Go Back   ninjette.org > Marketplace > Motorcycle-related
Closed Thread
Old May 17th, 2011, 05:46 AM   #1
CThunder-blue
ModMy250.com
CThunder-blue's Avatar
Group Buy for Plug and Play Flush mount LED turn signals
I want to see if there is interest for a group buy on these LED Front turn signals. I saw them on Wayan's thread for his group buy on misc stuff from his corner of the world and really liked them. They're the Kymoto triangular signals. By themselves they require some extra work to fit them onto our new gen 250's. The threaded pipe it has is too short as well as the wiring is short about 10". If there is enough interest, I can put together a kit that would make this completely plug and play. It would include the turn signals, an extension for the threaded shaft, a new nut & washer, and soldered wires with a factory style harness to plug into the bike.
Here's what the original kit comes with:
Here's what I'm proposing:
Pricing:
1-5 people: $45 shipped in the US / International would be extra
6-10 people: $40 shipped in the US/ same as above
Time: It would take about 2 weeks for the supplies to arrive and a day for me to make them. Each signal would be tested for functionality before shipment too. Shipping would be by usps priority mail. So I would say 3 weeks from the time you send payment.
The one thing I'm not including is the Electronic Flasher Relay. I used a Tridon EP34. It has 3 pins. You just hook up the oem harness to pins B and L and run a ground wire for E. I did this, but you can choose to get a 2 pin relay as well. The relay is required but can be purchased from any auto parts store. If you want the same relay I used, I can include it (with a ground wire attached) at my cost which is $13.
This is it guys. I have 2 spots left for the GB. If anyone else wants them at this price, speak up now. I'll leave it open until the end of next week. After that, normal selling price will be $60 shipped in the US.
Full Kit Orders
1. Sarapacman99 - Charlie + EF Relay
2. Platypus42 - Tyler
3. har0ld - Harold + EF Relay
4. caliente103 - Hector
5. GeneJunkie - Cindy
6. BlackNinja - J
7. cool runnings racing - Kevin
8. kaiserz- A.D. + EF Relay
9. gfloyd2002 - Floyd + EF Relay + ZX-2R - black decals.
10. Liquidtoon - Josh
11. Bish - Bish + EF Relay +$13 shipping to UK
12. oroboros - Drew + EF Relay
13. Shaol1n Monk - Jae + EF Relay
14.
Signals Only Orders
1. sledneckrider - Jordan + 250R + ZX-2R - White decals
The www.ModMy250.com guy
Last futzed with by CThunder-blue; June 6th, 2011 at 08:32 AM.
CThunder-blue is offline
Old May 17th, 2011, 05:48 AM   #2
CThunder-blue
ModMy250.com
more pics
Old May 17th, 2011, 06:06 AM   #3
nattygirl
nattygirl's Avatar
Motorcycle(s): 2010 Kawasaki Ninja EX250 Special Edition Red/Black
I'm not sure if its just me, but the left doesn't look like it sits the same direction as the right side. It doesn't look symetrical to me.
'10 Ninja 250R SE Red/Blk
Mods: Projekt D FE, Protons, HB Blk Windscreen, HIDs, TBR Blk Series Slip-On, Shogun Sliders, Solo Cowl, Integrated Tail Light, Gls Blk Rear Fender, Red Accents
nattygirl is offline
Old May 17th, 2011, 07:24 AM   #4
CThunder-blue
ModMy250.com
Haha. Good catch. The blinker is just rotated so I could take pictures to illustrate that you could position them in either direction.
Old May 17th, 2011, 07:50 AM   #5
oroboros
GDTRFB
oroboros's Avatar
Motorcycle(s): 2009 Ninja 250 - sold 2005 EX500R project
I'm interested. I think I like the look of the Protons a little more but I have a small crack in the plastics on the right side (from the PO) and this would cover it up mostly. Plus, these cost less...
I don't want a pickle Just want to ride on my motorsickle
-Arlo Guthrie
oroboros is offline
Old May 17th, 2011, 07:53 AM   #6
CThunder-blue
ModMy250.com
You should add some epoxy to the back of the crack so it doesn't get bigger.
Old May 17th, 2011, 08:35 AM   #7
oroboros
GDTRFB
oroboros's Avatar
Yup, I had it off and put a bead of ABS cement on the back. Its not bad but there are a few chips in the paint that could be covered by the flush mount. I'm not all ocd about it. I got a great deal on a very low mileage bike with the typical "fell over in the garage crack"
Posted via Mobile Device
oroboros is offline
Old May 17th, 2011, 08:43 AM   #8
CThunder-blue
ModMy250.com
Cool. Well, I'll have to see what kind of response I get about the LED's. If there's not enough interest, I don't want to spend money buying a bunch and having it collect dust. I can still make the required adapter and sell it in a kit with the oem style harness so people can do it themselves.
