 12th, 2021, 01:57 PM   #4
Vacuum leak
I would think a vacuum leak would be most pronounced at low throttle and fairly insignificant at high throttle. Brou110 says he can't get it over 1,000 RPM even when he opens the throttle.
Old September 12th, 2021, 04:18 PM   #5
Really severe vacuum leak?
Throws off MAP sensor.
Oh yeah, measure MAP sensor output voltage at idle.
Old September 13th, 2021, 07:02 AM   #6
Because you did top-end work - I'd start there.
As noted, check the cam timing. Also check valve clearances.
Something isn't assembled/adjusted properly.
Old September 13th, 2021, 09:17 AM   #7
Also measure all sensors and their wiring:
- IAT and continuity of wire between sensor and ECU connector
- ECT and continuity of wire between sensor and ECU connector
- MAP and continuity of wire between sensor and ECU connector
- TPS and continuity of wire between sensor and ECU connector
- Altitude sensor and continuity of wire between sensor and ECU connector
- tip-over sensor and continuity of wire between sensor and ECU connector
Something's different between when you disassembled engine vs. after re-assembly.
Super Rough Idle On my 2007 Ninja 250 jordanc91 1986 - 2007 Ninja 250R Tech Talk 6 June 8th, 2016 07:14 PM
Rough idle and a couple of misfires tanghonglai 1986 - 2007 Ninja 250R Tech Talk 12 October 21st, 2015 12:54 PM
Rough Idle BartZerv579 1986 - 2007 Ninja 250R Tech Talk 4 March 29th, 2015 11:53 AM
Rough and Low Idle RiderOnTheStorm 2008 - 2012 Ninja 250R Tech Talk 4 March 26th, 2012 07:52 PM
Rough Idle BSNinja250 2008 - 2012 Ninja 250R Tech Talk 2 May 18th, 2010 09:35 PM
