September 17th, 2010, 12:14 PM | #1 |
Join Date: Feb 2010 Motorcycle(s): kawasaki ex 250 f7 Posts: 11
is this suspension upgrade possible????
i saw in youtube a video someone put a zx6 rear suspencion on a ninja 250
my cuestion is A REAR SHOCK OFF A 2001 SUZUKI GSXR 1000 could fit in a ninja 250????? Thanks for your answers !!!!!! Saludos form argentina |
September 17th, 2010, 12:58 PM | #2 |
You need to take measurements of the shock mounts and see if it is the same dimension as the 250 mount. Even then you may have to do some shimming or fabricating to make it work.
September 17th, 2010, 02:19 PM | #3 |
darrell85
Join Date: Jul 2010 Motorcycle(s): 2001 250 ninja Posts: 91
The zx6 shock conversion is actually a fairly common upgrade for the pre gen 250's, it gives a little stiffer suspension and about an inch of lift, though I have never heard of the gsxr 1000 shock on a 250 the gsxr600 will work. there is a writeup on this over at the 250 ninja.org faq
September 18th, 2010, 01:27 PM | #4 |
thank you guys for yours answers help my a lot
now a 09 KAWASAKI ZX6R REAR SHOCK can fit and work???? or have to be an especific year suspencion??? Thanks again |
September 18th, 2010, 01:40 PM | #5 |
October 3rd, 2010, 03:33 PM | #6 |
Join Date: Jul 2010 Motorcycle(s): 2005 Kawasaki Ninja 250R Posts: 66
You might think about trying a newgen 250 rear shock. Its stiffer and a direct replacement with no modifications.
Posted via Mobile Device |
Suspension upgrade | jgcable | 1986 - 2007 Ninja 250R Tech Talk | 13 | February 13th, 2015 02:22 AM |
Advice on Suspension Upgrade? | Sykes92 | 2008 - 2012 Ninja 250R Tech Talk | 19 | May 20th, 2014 12:26 PM |
300 rear shock upgrade and front suspension | agentbad | 1986 - 2007 Ninja 250R Tech Talk | 1 | January 22nd, 2014 12:07 PM |
Front suspension upgrade | Rollingmenace | 1986 - 2007 Ninja 250R Tech Talk | 3 | October 4th, 2013 07:42 AM |
New gen suspension upgrade | randomwalk101 | Ninjettes At Speed | 23 | October 18th, 2010 09:42 PM |
