Old November 24th, 2011, 05:36 PM   #121
headshrink
headshrink's Avatar
Originally Posted by etiainen View Post
It's the bolt of the camshaft cover, I don't have a pic right now, cause it's hard to move around in there.
http://i291.photobucket.com/albums/l...se_Caution.jpg
It's the red circle on the top left where the thread is stuck inside.
The red circles are the little stand-off thingys, but I assume you mean the bolt hole near it.... If it were mine, I would buy an extraction kit, and go from there. Otherwise you are looking at ebay for a new engine. You COULD look at just the top-end, but IMO you might as well get the whole thing together, as this is a bit simpler and gives you less to mess up. But FIRST try an extraction kit. Take your time to do right (remove engine).
Old November 24th, 2011, 05:41 PM   #122
etiainen
CBR250R Traitor
etiainen's Avatar
Motorcycle(s): 2011 Red CBR250R 2009 Ninja 250r SE(With 2008 Fairings)(sold)
Yeah, it's the bolt sorry, what do you mean look at the top end only?
etiainen is offline   Reply With Quote
Old November 24th, 2011, 07:41 PM   #123
hoodadooda
MotorbikeLuv
hoodadooda's Avatar
Motorcycle(s): 2009 Kawasaki Ninja 250 (sold), 2006 Daytona 675 in Tornado Red (sold), 2007 Ninja 650
Just finished my first valve job, anything in particular I should look out for in the next couple of days? Btw, the bike started fine, but one of the coolant hoses wasn't tightened up enough and some coolant spilled onto the engine. Tightened her up enough to stop the leak +1/8 turn of the wrench, should be fine, right?
One thing is for sure though, I definitely wish I had a garage to work in...
I think he means the cylinder head where the cams sit and where your bolt broke off.
http://www.bikebandit.com/houseofmot...7969#sch580492
Correct me if I'm wrong headshrink
hoodadooda is offline   Reply With Quote
Old November 24th, 2011, 07:59 PM   #124
etiainen
CBR250R Traitor
etiainen's Avatar
I have a garage but no working bike
Old November 24th, 2011, 09:40 PM   #125
headshrink
headshrink's Avatar
You explained it better than I could.
Old November 26th, 2011, 10:33 AM   #126
etiainen
CBR250R Traitor
etiainen's Avatar
Are floor jacks the only way to go to remove the engine? They seem pretty pricey:/
Old November 26th, 2011, 01:26 PM   #127
headshrink
headshrink's Avatar
Probably... you can get cheapo ones from Walmart or auto parts stores.
Old November 26th, 2011, 02:03 PM   #128
etiainen
CBR250R Traitor
etiainen's Avatar
Search time I guess.....
Old November 26th, 2011, 02:07 PM   #129
etiainen
CBR250R Traitor
etiainen's Avatar
Think this cheapo jack could work?
http://www.homedepot.com/h_d1/N-5yc1...atalogId=10053
Old November 27th, 2011, 01:49 PM   #130
headshrink
headshrink's Avatar
Yes. Just put a scrap of wood between the jack and motor.
Also, have something worked out to set the engine down on. I've heard some use spare tires. I used a furniture dolly.
Old November 30th, 2011, 12:19 AM   #131
cuong-nutz
cuong-nutz's Avatar
Bumping this up. I'm past due for a valve job....
HalfFast Racing Team
Old November 30th, 2011, 12:50 PM   #132
Honko
Honko's Avatar
Motorcycle(s): 2010 Green SE
Want to help me with mine???
Honko is offline   Reply With Quote
Old November 30th, 2011, 03:56 PM   #133
hoodadooda
MotorbikeLuv
hoodadooda's Avatar
I felt uneasy going into my own engine for this service lol, so not too sure if I would be much help. Just follow these videos to the letter, take your time, and don't put too much force into taking anything out or putting it back in. Also, I cannot stress enough how important it is to have a decent torque wrench in inlbs on hand when putting things back together.
Besides that, there has to be someone closer to ya who could assist
We have quite a few members in NoVa AND a handful of them seem to be the mechanic type. cerberusrex25 comes to mind.
Old December 8th, 2011, 12:03 AM   #134
cuong-nutz
cuong-nutz's Avatar
doing my valve lash check right now. The 1T and 2T marks are are pretty hard to see.
