Old March 15th, 2017, 11:14 AM   #1
Cra1g
Cra1g's Avatar
Motorcycle(s): 2014 Ninja 300 ABS, 2007 Yamaha FZ6
Lowering handlebars using ZX600 risers, but problems...
Per this wiki article on lowering the pregen handlebars, I bought some 93-02 ZX600E handlebars off of eBay for ~$15. I only needed the risers and not the handlebars, but it came with both (and the right handlebar was bent, which is probably why I got them for cheap).
My plan was to just remove the handlebars and toss them, keeping the risers and using them on my Ninja 250. However, it looks like the riser and the handlebar is all one piece. There's no bolt to remove the handlebar portion and from what I can see, it definitely appears that it is, in fact, all one piece..
http://imgur.com/a/OpgW8
Did I not get risers from the right ZX600 model or what?
Cra1g is offline   Reply With Quote
Old March 15th, 2017, 11:34 AM   #2
Ghostt
Ghostt's Avatar
As my write-up clearly states ZX600C, so basically yes you got the wrong ones
But I'd still give the try, Kawasaki may have been lazy and your Ninjette controls might just fit.
If they work, please let us know
violente et ignorantia
ZX-2R BLOG
Old March 15th, 2017, 12:09 PM   #3
Cra1g
Cra1g's Avatar
Aw, I didn't realize that the "C" and "E" made a difference. I just figured any ZX600 model worked
I'm not gonna bother trying them out, since the right handlebar is bent. Guess I'll take the loss or try to resell them.
Old March 15th, 2017, 06:10 PM   #4
Ghostt
Ghostt's Avatar
I'd say straighten out the right bar, and give them a try, the only thing that might give you some issues is the forward controls, which if the holes in the new bars don't line up, just drill some new ones.
Straighten the bent one should be easy, assuming you have a bench vice, and a long piece of pipe, and a plus is if you can hear it up, otherwise it's brute force and ignorance is your best best. If you don't have any of that, try a local mechanic, shade tree etc..... They usually have the tools, and don't care to try for a few bucks
Hell I might be interested in them, PM me if you want to, I know I can straighten them out, hopefully without weaking them.
ZX-2R BLOG
Old March 15th, 2017, 07:01 PM   #5
Cra1g
Cra1g's Avatar
I might take you up on that offer. On a slightly-unrelated note, if I were to get my hands on some Woodcraft risers for the Ninja 250, would the stock bars fit into those risers? Or would I need to use the Woodcraft bars?
Old March 15th, 2017, 08:05 PM   #6
Ghostt
Ghostt's Avatar
Nope on the OEM fitting, as far as I know.
ZX-2R BLOG
Old March 16th, 2017, 06:22 AM   #7
taz
taz's Avatar
MOTM - May '17
I have a pair they take different bars, but plus side they are cheap they only cost $14 for a set of bars
Old March 16th, 2017, 06:24 AM   #8
taz
taz's Avatar
MOTM - May '17
Old March 16th, 2017, 07:22 AM   #9
Cra1g
Cra1g's Avatar
Bummer. I really just want to avoid having to take everything off of the bars and put it all on new bars. If I could just get the most lowered risers possible and use the OEM bars, that'd be perfect..
Old March 16th, 2017, 11:26 PM   #10
Ghostt
Ghostt's Avatar
Then keep looking on my eBay, you'll find what your looking for.
I did a quick search and came up with these,
Look at this on eBay http://www.ebay.com/itm/132092792913
Look at this on eBay http://www.ebay.com/itm/132092794134
Same seller, I would shoot him an email and see if he'll make a deal, they usually will.
ZX-2R BLOG
Old March 17th, 2017, 07:10 AM   #11
Cra1g
Cra1g's Avatar
Great find--thanks!
Old March 24th, 2017, 06:13 PM   #12
Cra1g
Cra1g's Avatar
How did you grind off the ends of the risers? In my mind I was thinking about just using a Dremel, but there's a lot more metal to grind off than I thought.
I'm thinking about using an angle grinder with a cutting disc, but is there a cleaner method?
Old March 24th, 2017, 08:10 PM   #13
Ghostt
Ghostt's Avatar
I had only a dremmal with a cut off disc, risers are just aluminum, so whatever you got handy to get the end results.
Bench grinder?
ZX-2R BLOG
Old March 28th, 2017, 08:18 AM   #14
spent_too_much
spent_too_much's Avatar
I used a chap Harbor Freight 4 1/2" angle grinder and disk. I think combined, they cost me $15 USD. Love those 20% off coupons! LOL
Need to raise handlebars more than risers Ninjamomma 2008 - 2012 Ninja 250R Tech Talk 27 March 15th, 2017 12:14 PM
Clipons for lowering front forks instead of risers gptoyz 2013 - 2017 Ninja 300 Tech Talk 19 August 7th, 2014 05:44 PM
FS: 08-12 250R Roaring Toyz Lowering Blocks/Handlebar Risers DJK Motorcycle-related 7 July 8th, 2014 06:25 PM
wanted: new gen 37mm handlebars, stock or 2-3in risers. thumper64 Items Wanted 2 November 8th, 2013 06:45 PM
