Go Back   ninjette.org > Marketplace > Motorcycle-related
Old July 4th, 2013, 08:17 AM   #161
LoD575
LoD575's Avatar
Motorcycle(s): 2012 Ninja 250, 2006 Ninja ZX6R-636
I just ordered this kit today.
LoD575 is offline   Reply With Quote
Old July 6th, 2013, 10:42 AM   #162
SSG54
SSG54's Avatar
@RaceTech Electric any ideas on why the turn indicator only displays when i am turning right, but when i am turning left the turn indicator on the display does not go off? but the signals are all working perfect.
SSG54 is offline   Reply With Quote
Old July 7th, 2013, 04:57 AM   #163
dandj86
dandj86's Avatar
Motorcycle(s): '09 Ninja 250R
Strange problem you have there! I finished installing my gauge and voltmeter last week and everything's working fine. No issues like what you have mentioned
Do you have stock signals front and back? And the signals are working fine and flashing and turning off like normal when you use the controls on the handlebar? ie; the only issue is how the signals are displayed on the new gauge?
dandj86 is offline   Reply With Quote
Old July 7th, 2013, 08:18 AM   #164
NevadaWolf
Certified looney toon
NevadaWolf's Avatar
MOTM Jul '13, Jul '14
Taking a wild ass guess... And attempting to read the wiring diagram for the bike...
The left signal signal looks like it activates the indicator from the green wire inside the 9 pin connector. (The right uses the gray wire inside the 3 pin.) is it possible that the wire either from the plug n play or in the stock connector is loose and not making a solid link?
I don't have my bike with me at the moment so can't look inside that part to see how it joins together but that seems like it might be the weak spot since the rest of the system is working normally.
<-- Linky
Old July 9th, 2013, 05:38 PM   #165
RaceTech Electric
RaceTech Electric's Avatar
Motorcycle(s): 1988 FJ1100
Hey guys,
So sorry I've been out of the loop here. It occurred to me today that I never saw a response on this thread from the group buy parts i sent out. I checked my spam folder, and found that every single Ninjette.org email update had been going to junk mail. I'm not sure how that happened, but I missed every single one for the last month+. So sorry about that.
I'm glad everybodys stoked on the kits and have them installed and running.
As for the turn signal issue, that's a tough one. It should work perfectly, there is really nothing to configure for the turn indicators. The PnP kit takes care of that. Like DandJ said, are they the stock t/s bulbs? are they working fine on their own? Do they cancel fine? I'm really not sure what would cause this. It's just the indicator on the dash that doesn't light correctly? Please give me some more info and I'll try and help. You can give me a call as well.
High output motorcycle stators, rotors and replacement regulators/rectifiers.
www.racetechelectric.com
RaceTech Electric is offline   Reply With Quote
Old July 9th, 2013, 05:42 PM   #166
RaceTech Electric
Originally Posted by Red250R View Post
@RaceTech Electric I do have one suggestion/constructive criticism. The piece that holds the water temperature sensor. Why not make it a 45 degree angle piece instead of a straight piece. It'll be a lot easier to install because it will be bent the same direction the hose already wants to go because of the radiator. It'll require you to cut a little bit more out of the hose but fitment will be a lot better and it'll be more streamlined.
Hey Red, see my other post, all my msgs were going to spam. I just saw this post from you. When I installed the kit for my instruction video, I actually thought the same thing. It does need to be angled to install easier. It's kind of a PITA with the straight hose piece. I will mention this to Koso to see if it can be updated. However since they already stock these and have probably already built thousands, I doubt we'll see a change anytime soon. I will mention it though.
Thanks for the advice!
Old July 9th, 2013, 05:56 PM   #167
Fan mode! I love it.
Old July 9th, 2013, 06:24 PM   #168
Red250R
Red250R's Avatar
Yeah thats what i figured. Not to mention the fact that they probably send out the same exact piece with every kit they sell. It just so happen to be that with our bikes, the area it needs to go in is cramped already AND its a 45 degree angle. Other bikes might have more room or not angled hose like we have.
Red250R is offline   Reply With Quote
Old July 19th, 2013, 04:52 PM   #169
LoD575
LoD575's Avatar
Came home to find my kit arrived. Will have a fun weekend installing the kit, doing an oil change, and flushing out the factory coolant.
Old July 20th, 2013, 07:47 PM   #170
SSG54
SSG54's Avatar
Hey guys,
sorry i have been crazy busy and also riding all over the place, i put 3k miles on my new koso
the signals work, the only thing that does not work, is the indicator on the display when i turn left, when i turn right, the signal on the display blinks
as for canceling, both directions work perfect
i have flush mount (protons) led for the front and i have the tail light with the intergraded turn signals
Old July 20th, 2013, 07:50 PM   #171
SSG54
SSG54's Avatar
no stock signals, i'm LED protons flush mount, and intergraded LED tail light, all the flashing is normal, its just the display on the new gauge when turning only left, when i turn right the display is blinking
Old July 23rd, 2013, 05:50 PM   #172
Ausoi
Motorcycle(s): 2008 (Black) Kawasaki Ninja 250R
Seems like the speedo on mine is reading kinda high. Am i spose to program it beforehand? the front is a normal 110, the rear is a 150 though.
Ausoi is offline   Reply With Quote
2014 Koso Group Buy! RaceTech Electric Motorcycle-related 19 April 24th, 2014 01:39 AM
When's the next Koso group buy? IF13 Motorcycle-related 23 March 18th, 2014 08:26 AM
Koso rx-2n 7 colours backlight were can i buy it bandit_fosky Items Wanted 6 September 10th, 2012 12:16 AM
Group Buy on Koso Gauges *requested* RaceTech Electric Motorcycle-related 228 July 16th, 2012 06:43 AM
Having trouble finding a Koso RX-2 complete kit. MotoStrider 2008 - 2012 Ninja 250R Tech Talk 8 July 23rd, 2011 05:54 AM
