Go Back   ninjette.org > Marketplace > Motorcycle-related
Old February 1st, 2012, 08:49 PM   #81
5evenz
5evenz's Avatar
Motorcycle(s): 09' 250r Thunder Blue
Payment sent. (WOOPIEEEE!!!!!!)
5evenz is offline   Reply With Quote
Old February 1st, 2012, 08:59 PM   #82
massacremasses
Avid Kitteh Poster
massacremasses's Avatar
Motorcycle(s): 2006 Yamaha TTR 50 SUCK IT
woohoo that everyone?
I powdercoat stuff Help me pay for my addiction
I say funny stuff. http://twitter.com/JustinPWNSyou sometimes...
I write like a 12 year old too, http://justinpwnsyou.wordpress.com/
massacremasses is offline   Reply With Quote
Old February 1st, 2012, 09:33 PM   #83
CThunder-blue
ModMy250.com
CThunder-blue's Avatar
Thanks guys! Only missing Toby's payment
The www.ModMy250.com guy
Old February 2nd, 2012, 01:35 AM   #84
jack_bm
Ex ninjette!
jack_bm's Avatar
Motorcycle(s): Suzuki GSXR 600 K4, Kawasaki ninja 250r 08
was just wondering what kind of switch the blaster X switch is, is it something you could just buy down the hardware shop?
jack_bm is offline   Reply With Quote
Old February 2nd, 2012, 08:21 AM   #85
CThunder-blue
ModMy250.com
Yeah, it looks like its just a circuit on/off toggle switch. If you price it out, the cost is nearly the same once you factor in the time to make one.
Old February 2nd, 2012, 09:01 AM   #86
Makenza
Lurker
Motorcycle(s): 2010 Red Ninja 250R
^ Which is why I'm just ordering one through Tri for the CustomLED switch, it'll be properly gauged wiring, properly made, with a ring terminal and proper shrink tape. Otherwise I'd make it myself.
Makenza is offline   Reply With Quote
Old February 2nd, 2012, 12:13 PM   #87
EthioKnight
Super Noob
EthioKnight's Avatar
Motorcycle(s): '09 Kawasaki Ninja 250R, '84 Honda Spree 50cc
Hey Tri,
Do you think it would be possible for me to buy the switch after I've received and installed the tail light? I think the standard 3 strobe is enough, but if I wanted to increase it, would you accept new orders? (for just the switch I mean). thanks.
EthioKnight is offline   Reply With Quote
Old February 2nd, 2012, 12:16 PM   #88
Makenza
Lurker
You don't need the switch, the switch just makes it easier to configure.
The tail light comes with a ground, that you would hook up to the switch.
But to re-configure the tail light without the switch, you would just MANUALLY ground that wire. As in hold it by hand, and touch it to a ground.
Again, the switch is 100% for convenience. Absolutely not necessary.
Old February 2nd, 2012, 12:58 PM   #89
jack_bm
Ex ninjette!
jack_bm's Avatar
hmm if its any switch i might buy one at a later stage or something as i don't wanna confuse my self any more with the installation lol with the switch is it just for configuration because i saw on a youtube video think from someone on this site that when its turned on it makes it strobe and everything and when he turns it off it goes normal, what's all that for?
Old February 2nd, 2012, 01:04 PM   #90
Makenza
Lurker
All of that is also done using the ground wire, aka the ground switch.
Both ways enable the strobe mode, which is basically a demo mode.
See this link for further information.
http://www.customled.com/09_250R_REV...structions.pdf
Old February 2nd, 2012, 01:23 PM   #91
jack_bm
Ex ninjette!
