Old June 1st, 2023, 02:27 PM   #1
Canuckinatruck
Canuckinatruck's Avatar
Motorcycle(s): 2003 ZZR250
Surging then Losing Power
Hey all,
I have a 2003 ZZR250 that I picked up cheap for a starter bike. After having my uncle do the carbs and valves, then doing brake lines, new rubber and making an MT09 fender fit, it's finally ready. Right? Right?!?!?! After a few shakedown rides and a celebratory rip when I got my plate on, I was pretty sure it was.
Wrong. I took it to work yesterday, normally 30 mins on mostly 80kmh roads. So I got about half way there after it started and ran fine. Out of nowhere, in 6th gear at 7500rpm, it started surging, like I was hitting the back brake then releasing it. After a few surges, it started slowly losing power. I tried to drop a gear and the revs wouldn't come up, they just faded down to 0.
Stopped on the side of the road, I tried to refire it. Turned over but won't start. Choked it, still no start. Checked fuel, still lots and it's not old. Finally it fired up again after a few minutes. Continue down the road for a few minutes and it happens again. And again. And a 4th time 200 feet from the gates at work.
After work, same thing. Starts fine, rides fine for 10 minutes or so, then surge and die. It became more and more frequent on the way home, dying every minute or two.
Everything seems visibly fine. One spark plug was tan and dry, the other was more black but dry. Wiring to the coils and plugs all looks good. No whoosh from the gas cap. Switching fuel tap to prime to bypass the vacuum didn't change anything. Fired it up today to move it to my barn, ran fine.
Anyone know where to start here? I was super stoked to finally be legal to ride and now I'm debating burning the bike to the ground.
Canuckinatruck is offline   Reply With Quote
Old June 1st, 2023, 03:43 PM   #2
Something is restricting fuel flow. If it's not the tank vent, it may be the fuel filter. The stock filter is small, and inside the rubber hose where it goes into the carbs. Mine was clogged and did things like you described until I took it out and put an inline pleated paper filter in the line instead.
It could also be a clogged petcock, but you can check that pretty easily by taking the hose off at the carb and checking flow in "prime", and also by checking it in the "ON" setting by sucking gently on the vacuum port.
Old June 1st, 2023, 04:27 PM   #3
Canuckinatruck
Sweet, I'll redo the lines and check the petcock after work tomorrow. Conveniently I just did the limes on my mud toy so I have filters and hose leftover. And on a hunch, ordered a petcock rebuild kit yesterday. Hopefully it's that easy. I was thinking it was something spark related, which is much more expensive and difficult to find parts for.
Thanks, friend! I'll post back this weekend after some test riding and see if that fixes it.
Old June 2nd, 2023, 03:44 PM   #4
Canuckinatruck
It worked perfect! Cut the old filter out, added a normal, changeable filter and put about 150km on it with no issues. You are appreciated friend!
Old June 2nd, 2023, 04:10 PM   #5
Great! I'm glad it worked out for you, J.J.
Old June 4th, 2023, 06:05 PM   #6
woohoo!!! Good job!!
Losing power then dies NaturalFlavored 1986 - 2007 Ninja 250R Tech Talk 18 July 2nd, 2017 02:39 PM
Losing power in the rain scorch 1986 - 2007 Ninja 250R Tech Talk 13 May 13th, 2016 08:04 PM
Losing braking power randomwalk101 2008 - 2012 Ninja 250R Tech Talk 21 December 25th, 2011 10:11 AM
losing power on the road :( onizthegnome 2008 - 2012 Ninja 250R Tech Talk 17 October 25th, 2011 10:19 AM
Losing Power stewy832 1986 - 2007 Ninja 250R Tech Talk 14 July 9th, 2011 04:33 PM
