Old July 25th, 2012, 11:54 AM   #1
DaMan22
Motorcycle(s): Ninja 250r
turn light indicator stopped working...
I have the proton flush mount lights and the Blaster-X Integrated LED Tail Light installed on my bike. i also installed the no-cut diode kit that came with it and the electronic flasher relay... everything worked for a while and then i noticed that my flasher indicator on the bike didn't blink sometimes when i used the signals and the proton lights blinked dim... the flasher relay was also making a "click click click click" sound rather then the "click click...click click" so i changed out the flasher relay for a new one and now it works, but the rear turn signals strobe with the proton lights, and the gauge indicator for the flasher still doesn't work... any thoughts?
DaMan22 is offline   Reply With Quote
Old July 25th, 2012, 01:19 PM   #2
DaMan22
Ok so I took the bike apart and re checked all the connections... I grounded the ground wire from the diode kit directly to the batt this time and re installed the original electronic relay i had and everything including the gauge light worked... I'm pretty sure the relay is going bad though bc sometimes it will work fine and other times the lights will blink dimly... Could that be right?
Old July 25th, 2012, 02:04 PM   #3
broilmebk
broilmebk's Avatar
Motorcycle(s): '12 ninja 250r
I don't think the relay has to do with the dim blinking. It just sounds like you didn't have a proper ground
broilmebk is offline   Reply With Quote
Old July 25th, 2012, 02:31 PM   #4
DaMan22
It's grounded directly to the batt
Old July 26th, 2012, 09:51 AM   #5
CThunder-blue
ModMy250.com
CThunder-blue's Avatar
Trying connecting your stock front signals and see if the same thing happens. If it doesn't, then it might be your protons.
The www.ModMy250.com guy
Old July 26th, 2012, 06:12 PM   #6
DaMan22
Figured it out! One of the diods in the "no cut diode kit" was bad... Cut them out and put two of my own in and boom worked like a champ!
Old July 26th, 2012, 07:52 PM   #7
CThunder-blue
ModMy250.com
Cool!
Indicator Problem - Turn Signals Not Working alex192 2008 - 2012 Ninja 250R Tech Talk 6 December 7th, 2014 09:56 AM
Turn signals stopped working. Insan3guy General Motorcycling Discussion 1 October 15th, 2013 10:17 PM
Blinkers just stopped working coluk33 1986 - 2007 Ninja 250R Tech Talk 8 May 6th, 2013 09:13 PM
tach stopped working -.- ajaygraci 2008 - 2012 Ninja 250R Tech Talk 23 March 31st, 2012 10:55 PM
Turn Signals Stopped Working! DisciplesHeart 2008 - 2012 Ninja 250R Tech Talk 18 March 21st, 2012 08:45 PM
