Old December 29th, 2009, 05:27 PM   #1
g21-30
g21-30's Avatar
DIY Bleeding Brakes - A new method
In my quest to upgrade my front brakes with a Galfer stainless steel line and a ZX-10R Master Cylinder (MC), I acquired a Vacuum Pump and accessories to help with bleeding the brake system.
For the past 40+ years, I have always bled brakes via the manual method, i.e. have someone pump the brake and hold it, while I tediously loosened/tightened the appropriate bleeder valve. Once I used the one-way (one man) bleeder valves, but they disappeared one day!
A few minutes ago, while searching for some info on bleeder valves, I came across ANOTHER technique for bleeding brake systems. Check it out here:
http://www.badweatherbikers.com/buel...42/174272.html
Old December 29th, 2009, 09:39 PM   #2
randomwalk101
self wrencher
randomwalk101's Avatar
Have you tried it? Does it work? Lol
Posted via Mobile Device
Old December 29th, 2009, 11:39 PM   #3
MKlein3004
Fighting Texas Aggie '08
MKlein3004's Avatar
Motorcycle(s): 2008 Ninja 250r (Race), 2005 Kawasaki Ninja ZX-6R 636 (Track), 2005 Ducati Monster 620 (Street)
Now thats interesting
MKlein3004 is offline   Reply With Quote
Old December 30th, 2009, 01:55 AM   #4
komohana
komohana's Avatar
Motorcycle(s): 05 GSX-R 600 2003 EX250: Woodcraft Bars, Levers, Mirrors, Shim'd Mixture, Synthetic, '08 Rear Shock
trippi method
thanx for sharing that
Remember when sex was safe
and motorcycles were dangerous?
komohana is offline   Reply With Quote
Old December 30th, 2009, 04:25 AM   #5
sharky nrk
Fighting Texas Aggie '05
sharky nrk's Avatar
speed bleeder ftw - tried the mighty vac - fail and sitting there manually pumping and closing - fail.
Old December 30th, 2009, 07:26 AM   #6
g21-30
g21-30's Avatar
I'm willing to bet you had a leak from one of the bleeder valves. As kkim would say "Ask me how I know!"
Old December 30th, 2009, 08:43 AM   #7
sharky nrk
sharky nrk's Avatar
are you referring to the speed bleeders or when using the other methods - I know of no leaks on the vehicles using the speed bleeders and see no signs of it. As for the other methods, I always use thread tape, and the brakes always get bled properly - it just takes a while
Old December 30th, 2009, 08:51 AM   #8
g21-30
g21-30's Avatar
I was referring to the use of the mity-vac. Turns out the master cylinder bleed screw was leaking around the the threads. Without my vacuum, I would have never found that. I will use teflon tape from now on!!
Bleeding brakes - simple and easy Somchai 2008 - 2012 Ninja 250R Tech Talk 28 March 31st, 2015 12:10 PM
[RoadRUNNER] - MotoMojo: Bleeding Brakes Ninjette Newsbot Motorcycling News 0 April 15th, 2014 09:40 AM
Bleeding brakes but lever doesn't stiffen after pumping? chsonnu 2008 - 2012 Ninja 250R Tech Talk 12 August 8th, 2013 01:46 PM
SS lines and bleeding the brakes Aggrotech 2008 - 2012 Ninja 250R Tech Talk 13 July 16th, 2013 08:31 PM
Bleeding Brakes. Possible air in my system? Ken 2008 - 2012 Ninja 250R Tech Talk 16 March 25th, 2009 03:07 PM
