Old April 29th, 2015, 07:22 AM   #1
Kurgan
Kurgan's Avatar
Motorcycle(s): '09 Ninja 250R
Question Swingarm swap from 300 to 250?
Has anybody tried this?
I went into the dealership last week and saw that the 300 has a 140 rear tire by default, and the swingarm is "modded" so to speak to accept even wider tires with no problem.
Would that swingarm work on a '08-'12 250R?
Kurgan is offline   Reply With Quote
Old April 29th, 2015, 08:03 AM   #2
Somchai
Freedom for Germany
Motorcycle(s): Ninja 250R-FI
Yes, it's the same...
Old April 29th, 2015, 09:51 AM   #3
subxero
dirty boy
subxero's Avatar
MOTM - Apr '14
I think the wheels pretty much swap over, so forget the swingarm and just get the wheel. Not sure if the spacers are the same or not?
Old April 29th, 2015, 10:47 PM   #4
BoBO
BoBO's Avatar
Motorcycle(s): SC28 Fireblade
Same here, I believe you can do a straight swap on front & rear wheels from the N300 to the N250.
94 900RR
04 BMW Z4 2.5 M Package
01 R170 AMG Sport Package
BoBO is offline   Reply With Quote
Old April 30th, 2015, 06:50 PM   #5
Kurgan
Kurgan's Avatar
I'll have to go to the dealership again and take some pictures, the swingarm on the 2015 300 doesn't look the same as the one in the Clymer manual diagram.
Old May 9th, 2015, 11:34 AM   #6
InvisiBill
EX500 full of EX250 parts
InvisiBill's Avatar
I'm not sure about the 2015, but the earlier 300 swingarms are the same as the 250 swingarm as far as I can tell, other than some accessory mounting details. The chainguard has a little hugger builtin, which screws into rivnuts on top of the swingarm, and the brake hose guide might be different. The chainguard is notched at the front to give a little more clearance for a wider tire. The actual main swingarm is the same though (and very similar to the EX500's too).
300 chainguard on a 250 swingarm
Old May 9th, 2015, 12:36 PM   #7
cbinker
Track Clown
cbinker's Avatar
MOTM - Sep '15
300 part number (13) - 33001-0632-18R (non ABS)
300 part number (13) - 33001-0634-18R (ABS)
250 part number (12) - 33001-0558-18R
250 part number (08) - 33001-0558-18R
the 2015s have different part numbers too.
TEAM ALFALFA
www.apexassassins.com
Old June 3rd, 2015, 10:27 AM   #8
I don't think the front is a simple swap because the speedometer is electronic on EFI bikes, right? If so, then there is no speed sender on the left side and it might require some kind of spacer. Even then, you'd be without a speedometer.
Old June 3rd, 2015, 11:12 AM   #9
Qomomoko
Motorcycle(s): 1995 Ninja 250, 2005 R6, 2002 Ducati Monster S4
WHEELS>>
WHats the advantage of Ninja 300 wheels to ninja 250 wheels (new gen)???
Qomomoko is offline   Reply With Quote
Old June 3rd, 2015, 11:16 AM   #10
BoBO
BoBO's Avatar
It depends on the car or motorcycle, but good point a buddy of mine did the wheel swap on his bike before selling it. I didn't inquire the specific mods he did but as far as I know it was simple enough to do for the average Joe. I could ask him if your planning to do a wheel swap. With cars you can just buy a simple analog to digital conversion kit or customize your own on various cars & trucks. Instead of using a cable you use a rotation sensor.
94 900RR
Old June 3rd, 2015, 12:41 PM   #11
BoBO
BoBO's Avatar
For me, it's the rear wheel swap that make sense because of the wider rear rim from the ninja 300. Therefore you can avoid having to pinch the tires when using 140mm+. Most 130 size tires are bias-ply except for the new Michelin, some people prefer radial tires for better life and performance.
94 900RR
Old June 3rd, 2015, 01:33 PM   #12
Qomomoko
ohh...
i did the rear swing arm swap and then some on my pregen 250 to get 17 inch rims but I guess I did not think about different types of 17 inch tyres....
I got 110/70 and 140/70 DRII's...
for the track on a ninja 250.... you guys think larger than 140 has an advantage?.....
Old June 3rd, 2015, 01:40 PM   #13
BoBO
BoBO's Avatar
ohh...
Show us a pic I like the old Ninja's especially the green one since I never see a green one anymore. I wouldn't mind 130 tires if Bridgestone made one for the BT-003 or S20. How long did it take you to do the 17" wheel swap?
94 900RR
Old June 3rd, 2015, 03:37 PM   #14
InvisiBill
InvisiBill's Avatar
http://www.kawasaki.com/Parts/PartsD.../2015/EX300AFS There doesn't appear to be a speedo drive on the 300's front end. My understanding is that the wheel width is the same between the 300 and NewGen, so the swap would just be to get the matching design, not for technical reasons.
This might be an easy way to eliminate the speedo drive from a track NewGen, if the parts in this area are as similar as some of the other wheel-related parts on different models of the small Ninjas.
Whereas the NewGen has tabs right as part of the wheel, the 500 uses a little piece with tabs that clips into the wheel. If you really wanted to use the 300 wheel with a cable speedo, you might be able to adapt that.
Back to the original topic, the 2015 EX300 swingarm in the parts diagram looks pretty similar to the earlier 300 and NewGen swingarms that I've seen, not counting minor accessory mounting differences.
Granted, these are just drawings in a manual, but I don't see anything about that diagram that indicates the main structure of the swingarm is any different. I'm curious to see actual pics of it, to see if there really is any difference.
Random Google image:
That looks pretty similar to what I'm used to.
Old June 3rd, 2015, 05:30 PM   #15
Qomomoko
Pics but check out my thread on this... for more..
here are some pics.. but more info on the thread...
https://www.ninjette.org/forums/showthread.php?t=197898
Old June 10th, 2015, 11:34 PM   #16
BoBO
BoBO's Avatar
Thanks for the link! I like the gixxer shocks as well...clean setup.
94 900RR
Old June 11th, 2015, 05:31 PM   #17
InvisiBill
InvisiBill's Avatar
I get thrown off every time I see this picture. The exhaust hanger (or whatever that is) and its bolt are perfectly aligned with the shock, so I think the shock is hanging from something on the subframe above.
Old August 27th, 2019, 07:27 AM   #18
rabies
time is running out....
rabies's Avatar
Motorcycle(s): pregen ninjari
update. everything is direct swap.
even a 300 ninja swingarm to 78 kz650 bolts up....
The King
rabies is offline   Reply With Quote
250@300 cc swap Shinigami 2008 - 2012 Ninja 250R Tech Talk 21 May 27th, 2015 12:23 PM
