Old January 29th, 2016, 07:56 AM   #1
peperino
Motorcycle(s): 250R
2 more q's. Carb removal and clutch switch
Hey guys, it's me again. 2012 250r.
I keep taking the bike apart to make sure everything is fixed, I have 2 q's.
1) How do you take out the right side carb airbox clamp ? (its a 3mm allen bolt). Seems like I get blocked by the frame. How to access it? I'm trying with a T wrench without luck, it won' fit properly
2) My bike won't start in 1st even with the clutch in. I checked the clutch switch and seems to be running fine. I bridged the clutch connector to try to start the bike in 1st but nothing happens. Where to look further?
Thank you!
peperino is offline   Reply With Quote
Old January 29th, 2016, 08:18 AM   #2
Floki
Motorcycle Nurse?
Floki's Avatar
Motorcycle(s): 2010 250R, 1998 Ducati 748L #77/100
1. Ball end hex heads help when you can't go straight in. They allow you to access it at a slight angle
2. Is the kickstand up or down?
Floki is offline   Reply With Quote
Old January 29th, 2016, 08:21 AM   #3
peperino
Motorcycle(s): 250R
Would you mind showing me a picture of the tool you mention?
KS down or up, no difference.
Afaik when you pull the clutch in the bike should start no matter what position the KS is in anyway
Thank you
Old January 29th, 2016, 08:26 AM   #4
HoneyBadgerRy
HoneyBadgerRy's Avatar
Thank you
I belive this is what he is taking about.
Old January 29th, 2016, 08:28 AM   #5
peperino
Motorcycle(s): 250R
Oh damn
So that ball end will fit the 3mm allen bolt?
Old January 29th, 2016, 08:33 AM   #6
HoneyBadgerRy
Oh damn
Yeah, you can get a 3mm allen with a ball end, and the end will fit the hole and help if the allen is angled slightly.
Old January 29th, 2016, 08:34 AM   #7
peperino
Motorcycle(s): 250R
Awesome thanks
Old January 29th, 2016, 08:34 AM   #8
Floki
Motorcycle Nurse?
Floki's Avatar
Yeah they come in all sizes. I have ones that go on a ratchet so you can get leverage.
Also the bike has a KS safety switch which kills the bike if you put in in gear with the KS down. Start it in neutral and shift into 1st with it down. This would prevent you from starting with the clutch in if it was down normally.
Check the wiring. My switch broke in a lowside.
Old January 29th, 2016, 08:39 AM   #9
peperino
Motorcycle(s): 250R
Thank you
That is true, but I tried both KS up and down. With the KS up, you should be able to start the bike in 1st gear with the clutch pulled in. That's not happening in my bike.
I will recheck, thank you
Old January 29th, 2016, 09:07 AM   #10
SLOWn60
n00bie to wannabie
SLOWn60's Avatar
Motorcycle(s): 2012 250R (Red), 2005 VFR800A (Red), CRF450X (Red), 2012 F800GS (Wants to be Red!)
MOTM - Nov '15
Unless a switch, connector or wiring is faulty.
The Smart Money: #1 - ATGATT, #2 - Training (machine skills and survival skills), #3 - The bike; whatever floats yer boat with the money you have left over
SLOWn60 is offline   Reply With Quote
Old January 29th, 2016, 10:01 AM   #11
peperino
Motorcycle(s): 250R
I will re-test the connector, when I jumped the cable my KS was down so the test was invalid. Will re-test thank you !
Old January 29th, 2016, 05:37 PM   #12
peperino
Motorcycle(s): 250R
Alright, so I managed to get the carbs out. Hard, but doable.
Now, the previous owner installed a #100 main jet. Should I bother trying to get the standard #98 as per the manual or leave it like it is? The bike has the stock muffler. Not sure about the needle, and pilot jet values, I still have to check.
Also, should the jet holder have only 2 holes in it? I was expecting to have many holes in it.
Thank you
Old January 31st, 2016, 05:15 PM   #13
peperino
Motorcycle(s): 250R
Guys, is there a trick to install the air filter side of the carb? I'm struggling to get the boot properly seated on that side, when I tighten the clamps I can clearly see some holes and it is not a smooth fit.
Any trick? I have the air filter box loosen and can wiggle a bit but I can't seem to get a perfect fit
Old January 31st, 2016, 05:15 PM   #14
peperino
Motorcycle(s): 250R
Btw, not sure if that matters but I rotated the clamps so I have the adjusting screw on top instead of bottom. Is that ok ?
Old January 31st, 2016, 06:49 PM   #15
BernawanFR
BernawanFR's Avatar
Motorcycle(s): Kawasaki Ninja 250R 2011
When I'm on the 1st gear, engine stops if I kick the KS down (KS wiring simply stops the engine)
But somehow my bike won't start on the 1st gear with clutch pulled (KS up).
I don't mind as long as the bike can start and run as it should.
BernawanFR is offline   Reply With Quote
carb removal mikedabike64 2008 - 2012 Ninja 250R Tech Talk 8 November 19th, 2013 08:34 AM
Help me please! Carb Removal (I'm Stuck) zach 2008 - 2012 Ninja 250R Tech Talk 30 August 13th, 2013 08:17 PM
Kickstand switch removal cookiebug79 1986 - 2007 Ninja 250R Tech Talk 9 April 3rd, 2013 06:37 PM
Ignition switch removal rkildu 1986 - 2007 Ninja 250R Tech Talk 2 June 1st, 2012 03:48 PM
Do shogun sliders get in the way of carb removal? adouglas 2008 - 2012 Ninja 250R Tech Talk 3 April 29th, 2010 07:53 AM
