Go Back   ninjette.org > General > Off-Topic
Old October 16th, 2019, 04:16 AM   #1
GreatGreedo
GreatGreedo's Avatar
Motorcycle(s): Ninja 300, CBR 125R (My 1st bike was a 2001 ZX-6R)
Aftermarket Fairings
Hello guys,
Any of you have Chinese fairings on your bike and how do you like them?
GreatGreedo is offline   Reply With Quote
Old October 16th, 2019, 05:47 AM   #2
Worked fine for me. I’m in middle of painting set now.
Old October 16th, 2019, 08:05 AM   #3
GAU-8
Socially inept. Yet FUN!
GAU-8's Avatar
Motorcycle(s): Current machines- 1992 SECA II 600, 2006 Ninja 250, 2008 Ninja 250
Worked fine for me
Just curious, what brand, or seller is it? is it a generic set, that is labeled as many different brands. ( or sevaral companies using the same mold type?) Reason I ask is that I see many aftermarket parts that look exactly the same, yet the names are different. Either by sticker, or simple engravings. Yet other than that, exactly identical. Even dimensionals, are often the same.
How was yours when it arrived? Any real issues you had to adress/fix/hide, before typical prep work prior to painting?
GAU-8 is offline   Reply With Quote
Old October 16th, 2019, 08:56 AM   #4
GreatGreedo
Thanks Guys, I'm looking to buy from this company based in Australia called 12K Motor. They seem pretty honest and say that their fairings are basically the same as the other aftermarket injection molded fairings from China but they have their own painters.
Earlier, I was thinking of buying from Monster Fairings but they were a couple hundred dollars more than 12K Motors (also chinese fairings). The difference is that Monster Fairings would apply a superior paint application process like 12K Motor.
I'll see though, and post pictures on here somehow.
Old October 16th, 2019, 10:44 AM   #5
I got mine from eBay and came in one big box. Each piece was individually wrapped in padding. There was nothing on bodywork itself that had name. Invoice said "XZMT bodywork, Ninja 250R". This particular kit came with rear-seat cap and all inner black pieces as well.
It went together pretty easily. I think A LOT of complaints about ill-fit has to do with user technique. I suspect these folks didn't install all bolts loosely first. But tightened all bolts as they went. Then last pieces end up out of alignment with no way to wiggle earlier pieces to make room.
Most likely there's many factories cranking these things out. Middle-man then calls it whatever they want and re-sells it online. They all probably used original OEM bodywork to make master moulds, so they should be similar. This isn't exactly rocket-science and even backyard fabricator can hand-make one-off copies that have precise fit. I made some moulds to repair 1st-gen '86-87 fairings since my 2nd-set came hacked in half by some racer for unknown reasons. Will post pictures when that project is completed.
Old October 16th, 2019, 06:00 PM   #6
GAU-8
GAU-8's Avatar
Thanks for getting in depth. That's actually what I wanted to hear. I've learned to take most reviews, in general with a grain of salt. (Depending on criteria.)
Thanks for your input!
Old October 16th, 2019, 08:05 PM   #7
GreatGreedo
I'll remember this technique, thanks
"Every saint has a past, and every sinner has a future." ~Oscar Wilde~
How big are the packages for aftermarket fairings? minimatt 2008 - 2012 Ninja 250R Farkles 1 July 14th, 2019 03:25 AM
New Fairings (the aftermarket ones from eBay) T-? 2008 - 2012 Ninja 250R Farkles 36 August 14th, 2013 05:20 PM
Fairings.. Oem and aftermarket JustRidin 2008 - 2012 Ninja 250R Farkles 13 October 12th, 2012 03:19 AM
Aftermarket fairings TFKninja 2008 - 2012 Ninja 250R Tech Talk 19 August 25th, 2011 08:13 AM
Aftermarket Fairings for a red 2009 250r? danjaho 2008 - 2012 Ninja 250R Farkles 2 February 4th, 2011 12:29 PM