Old May 17th, 2011, 08:48 AM   #9
Kevin2109
KThanksBye
Kevin2109's Avatar
Motorcycle(s): 2006 zx636r
I would be more interested in just the signals... not the wiring or anything else
Kevin2109 is offline
Old May 17th, 2011, 08:54 AM   #10
CThunder-blue
ModMy250.com
That could be arranged as well. It would probably be $28 shipped.
Old May 17th, 2011, 09:56 AM   #11
kaiserz
There's a limit to s2pdty
kaiserz's Avatar
$45 - $40 with the kit?
kaiserz is offline
Old May 17th, 2011, 09:59 AM   #12
kawac
Kawic
Motorcycle(s): ninja 250 08
Since it is LED, does it require some modification on the wiring?
kawac is offline
Old May 17th, 2011, 11:02 AM   #13
CThunder-blue
ModMy250.com
Right. The $40-$45 price includes the flushmount blinkers with an extended oem style harness, my adapters, and necessary hardware.
No modification necessary to the wiring with the stock rear lights and the front LED blinkers. You will need to purchase a new electronic Flasher relay for them to work right. The new relay will future proof your bike in case you want to add in additional rear LED's. Some bikes may require the Diode Mod if you add rear LED's. I don't have them, so I wouldn't be able to tell you if it's needed or not.
Old May 17th, 2011, 02:39 PM   #14
Platypus42
Platypus42's Avatar
Motorcycle(s): '10 Ninja 250
It seems like they would be hard for someone to see who was looking at your bike dead on. Can you maybe post a picture like in the second set but with them flashing?
Platypus42 is offline
Old May 17th, 2011, 02:46 PM   #15
CThunder-blue
ModMy250.com
Yeah, I can take a pic today when I get home. The really nice thing about them is for people like me who commute on the freeways. The people on the sides of me will be able to see my blinker when I'm changing lanes. The front facing oem blinkers don't help at all. I could always add in a strip of LED's in the front fairing on each side that would blink amber as well.
Old May 17th, 2011, 04:46 PM   #16
sledneckrider
sledneckrider's Avatar
Motorcycle(s): "Hopper" 2011 SE Ninja 250R
I'm in! I think they look very clean! Although i woundn't need the wiring or adapter either. Just the signals. Let me know what you figure out.
"Some may never live, But the crazy never die." - Hunter S. Thompson
sledneckrider is offline
Old May 17th, 2011, 05:31 PM   #17
kaiserz
kaiserz's Avatar
it will be awesome if you van post a vid for it, i'm really really interested, but i want a plug and play set up.
kaiserz is offline
Old May 17th, 2011, 06:50 PM   #18
DarC
DUCEATR
DarC's Avatar
Motorcycle(s): RVT1000R
Here they are in a darker garage. If this doesn't work for ya it should be dark outside here in an hour and a half or so....
http://www.youtube.com/watch?v=-ROiPq7LOoE
DarC is offline
Old May 17th, 2011, 07:24 PM   #19
Platypus42
Platypus42's Avatar
Thanks DarC. That was the angle I was looking for. They look good. Put me down for a set.
Old May 17th, 2011, 07:39 PM   #20
kaiserz
kaiserz's Avatar
I'm so tempted to get them. . . how many people are on the list right now?
kaiserz is offline
Old May 17th, 2011, 08:11 PM   #21
DarC
DUCEATR
DarC's Avatar
No problem I have had no problem on the street with visibility so far. The are bright at night too. They literally light up whatever is next to you, even the interiors of MP cars who are in the inside left turn lane at the intersection
DarC is offline
Old May 17th, 2011, 08:37 PM   #22
CThunder-blue
ModMy250.com
Thanks Dan!
OK. Let's start a list. I should be getting an invoice from the supplier tomorrow and will get the ball rolling. I'm going to offer the signals with and without the kit.
Pricing will be $28 shipped without the kit/ $45 shipped w/P&P kit for 1-5 people/ $40 shipped w/P&P kit for 6+.
I'm going to list names for people who said they're definite. Please let me know if you just want the signals or the full kit as well. Thanks! Also, for those that want the full kit, if you order early and I end up selling 6+, I will refund you $5.
Old May 17th, 2011, 09:42 PM   #23
CThunder-blue
ModMy250.com
Ok. I did a video of the blinkers in my garage with all the lights on to show what it should be like during the day. It was cloudy and rainy today so I couldn't get a good video of it on a sunny day. Also got some more pics. Enjoy
Old May 17th, 2011, 10:03 PM   #24
har0ld
Motorcycle(s): 08 ninja 250r
Hey CThunder, I would be interested in the kit, so you can count me in! These look awesome.
har0ld is offline
Old May 17th, 2011, 10:51 PM   #25
sarapacman99
Climb to Glory!
sarapacman99's Avatar
Motorcycle(s): 2011 Kawasaki Ninja 250R White (sold)
count me in on that! looks sweet. quality looks real good. i like the way it looks better than the protons.
