Old December 10th, 2016, 08:14 AM   #1
RichmondKawi
RichmondKawi's Avatar
Motorcycle(s): 2003 Ninja 250r, 2004 CBR600 F41
Rear tire width
I'm in the process of gathering parts for a steetfighter conversion and I want to stick a super fat tire in the back mainly just for looks. What's the widest I can go without needing to do fabrication or something?
Not here for a long time, here for a good time.
RichmondKawi is offline   Reply With Quote
Old December 10th, 2016, 08:31 AM   #2
well a 130/90-16 Bridgestone BT45 is more like 138 or so and doesn't have a ton of clearance on the swingarm
You might be able to stuff a 150 in there if you scoot the wheel back as far as you can...?
Old December 10th, 2016, 08:59 AM   #3
Mohawk
Mohawk's Avatar
Motorcycle(s): ZZR250, VFR800
Different brands of tyre have different widths, regardless of what is on the side wall. You need about 5mm clearance to each side of the swingarm as a minimum to allow for tyre flex.
I have a 4x17" rim in the back of mine, its fitted with a BT45 140/70-17 tyre but measured its 149mm wide with no load. I have approx 10mm clearance a side, so could squeeze a 150-160 in there. I measured the original swingarm it has a maximum gap of 180mm where the tyre rim would be.
Old December 10th, 2016, 10:12 AM   #4
RichmondKawi
thanks guys im probably gonna go 140 i guess its not exactly practical to try and make my 250 look like the 600 i cant afford haha
Old December 12th, 2016, 07:26 AM   #5
spent_too_much
spent_too_much's Avatar
You might have an issue with the tire and the rim. I believe that I read somewhere that the factory wheel was designed for a 120 width tire, and then began to ship with a 130. A 140 might not seat correctly on the rim. Just verify before going to a tire shop to have it mounted.
Old December 12th, 2016, 08:17 AM   #6
Right, Bridgestone has a chart somewhere on their site that shows what rim widths their various tire sizes are designed to run on. While correct seating on the rim is not likely to be a problem, excessive wrap would make the tire shape different from what it was designed to be.
The 130/90 BT45 I have on my 250 is plenty big.
Old December 12th, 2016, 11:03 PM   #7
JohnnyBravo
Certifiable nontundrum
JohnnyBravo's Avatar
MOTM - Sep '13, Sep '16
FLOOR-UH-DUH MOD!!!!!!!!!!!!!!!!!!!!!!! Rock on
Old July 4th, 2017, 04:19 PM   #8
ThrottleGirl
ThrottleGirl's Avatar
Motorcycle(s): 1993 Ninja 250R, 2013 Ducati Diavel Dark Stealth, 2005 Honda Rebel Bobber
Curious what you ended up deciding on, would love to see pictures of it.
When in doubt, throttle out.
ThrottleGirl is offline   Reply With Quote
Old July 4th, 2017, 05:51 PM   #9
Lazarus
Lazarus's Avatar
Motorcycle(s): 2008 Ninja 250
I have the Bridgestone bt45 in a 140 and I love it.
Lazarus is offline   Reply With Quote
Old July 4th, 2017, 06:22 PM   #10
ThrottleGirl
140/80-16? I'd love to see a picture of those.
Old July 4th, 2017, 08:10 PM   #11
Here you go!
Old July 4th, 2017, 08:41 PM   #12
They're the same ones I have on mine, except my rear is a 130/90-16. Handling is excellent.
Old July 4th, 2017, 11:37 PM   #13
ThrottleGirl
Ha, I meant on the bike, silly. I'm curious what the larger size looks like.
Old July 5th, 2017, 02:42 AM   #14
Lazarus
Lazarus's Avatar
I'll check when I get to work (about to ride out in 20min) I believe it's a 140/80/17 in the rear and a 120/80/17 in the front. I have a new gen though
Edit: it's 140/70/17 and 120/70/17 front.
Pardon the bikes dirty appearance and the half shot of my plate in the second image lol. https://m.imgur.com/vTaFlx2
https://m.imgur.com/nIOIClj
Last futzed with by Lazarus; July 5th, 2017 at 04:07 AM.
Old July 5th, 2017, 08:11 AM   #15
ThrottleGirl
Wow, I guess I must be used to my 240 on the Diavel as that tire doesn't look 'big' on your bike. I'm dreading being forced to switch out 16 to 17's....still trying for one more massive online search to magically pull up a 16" enduro tire.
Do you have a thread talking about your build? I'd like to know about your muffler and mudguard, too.
Old July 5th, 2017, 09:04 AM   #16
Lazarus
Lazarus's Avatar
Ya I've only ever owned my little ninja so it definitely doesn't look big. I'm to impatient and lazy to do a build thread lol the muffler is from amazon (I'll check my order log and link you the url if you'd like.) The mudguard? Do you mean the plastic tail section that is black? Or the white tire hugger? If it's the latter it can be had off eBay for about 15$. It is a stock cbr 250 chainguard that I painted to go with the fairings.
Edit: https://www.amazon.com/gp/aw/d/B01L1...?ie=UTF8&psc=1
I've done a lot of mods thanks to this forum and members of it.
Seat height and width archaeofreak General Motorcycling Discussion 23 July 4th, 2017 11:07 PM
Confirming rear wheel size & width LoganCormier 2008 - 2012 Ninja 250R Tech Talk 3 May 1st, 2016 05:57 PM
someone bored and can take measurement ASAP pregen under seat rail width? crazymadbastard 1986 - 2007 Ninja 250R Tech Talk 8 April 24th, 2014 08:22 PM
08-12 front and rear rim width Kangxi 2008 - 2012 Ninja 250R Tech Talk 8 December 17th, 2012 03:23 PM
wheel stand width question ubnewbie 2008 - 2012 Ninja 250R Tech Talk 1 June 14th, 2012 06:13 AM
