Old October 12th, 2017, 11:30 PM   #1
gitter
Motorcycle(s): 20' Speed Triple RS - 95 ex250
Lots of smoke....piston rings shot?
welp i finally got this 250 running....ish. Still working on the carbs but i noticed when it does run, its making alot of smoke (blueish - gray) and also when it sits on the side stand oil is leaking out of somewhere ( pretty sure its the side case, havent tracked it down yet)
In any case, when this thing was only running on one cylinder due to spark issues, could that have damaged the cylinder / piston rings to the point where they would go bad?
Thanks
Joel
gitter is offline   Reply With Quote
Old October 13th, 2017, 06:35 AM   #2
bob706
bob706's Avatar
compression test
http://sandollarmotorcycleclub.com/
Old October 13th, 2017, 06:51 AM   #3
No, running on one cylinder didn't damage it.
Old October 13th, 2017, 09:48 AM   #4
yeah, the dead cylinder was just coasting along not doing anything.
Compression-test to see condition of the rings and valves. I've got borescope if you want to take a look inside. Although these engines aren't known for burning oil and clogging rings.
Old October 13th, 2017, 10:55 AM   #5
Is the airbox dry of any oil?
new piston rings without honing 3ØØ 2013 - 2017 Ninja 300 Tech Talk 44 February 7th, 2022 01:39 PM
Is there a DIY on piston rings? cookiebug79 1986 - 2007 Ninja 250R Tech Talk 33 April 22nd, 2015 01:17 PM
Stuck piston rings or glazed walls cuong-nutz General Motorcycling Discussion 14 March 5th, 2013 04:26 AM
Where to find oversized piston rings? cuong-nutz General Motorcycling Discussion 19 January 9th, 2013 08:27 AM
Where to buy Piston Rings? iceman.kcmo 1986 - 2007 Ninja 250R Tech Talk 5 January 28th, 2010 11:59 AM
