November 9th, 2019, 11:58 PM | #1 |
Join Date: Nov 2019 Motorcycle(s): Kawasaki GPX250r Posts: 7
Cant shift into 1st gear
HI
I just bough my first bike, a 04 Gpx250. Owned it and have been riding it for about a week. The Previous owner had not changed the chain in quite a while. I ordered a new one and in the mean time i though i would give the current one a good clean and lube. I took the front sprocket cover off and gave it a good clean with some kerosene and a old paintbrush. Now no matter what i try i cannot get the bike into fist gear. It will go into second, (and then no other because of the safety) But i cannot get it to go past neutral into first. I have tried changing the angle of the shift leaver but nothing seems to help. |
November 10th, 2019, 10:06 AM | #2 |
Hello Mitchell, and welcome to Ninjette!
Can only change gears out of neutral when engine is running. Also make sure shift-linkages connecting to shift-rod is connected at 90-degrees |
November 10th, 2019, 10:43 PM | #3 |
I did not have the bike running due to cleaning the carbs. however now that its running i still cannot shift into first. I have also found out that i cannot shift into anything above 2nd, Only neutral and second. I am not quite sure what you mean about the shift linkages being at 90 degrees so i have included a picture of them.
https://ibb.co/0fZSMpS I feel like i have done really simple, Like put the linkage on backwards or something. |
November 11th, 2019, 12:08 AM | #4 |
I did the dumb. I had the shift linkage on backwards. Works fine now. Can you confirm that this is the right orientation.
https://ibb.co/SR2F78V Thanks Mitchell. |
November 11th, 2019, 03:42 AM | #5 |
Yes, this is correct.
November 11th, 2019, 06:22 AM | #6 |
Thanks for you help
November 12th, 2019, 10:19 PM | #7 |
Welcome!
Occasional 1st gear issue | wendyjboss | 1986 - 2007 Ninja 250R Tech Talk | 10 | June 1st, 2016 03:20 AM |
Trackday Gear - 1st time | Bigballsofpaint | Motorcycle Gear | 18 | August 25th, 2013 05:40 AM |
Stalling in 1st Gear at stops - HELP!!!!! | kingskater | 2008 - 2012 Ninja 250R Tech Talk | 27 | September 5th, 2012 08:39 AM |
Finding 1st gear? | Focus Mike | 2008 - 2012 Ninja 250R Tech Talk | 38 | August 7th, 2009 01:11 PM |
1st gear locking | mista350z | 2008 - 2012 Ninja 250R Tech Talk | 25 | August 5th, 2009 08:24 AM |
