Old November 25th, 2008, 12:31 PM   #1
Kurosaki
Akai Suisei - 赤い彗星
Kurosaki's Avatar
Motorcycle(s): 08 Kurosaki 250, 09 Honda 600RawrRawr
My 250 track experiences and reviews
First off, thanks to Alex for adding this track sub-section. I can tell this is a really tight-knit and great forum.
Anyway, in this thread I'll post some pictures, the tracks I've been to, reviews of the bike's performance in the track environment, and anything else I can think of to jot down.
Just as a disclaimer, all of this is from my perspective only as a new rider. So keep that in mind when reading my opinions and such.
I'll start off by describing my feelings on the bike in general. First and foremost, it's an absolute great bike for the track no doubt about it. Not only for new riders but also experienced ones. The bike allows you to give all your focus to the racetrack, your lines, your body positioning, etc, without having to worry about things like giving the bike too much gas and spinning the tires, or coming into corners at super high speeds. Things like that. You can get on the throttle very early and pretty much crack the throttle all the way once you're in the turn. And it turns over almost effortlessly with some pressure on the bars and footpegs. The bike allows you to develop the fundamentals of riding before adding in other liabilities and variables like a super powerful engine and brakes. I found myself progressing throughout the day alot quicker than many other riders on 600s or 1000s because it's much easier to be confident with the 250 and what its capabilities which gives me a big boost in confidence to brake later, turn in fast, corner harder, and accelerate earlier.
I'll start some track reviews with my favorite track so far that I've been on out of the three.
The Streets of Willow Springs.
Streets is the 2nd course at Willow Springs International Raceway. It's a 1.7mile(if I remember right) course that is much more technical and slower speeds than the Willow Big track.
Streets was my 2nd track day so I already had a chance to get my feet wet and know what riding at the track is all about. My first thoughts about this track is that it is a fantastic environment for a bike like ours that is light and easily steered from side to side. Many of the turns here require you to go from full lean on one side to full lean on the other side the next moment. So being able to get the bike turned over without much effort is important here not only to keep your speed and racing line but also it doesn't beat you up physically as much.
I'll describe the track turn by turn to start with. You can look at the picture and count the turns.
The front straightaway on this track, as you see at the bottom of the picture above the pits, is not so fast. I don't think I bothered to even shift into 6th gear at all.
-After the front straight, there's a slight bend to the right which is turn 1. You can basically blast right through this turn without backing off the throttle at all. It's a little intimidating at first. But once you get the turn in your head, it's a really good feeling because alot of people on larger bikes tend to back off a little there because they're carrying alot more speed so I was able to make passes right there sometimes
-Turn 2 is a little scary at first because it's pretty tight and you have to remember that after carrying all your speed through turn 1. This is where I was the hardest on the brakes, bleeding off speed to make turn 2 without cooking it too hot into there. I downshift to 3rd I believe for this turn.
-Turn 3 is easier than 2 for me because it's not as tight and I'm not carrying nearly as much speed into this left hander. I took this in 5th I think because I was finding that 1 gear lower had me running out of RPM too early while accelerating out of the turn.
-Turn 4 is a tight short little right that doesn't require as much speed reduction as I first thought because as soon as you apex it, the turn opens right back up.
-The next set of esses are pretty much straight forward and WOT
-The turn at the top is called the bowl turn because it's a big sweeper and it's also banked pretty high. It took me awhile to get comfortable here because you feel you can go into the turn alot deeper than normal which had me scraping my boot or footpeg a few times.
-After coming out of the bowl turn, there's a short back straight which leads to a short group of esses. The esses are a little scary because they are a little hard to see coming out of the bowl which makes it a little difficult to judge what speed you should go through there. After a couple sessions, I was able to get more comfortable but still took it easy for the most part.
-The turn is a quick left followed by a right, and another quick left. That leads out to the skidpad, which you can see labled in the picture. This turn is a little weird because you have to sort of make your own line that works for you. And it's very bumpy. I was finding that it's best to run wide out onto the skidpad, then dive back onto the straight to carry as much speed as possible on the little 250.
And that's a lap at Streets. It's a lot of work and it's easy to get fatigued because there's not anywhere to really relax long enough.
Here are some pictures from this day. Most of these are taken in the Bowl Turn I described.