I wanted to become Kamen Rider as a kid.
sarapacman99 is offline
Old May 18th, 2011, 12:52 AM   #26
wayanlam
wayanlam's Avatar
Motorcycle(s): 2014 Z250
basically looks the same like the ones i found here in bali too
but no one wanted it when i offered to get it the other week, hehehe
edit: ps. the price @ $28 shipped, that tri is selling them at is better than what i was able to get over here. so its a good deal
Kawasaki Z250, Bored up to 300cc with 12.8 CR, 41hp at wheel 27nm torque, Two bros full exhaust with DB killer
Dynojet Power Commander V, KnN Open filter, intake and exhaust ported, Puig Windshield
wayanlam is offline
Old May 18th, 2011, 01:45 AM   #27
Though they look good, I don't think they fit the style of the bike so I'll pass. I'd like to see what they look like with the triangular black area painted to match the bike (or installed on a black bike). That may hide the clash a bit.
CZroe is offline
Old May 18th, 2011, 07:16 AM   #28
DarC
DUCEATR
DarC's Avatar
They look great on a black bike They give a similar design cue as the factory flush mounts on the other Ninjas.....
DarC is offline
Old May 18th, 2011, 07:37 AM   #29
CThunder-blue
ModMy250.com
The black piece is a rubber gasket. No way to paint it and if it was removed, the blinkers would rub against the fairing unless you glued/taped it. It also makes up the difference in size, so it actually partially covers the hole there. I personally like it, but everyone has their own taste.
I'm only listing people who said they're in for sure. Anyone who's expressed interest has been left off the list to keep an accurate count.
Current List:
Full Kit Orders
3. har0ld - Harold
6.
7.
8.
9.
10.
Signals Only Orders
2.
3.
4.
5.
Last futzed with by CThunder-blue; May 18th, 2011 at 12:51 PM.
Old May 18th, 2011, 07:45 AM   #30
CThunder-blue
ModMy250.com
Thanks Wayan. I'm basically selling them at my cost + shipping just to help out fellow ninjetters.
Old May 18th, 2011, 08:54 AM   #31
ride2rideagain
total N00B
ride2rideagain's Avatar
What's the cost of kit, shipped to Toronto, Canada?
ride2rideagain is offline
Old May 18th, 2011, 09:17 AM   #32
CThunder-blue
ModMy250.com
It would be an extra $3 shipped to Canada.
Old May 18th, 2011, 10:37 AM   #33
CThunder-blue
ModMy250.com
During the group buy, if anyone buying signals would like some 250R or ZX-2R stickers, I will sell them for $2/pair and will ship them with the signals.
Old May 18th, 2011, 11:12 AM   #34
sledneckrider
i'll take a pair of both stickers!! i love the ZX-2R!! thats awesome!!
Old May 18th, 2011, 12:11 PM   #35
CThunder-blue
ModMy250.com
Would you like the decals in black, silver, or white Jordan? The R will be red of course.
Old May 18th, 2011, 12:48 PM   #36
GeneJunkie
GeneJunkie's Avatar
Why did I have to see this thread?
Add me to the list for the full kit
GeneJunkie is offline
Old May 18th, 2011, 12:52 PM   #37
CThunder-blue
ModMy250.com
Done
Old May 18th, 2011, 02:03 PM   #38
BlackNinja
Motorcycle(s): '09 2fiddy
Count me in for a full set! I'm guessing you want pay-pal, right? Got an address?
BlackNinja is offline
Old May 18th, 2011, 02:31 PM   #39
cool runnings racing's Avatar
Motorcycle(s): 09 ninja 250 special edition
I am in for the full Kit. Send me info for paypal.
Thanks.
cool runnings racing is offline
Old May 18th, 2011, 02:39 PM   #40
CThunder-blue
ModMy250.com
Thanks guys. I will post paypal info once the blinkers are ready to ship. I don't want to take money until then since I'm waiting on suppliers and I don't want you guys to get anxious.
Current List:
Full Kit Orders
3. har0ld - Harold
6. BlackNinja - J
10.
Signals Only Orders
2.
3.
4.
5.
Last futzed with by CThunder-blue; May 19th, 2011 at 09:40 PM.
Closed Thread
Plug and play flush mount turn signals? trugracie 2008 - 2012 Ninja 250R Tech Talk 6 March 4th, 2014 03:50 AM
Need help with Bike Monkey taillight and led proton flush mount turn signals romeo127 2008 - 2012 Ninja 250R Tech Talk 1 November 23rd, 2010 01:33 PM
