Old June 24th, 2017, 04:31 PM   #1
verve
Motorcycle(s): 07 ninja 250
07 ninja 250 front turn signals
hey guys i'd like to get some flush mounts for my ninja. i've seen a ton on ebay but im not sure if theyd fit or not. do you guys know any good websites or have any flush mounts that have worked for you guys?
verve is offline   Reply With Quote
Old June 24th, 2017, 05:48 PM   #2
Cra1g
Cra1g's Avatar
Motorcycle(s): 2014 Ninja 300 ABS, 2007 Yamaha FZ6
Mad Hornets makes some that fit the pregen, but I can't seem to find them on their website. It's a starting point, though..
http://www.madhornets.com/indicators-turn-signals/
Cra1g is offline   Reply With Quote
Old June 24th, 2017, 06:45 PM   #3
Ghostt
Ghostt's Avatar
One must remember that the last year of th PreGen was 2007, ten years ago, so in the aftermarket world of making parts it's a lifetime, so with shrinking demand, and not a current model, they stop making parts. It wouldn't surprise me if Mad Hornets has stopped making them, or at the very least carrying them.
violente et ignorantia
ZX-2R BLOG
Old June 24th, 2017, 06:57 PM   #4
verve
yea i know that but i was just hoping someone maybe found one on ebay or something that they knew would fit without modifications.
Old June 24th, 2017, 07:05 PM   #5
Ghostt
Ghostt's Avatar
Anything will require some sort of modifications, even the Mad Hornets one did, as seen in my blog below.
Mad Hornet's flushmount front turn signals /AsianCycle flush-mounts clones
I had the other flush Monet's before them, and they didn't seem too bad.
ZX-2R BLOG
Old June 25th, 2017, 09:30 AM   #6
What's wrong with modifications? Aren't you already modifying bike by changing the OEM lights out? Accepting cutting, grinding and welding as part of any mod will allow you to do quite a lot with bike.
Old July 9th, 2017, 06:37 AM   #7
harvey58
Motorcycle(s): 2007 250r
I just changed all the turn signals on my bike. Old stalks were breaking. Didn't use flush mounts, but this should work for you. Use 1/8" acrylic sheet, cut to fit the opening in the fairing where the original signals were. I used a scroll saw to cut the shape. Paint to match (paint on backside). Using LED lights will require some wiring mods to prevent winding up with "4-way flashers" all signals flash! This happens because the left side grounds the right and vice-versa.
harvey58 is offline   Reply With Quote
Old July 9th, 2017, 08:48 PM   #8
NaturalFlavored
Motorcycle(s): 250r
Modifying meaning cut into the fairing.
The rears are easier but still some modifications are needed. I bought mine off of Amazon.
NaturalFlavored is offline   Reply With Quote
wiring for flush mount front turn signals for 07 ninja 250 james250ninja 1986 - 2007 Ninja 250R Tech Talk 2 October 4th, 2013 01:35 PM
Need Right Side Fairing for an '09 Red 250 Ninja Plus '08+ Front Turn Signals SP1VEY Items Wanted 4 August 9th, 2012 06:31 PM