At the end of the day, the biggest thing I wanted to keep working on is my body positioning on the bike. Form can vary from rider to rider but I notice with this bike and the bars being so high, you really have to exaggerate what you do. When I feel like I'm putting my head down really low, it's not as much as I thought because the height of the bars. Also, the footpegs are pretty low so if I go into a turn fast and deep, either my foot or peg will touch down every now and then. I know this has to do with my form as well so it's just one of the things on the list to work on. I'm hoping that aftermarket clipons will become available for us over winter and I'll be investing in rearsets too to help out with ground clearance.
OK, that's all for now.
Sorry for the long winded post. I'll post up another track in a little bit.
Kurosaki is offline   Reply With Quote
Old November 25th, 2008, 12:41 PM   #2
wouldn't expect anything less from you.
great review and thanks for giving away your secrets. hope to be able to ride that with you guys sometime in the coming year.
Last futzed with by kkim; November 25th, 2008 at 02:33 PM.
Old December 2nd, 2008, 05:38 PM   #3
Kurosaki
Akai Suisei - 赤い彗星
Kurosaki's Avatar
A few pics from Buttonwillow with some other QTR LTRs.
Old December 2nd, 2008, 11:22 PM   #4
VeX
That's me!
VeX's Avatar
Motorcycle(s): 2008 Ninja 250r (Tis blue), 2008 CBR600RR
Kuro, do you pull your headlight fuse when you cover your headlight? Seems a wise thing to do...
VeX is offline   Reply With Quote
Old December 2nd, 2008, 11:24 PM   #5
Kurosaki
Akai Suisei - 赤い彗星
Kurosaki's Avatar
Headlight and taillight, yes.
Old December 2nd, 2008, 11:30 PM   #6
I pulled #2 and #3 for the top left rotation...
Old December 13th, 2008, 03:54 PM   #7
Bill N
Motorcycle(s): 250 Ninja
Joseph,
Excellent report and pictures. This is the first bike I've owned that I'd actually like to take to a track and learn racing basics. Keep up the reports. Thanks, Bill
Bill N is offline   Reply With Quote
Old January 2nd, 2009, 08:25 AM   #8
hairu
hairu's Avatar
Is that Beast's black and white bike?
hairu is offline   Reply With Quote
Old January 2nd, 2009, 01:02 PM   #9
workdaddy
WORKDADDY
workdaddy's Avatar
Motorcycle(s): 2008 ninja 2fitty
I was thinking the same thing... White, black, gold wheels... and then the gear? Looks alot like it might be....
workdaddy is offline   Reply With Quote
Old January 2nd, 2009, 01:10 PM   #10
CRXTrek
FORMER MOTORCYCLE RIDER
CRXTrek's Avatar
Yes it is.
Kuro's is even behind Beast on his B.O.T.Y. Pics
http://www.kawiforums.com/showpost.p...9&postcount=18
Old January 2nd, 2009, 04:51 PM   #11
Kurosaki
Akai Suisei - 赤い彗星
Kurosaki's Avatar
Good eyes to all 3 of you.
Old March 20th, 2009, 01:37 PM   #12
Lurkable
250Arrrgh!
Lurkable's Avatar
Motorcycle(s): 2009 250R, 2001 996
Kuro, loved the report! Posts like this make me all antsy but I still have to wait 2 months before I'll have any time to sign up for my first track day...
Lurkable is offline   Reply With Quote
Old April 4th, 2009, 11:48 PM   #13
almost40
ninjette.org Monkey Spank
almost40's Avatar
Gona hit my first track day in June at Gingerman Raceway in Michigan. Anyone been there or any other Sportbike Track Time event?
Black 250R
Full Area P QC
Old April 27th, 2009, 05:08 PM   #14
hairu
hairu's Avatar
I went there last June or so. Gingerman has huge sealer strips going down the center of the track. Be careful of them if it's raining. The trickiest turn on the track is turn 3. It's double apex right hander that I always managed to mess up. Gingerman is an OK track but Grattan isn't too far away and is way way better.
Dead batteries - your experiences... Linkin 2008 - 2012 Ninja 250R Tech Talk 8 December 8th, 2014 12:42 AM
Any experiences with Rev'it gear? :) Talonne Motorcycle Gear 12 October 5th, 2011 08:39 AM
Learning experiences sombo General Motorcycling Discussion 15 June 4th, 2009 12:37 AM
Any Near-Death experiences? lavid2002 General Motorcycling Discussion 25 April 25th, 2009 08:35 PM
[roadracingworld.com] - Racer Kris Turner Reviews New Track Changes At Road Atlanta Ninjette Newsbot Motorcycling News 0 July 1st, 2008 03:59 PM