jack_bm's Avatar
had a look and it says "THIS FEATURE IS ENGAGED BY GROUNDING THE GRAY WIRE (TO ANY COMMON GROUND POINT: BATTERY (-) OR FRAME). THIS WIRE SHOULD BE CONNECTED TO A TOGGLE SWITCH TO CONTROL STROBE MODE OPERATION. FOR NORMAL TAIL LIGHT OPERATION, THIS WIRE SHOULD NOT BE CONNECTED TO ANYTHING." Does this mean i have to have the switch (turned on) and grounded for the strobe to work when im braking otherwise if its not grounded it wont strobe? :s sorry im easily confused lol
Old February 2nd, 2012, 01:25 PM   #92
Bo0stZomb13
Motorcycle(s): 09 ninja 250r
Ill take a tail light and relay. (I have your diode kit already lol)
Area P full race, Hot bodies Undertail, Adjustable levers, Dyno Jet stage 2 kit, 719 gelgrips, Sporsti hugger, 15T, KN filter, Shogun swingarm spools
Bo0stZomb13 is offline   Reply With Quote
Old February 2nd, 2012, 01:28 PM   #93
Makenza
Lurker
No, read it more carefully,
CUSTOMIZING FEATURES
ONCE YOU HAVE ACCESSED THE PROGRAMMING INTERFACE, YOU CAN CUSTOMIZE THE FOLLOWING MENUS.
1) TURN THE STARTUP SEQUENCE ON/OFF.
2) SET THE NUMBER OF BRAKE ALERT PULSES FROM 0 TO 19, OR CONSTANT WHILE BRAKES APPLIED.
3) SET THE RUNNING LIGHT BRIGHTNESS WITHIN A PRESET RANGE.
4) SET THE BRAKE LIGHT BRIGHTNESS WITHIN A PRESET RANGE.
5) ENTER DEMO MODE. (USEFUL FOR BIKE SHOWS AND DISPLAYS)
6) RESET FACTORY DEFAULTS (SAME AS WHEN THE TAIL LIGHT WAS MANUFACTURED).
You ground, and unground, 5 times, and you enter demo mode.
Old February 2nd, 2012, 01:31 PM   #94
jack_bm
Ex ninjette!
jack_bm's Avatar
Ohhh thats cool thanks for helping me understand that, im sure i'll have more question when it comes to wiring it up and programming things like the brightness and all that, we'll come to that when i get there thoguh haha
Tri: if its not to much hassle can i add a switch think it will just make it a bit nicer for programming if its too much hassle no worries i can live without it, i can also pay as soon as you confirm it.
Old February 2nd, 2012, 01:58 PM   #95
n250r
Motorcycle(s): 2009 Blue Ninja 250r
Payment sent.
n250r is offline   Reply With Quote
Old February 2nd, 2012, 10:15 PM   #96
CThunder-blue
ModMy250.com
PM sent
No problem Jack. I sent you another invoice for the switch.
Old February 3rd, 2012, 12:57 AM   #97
jack_bm
Ex ninjette!
jack_bm's Avatar
All paid thanks for lettin me do that
Old February 3rd, 2012, 08:05 AM   #98
Ninja250gurl
M@ry M@ry
Ninja250gurl's Avatar
Motorcycle(s): 2012 ninja 250 Red/Black
Am i to late to get in on this?? I need the front and back i think its $166. that will cover me for everything i need...right?
~M@ry
Beside me or behind me... real woman dont ride b*t<h!
Ninja250gurl is offline   Reply With Quote
Old February 3rd, 2012, 08:10 AM   #99
massacremasses
Avid Kitteh Poster
Ok, here's the sale pricing:
Full kit:
Front LED's- $47
Relay- $13
Diode kit- Free
Int. Tail light- $106
Total cost: $166 Shipped (+$15 for a set of Y adapters) Normal cost if you were to buy at a later time: $195
Semi kit:
Front LED's- $47
Diode or relay or Y adapter: Free
Int Tail light- $106
Total cost: $153 Shipped
Kit sale:
Int. Tail Light- $106
Relay- Free
or
Diode kit- Free
or
Y adapter x2- Free
Total Cost:$106 Shipped
Yeah thats right unless you want to run your stock rear turn signals as well. Then I think you need the y adapter. Someone correct me if im wrong.
SEND HIM YOUR EMAIL (paypal email) so he can send you an invoice. Then check you paypal then pay.
Old February 3rd, 2012, 08:13 AM   #100
Ninja250gurl
M@ry M@ry
Yeah, i dont want to run my stock rear turn signals.. Ok, ill send him my paypal email Thanx!