Old December 8th, 2011, 08:37 AM   #135
cuong-nutz
cuong-nutz's Avatar
My current valve lash readings:
Exhaust:
.254
.229
.203
.178
Intake:
.178
.203
.152
.152
Question:
so do you only replace the shims if it's out of spec? Wouldn't you want to replace the shim that are on the tight/loose end of spec as well?
Old December 10th, 2011, 10:37 AM   #136
etiainen
CBR250R Traitor
etiainen's Avatar
Back to this today, my friend's dropping off a floor jack. Advice/suggestions for engine removal/re-installation, and a time frame of how long this usually takes. I ge the joy of trying to remove that bolt thread too.
Old December 10th, 2011, 12:19 PM   #137
headshrink
headshrink's Avatar
Use the SM, be slow and methodical, don't even think about taking it off the bike without help (you can do everything to that point yourself), have a place prepared to set the removed engine, beer should be drunk cold. The actual removal doesn't take much time.... it is the removal of everything else that is most of the time it will take.
Note: when you remove your engine from the frame, it will flex a little. So when you put it back in, you'll have to sweet talk it a bit to get the mounting bolts to line up. It really isn't that bad though.
Old December 10th, 2011, 03:52 PM   #138
etiainen
CBR250R Traitor
etiainen's Avatar
Do I have to remove the engine sprocket bolt? I don't have a 27mm socket. Can I just remove the chain, will that suffice for removing the engine?
Old December 10th, 2011, 03:58 PM   #139
cuong-nutz
cuong-nutz's Avatar
Yes you can remove the chain so you don't have to remove the sprocket.
Old December 10th, 2011, 04:05 PM   #140
why bother taking the enigne out?
Old December 10th, 2011, 04:15 PM   #141
etiainen
CBR250R Traitor
etiainen's Avatar
I can't reach the cam cover bolt thread with the frame in the way.
Old December 10th, 2011, 04:23 PM   #142
i see you broke a bolt off in there... sucks
Old December 11th, 2011, 01:49 PM   #143
etiainen
CBR250R Traitor
etiainen's Avatar
Finally, some good news, engine dropped today, bolt removed and engine back inside.
Posted via Mobile Device
Old December 11th, 2011, 02:51 PM   #144
headshrink
headshrink's Avatar
Great job!
You were able to grab it with something, with no drilling?
Old December 11th, 2011, 03:09 PM   #145
etiainen
CBR250R Traitor
etiainen's Avatar
Yeah, luckily, got some small flathead screwdrivers and turned it out
Old December 11th, 2011, 05:17 PM   #146
headshrink
headshrink's Avatar
I'm glad it all worked out. It must be nice finishing the valve adjustments out of the frame Now to get the engine back in.....
Old December 11th, 2011, 06:01 PM   #147
paulforaname
paulforaname's Avatar
Motorcycle(s): Ninja 250R
hey all,
well my bike has 20k and got the bike 2nd hand and from memory believe the valve adjustment should be done on the 15k service?? and got it with 16k on it,well its starting to make a rattle at cold idle and think its time, was going to do myself but also half thinking of paying someone else to do it.. I'm in Melbourne Aust and if anyone in Aust knows what I should pay can you let me know so can weight up if to do myself ..even ballpark figure .. Im prety mech minded and so is my bro and dad so between us shouldnt be too many headaches but just dont have the time at the moment and i do my work in my dads garage but he's got a car in pieces at the moment so would have to wait 2 months to do myself and if not too expensive then would prefer to get done asap..
paulforaname is offline   Reply With Quote
Old December 11th, 2011, 06:28 PM   #148
headshrink
headshrink's Avatar
Send me airfare and I'll do it for free
Old December 11th, 2011, 08:30 PM   #149
etiainen
CBR250R Traitor
etiainen's Avatar
I actually only had the jack for the day so I actually put it back in as soon as I got the bolt out..lol
Old December 11th, 2011, 10:11 PM   #150
etiainen
CBR250R Traitor
etiainen's Avatar
So, its possible that in all this engine confusion(the uncovered cam came loose and I had to put it on, that the timing may have gotten messed up. Should I get it back to 2T and have the intake and exhaust marks line up just in case it's off? Will that ensure the timing is correct?
