June 5th, 2021, 04:18 PM | #1 |
Join Date: Nov 2020 Motorcycle(s): GL1500, ninja 250 Posts: 11
Gold valve emulators.
Good day,
Upon installation with sonic springs and emulators, does the mini spring and the cap go back on the damping rod? Followed instructions here: https://faq.ninja250.org/wiki/Instal...rs_and_springs Make no mention of that. Anyone? Thank you, J |
June 6th, 2021, 08:47 AM | #2 |
If you’re talking about the top out spring, you probably want to keep that. I have seen them replaced with rubber before though.
June 7th, 2021, 04:51 AM | #3 |
Here are some pics
June 7th, 2021, 10:54 AM | #4 |
That spring is the top out spring, and you want that. The “cap” at the bottom of fork leg is to help with bottoming out( creates an all most hydraulic lock in the last bit of travel) want to keep that too
Just picked up some gold valve emulators | psych0hans | 2008 - 2012 Ninja 250R Tech Talk | 2 | July 17th, 2012 11:34 AM |
Gold Valve Emulators | KChatham | 2008 - 2012 Ninja 250R Tech Talk | 4 | January 4th, 2012 11:03 PM |