~M@ry
Old February 3rd, 2012, 12:34 PM   #101
CThunder-blue
ModMy250.com
This sale ends next wednesday. If anyone else wants in, please let me know.
Old February 3rd, 2012, 09:30 PM   #102
Bo0stZomb13
PM sent
replied
Old February 4th, 2012, 12:28 AM   #103
CThunder-blue
ModMy250.com
Btw, everyone placing an order by the 8th will be getting a free gift. I won't say what until the sale is over
Old February 4th, 2012, 01:03 AM   #104
5evenz
5evenz's Avatar
oooooo000ooo tantalizing!!!
Old February 4th, 2012, 01:06 AM   #105
Kstorm21
Kstorm21's Avatar
Motorcycle(s): 2009 Ninja 250R SE
WHAAAAAAAAAAAAAAAAAAAT!!!!!! Can't wait!
Kstorm21 is offline   Reply With Quote
Old February 4th, 2012, 02:03 AM   #106
jack_bm
Ex ninjette!
jack_bm's Avatar
I cannot wait to get my tail light and find out what the gift is
Old February 4th, 2012, 09:11 AM   #107
massacremasses
Avid Kitteh Poster
This is like Adamandeve.com!!! you get a free gift there too! ahahahaha
Old February 4th, 2012, 02:41 PM   #108
Makenza
Lurker
Nice! Free stuff? I'll take it!!
Old February 5th, 2012, 01:20 AM   #109
Squalo
Squalo's Avatar
Motorcycle(s): 09 Ninja 250
Ok, I'm in. PM sent
Squalo is offline   Reply With Quote
Old February 5th, 2012, 04:10 PM   #110
dma
dma's Avatar
Sent a PM-- interested. Let me know, thanks.
dma is offline   Reply With Quote
Old February 5th, 2012, 08:27 PM   #111
CThunder-blue
ModMy250.com
Thanks guys, I've updated the list.
Old February 6th, 2012, 03:45 AM   #112
Kstorm21
Kstorm21's Avatar
When will you be shipping stuff out?
Old February 6th, 2012, 08:32 AM   #113
CThunder-blue
ModMy250.com
I'll be placing the order for the tail lights on the 9th. Once they come in along with other parts, I'll start shipping. Everyone who has a US shipping address will get a PayPal notification of the tracking info.
Thanks
Tri
Old February 7th, 2012, 06:00 PM   #114
Bo0stZomb13
Thanks
Tri
Old February 8th, 2012, 08:55 AM   #115
CThunder-blue
ModMy250.com
Last day to get in on the GB people. The prices will never be this low again!
Old February 9th, 2012, 02:42 PM   #116
jack_bm
Ex ninjette!
jack_bm's Avatar
do you know when it will be sent out to GB?
Posted via Mobile Device
Old February 9th, 2012, 03:13 PM   #117
taz_250R
Tinkerer
taz_250R's Avatar
First GB = Group Buy
Second GB = Great Britain
taz_250R is offline   Reply With Quote
Old February 9th, 2012, 03:15 PM   #118
taz_250R
Tinkerer
taz_250R's Avatar
Hey Tri, you got my payment right? Once again thanks for the group buy offer...
Old February 10th, 2012, 02:51 AM   #119
jack_bm
Ex ninjette!
jack_bm's Avatar
OHHHH -.- GB group buy totally new that....
Old February 10th, 2012, 09:55 AM   #120
oreX
oreX's Avatar
Motorcycle(s): 2013 636 - ABS
Any updates on this?
oreX is offline   Reply With Quote
Modmy250.com promo sale! CThunder-blue Motorcycle-related 0 December 9th, 2012 05:45 PM
CustomLED Integrated tail light special sale! CThunder-blue Motorcycle-related 8 October 30th, 2012 01:29 PM
New Brake Light Modulators for sale~! Limited introductory sale!! CThunder-blue Motorcycle-related 15 October 5th, 2012 08:09 PM
Wire integrated tail light such that the brake light stays off while signal flashes? CZroe 2008 - 2012 Ninja 250R Tech Talk 6 March 4th, 2012 06:36 PM