Old December 11th, 2011, 10:29 PM   #151
paulforaname
i could probably get a life time of valve adjustments for the cost of a return flight from LA to Melbourne .. maybe if you dont mind hopping inside a cardboard box and being posted to Melbourne via UPS then might take you up on your offer ..lol
Old December 11th, 2011, 11:25 PM   #152
headshrink
headshrink's Avatar
Well, I do have a place in NSW, but I don't get there very often. I'd settle for a jet from a local airport, but you'd likely have to wait a few years.
BTW: I've always wondered.... is the 626 based on a real place in Melbourne?
Old December 11th, 2011, 11:46 PM   #153
cuong-nutz
cuong-nutz's Avatar
Yeah, just got back to 2T and have the cam marks lined up. Just make sure that your chain is tensioned properly so it doesn't slip. So make sure the cam caps are back on and the chain is tensioned and turn it over by hand a few times to make sure it's still in alignment.
Old December 12th, 2011, 08:12 AM   #154
etiainen
CBR250R Traitor
etiainen's Avatar
Ok thanks, what do I do if its not in alignment??
Old December 12th, 2011, 06:49 PM   #155
cuong-nutz
cuong-nutz's Avatar
If you positive that the cams are out of alignment (you rotated the crank over twice lining up the marks on 2T) you have to undo the chain tension, remove caps, reposition the cams again so that they align and put the chain back on, tension it, and turn the engine over by hand again and check alignment over.
Old December 13th, 2011, 10:41 AM   #156
headshrink
headshrink's Avatar
It is a pain, but you are going to want to be slow, and methodical. I found that once you tighten down the cam caps, you will want to double-check the chain, because as the caps press the cams into position, the chain can sometime unseat itself..... I really liked the idea of marking your chain for reference. Wish I would have thought of that.
Be as exact as you can. For some reason most of the DIYs point the white dots together, but unless you REALLY understand what it is doing, and the relation to other aspects of timing, I suggest sticking with the manual. I have done both without a problem, but now stick to the book because I loose some of it between valve jobs, forget, and have to relearn.
It may be a good idea to mark the end pins on the chain before you remove it. That way you won't even have to count them when you put it back on.
Old December 13th, 2011, 01:08 PM   #157
etiainen
CBR250R Traitor
etiainen's Avatar
Um, one question though, since there are two 2T's, how do I know I've aligned with the correct 2T?
Old December 13th, 2011, 02:15 PM   #158
cuong-nutz
cuong-nutz's Avatar
When you align it, your cam gears will look like this:
Put the exhaust cam in first so that you remove all the slack and then the intake cam.
Per Vex's DIY: "With any 4-stroke engine you'll hit "2|T" TWICE per complete engine cycle. I made sure that I had the engine on "2|T" (which is cylinder #2 at TDC) at the end of i's compression stroke. The camshafts should line up as you can see in the picture above. Notice the two white dots face eachother? Timed!"
Old December 13th, 2011, 03:00 PM   #159
etiainen
CBR250R Traitor
etiainen's Avatar
How do I know when I'm at the end of it's compression stroke?
Old December 13th, 2011, 03:28 PM   #160
cuong-nutz
cuong-nutz's Avatar
At the end of the compression stroke is when the piston is at or almost at top dead center. The intake valves and exhaust valves are closed. If you look at the first picture of my previous post, you will noticed that the cam profile (rounded pyramid) is about to compress the exhaust valve open(far end near the cam gear). If you look across from the exhaust cam, you will see that the intake valve has to travel 180* before it opens up again which would be the intake stroke.
Valve Adjustment Video? MisterLu 2008 - 2012 Ninja 250R Tech Talk 17 August 19th, 2014 12:54 PM
Valve Adjustment quarterliter 1986 - 2007 Ninja 250R Tech Talk 7 June 25th, 2013 05:32 PM
1st Time Valve Adjustment Guidance Needed (video) az3200 1986 - 2007 Ninja 250R Tech Talk 33 May 21st, 2013 06:31 AM
Valve Adjustment to Come Soon! gilmorec61 2008 - 2012 Ninja 250R Tech Talk 54 June 22nd, 2012 03:43 PM
Valve Adjustment-Really Tight adjustment screw? mikesova 1986 - 2007 Ninja 250R Tech Talk 5 May 2nd, 2010 04:57 AM
